Papywizard driving stepper motor(s)
Daniel Moore
by Daniel Moore » Tue Jan 22, 2013 6:24 pm
Is it possible to drive two off the shelf stepper motors directly with Papywizard?
by fma38 » Tue Jan 22, 2013 6:48 pm
Do you mean 2 more motors (yaw, pitch, mot1 and mot2)? Or 2 stepper motors, for yaw and pitch?
Daniel Moore
by Daniel Moore » Tue Jan 22, 2013 9:30 pm
I'm thinking two motors total, without the use of a Merlin or Orion interface. The application would be for an X Y linear motion stage.
by fma38 » Tue Jan 22, 2013 10:49 pm
I'm not sure Papywizard is the right choice.
First, you will need to write a new plugin to drive your electronic (what controller do you plan to use?).
Second, Papywizard 'speaks' angles, not mm...
There are better softwares to fit your needs.
Daniel Moore
by Daniel Moore » Tue Jan 22, 2013 11:22 pm
This would be Arduino controlled with Easydrivers or other motor driver. I'm not a programmer so the plugin necessity puts the brakes on it right there : ).
by fma38 » Wed Jan 23, 2013 7:01 am
What is your final usage?
Daniel Moore
by Daniel Moore » Wed Jan 23, 2013 8:36 am
We are working on a DSLR based film scanner requiring an automated XY stage to transport the film beneath the camera, followed by stitching to assemble.
by fma38 » Wed Jan 23, 2013 9:41 am
Interesting project! Do you have a link? I also plan to scan all my films using such DSLR ;)
I think all can be done within the Arduino. There are plenty of examples to drive motors and LCD, read keys, communicate with PC through serial or USB... Unless you really need a complex GUI, I would not use anything else. You will then have a compact, autonomous and robust system, easy to debug. It will be more an integration exercise than a full dev.. That's the nice point with Arduino ;)
And the Arduino community is so large that you will get all the help you need.
