The Skywatcher Merlin Non-Goto - DC 12volt what is the correct Amp?
zhiker
by zhiker » Thu Jan 31, 2013 8:22 pm
This last weekend while coming back from hike in the gorge, my friends
wife insisted we stop at this neighbor hood garage sale, setting there in
the rain was a merlin non-goto mount marked for $20.00, well I have one
already but 2 is better, right, and for $20.00 as is, what the hay. So now
I'm looking to attach a external DC-12 volt power supply for the unit.
In the manual, the only info for external power is DC 12-volt but
there is no Amp value, per chance anyone know the correct value.
Thanks in advance for the info. zhiker
FYI: For half case case of beer, extra, they came up with the hand controller, had
a broken connection, but was easy to correct. :cool:
Mateusz Malinowski
by Mateusz Malinowski » Thu Jan 31, 2013 8:36 pm
"The SynScanTM AZ should be powered by 11-15V DC
power supply (tip-positive) capable of producing
continuous current of minimum 1 amps. Correctly plug
the power cord into the 12V DC outlet on the the
mount ... For Multi-function telescopes, flip the
Power Switch to the "on" position to turn on the power."
Connector 2.1mm x 5.5mm
zhiker
by zhiker » Sat Feb 02, 2013 3:03 pm
First thanks to Mateusz Malinowski for your reply, it was a great help.
So here is what I finally did, went to Radio Shack and purchased a
universal adapter and here is the info for those of you interested
in knowing what product actualy work with the merlin mount.
(1) enercel AC-to-DC Power Adapter 12VDC-1.5A (273035B)
(1) enercel Adapterplug Tip "M" (2730344)
The power adapter was $30.00 US but the plug was Free with purchase.
So far both Merlin's are running just fine with this power adapter,
it is great way to save on battery's when testing out time lapse
sequences code. Not saying Radio Shack is the only way to go but maybe
this info will help those looking for a power adapter option for
testing purposes. zhiker. :cool:
