Links to different Bluetooth modules
jriley
by jriley » Tue Dec 25, 2012 5:12 am
I know I have seen a list of links to the various commercial Bluetooth modules available for the Merlin, but I can not find it now :rolleyes:
The only one I seem to find now is the Ursa Minor module, which seems very expensive. I would like to compare to the others before buying one (I have about given up on getting my eb500 to ever work right.) Aren't there at least one or two others? I can't even find where Kolor sells their module separately (though I'm sure I could before.)
Any pointers? This is why I sometimes hate the forum format - finding anything is nearly impossible in the noise. Searching leads to dozens of unrelated threads on which hours are spent searching fruitlessly :(
by mediavets » Tue Dec 25, 2012 11:52 am
The Deltawave Papymerlin BT module was developed especially for use with the Merlin mount and Papywizard.
You can get it here (original source):
Or from the Kolor Web store:
or from SkiVR:
http://magasin.skivr.com/materiel/rotules/panogear/accessoires-panogear/module-bt-panogear.html
Happy Christmas.
jriley
by jriley » Tue Dec 25, 2012 10:29 pm
Thanks - that was what I needed (but your two first links are the same!)
by mediavets » Tue Dec 25, 2012 10:49 pm
jriley wrote:Thanks - that was what I needed (but your two first links are the same!)
Ooops - I'll try again, here's the link to the Kolor web store:
http://www.kolor.com/buy/photo-hardware/accessories/recepteur-bluetooth.html
FLA
by FLA » Wed Dec 26, 2012 6:42 pm
