Papywizard developement
by fma38 » Wed Oct 31, 2012 1:18 pm
Hi all,
Just a little message to say that I finally decided to stop the developement of the Papywizard project.
I explain why in a longer post in the french section of the forum; I let you use an automatic translation tool to read it :D
But let me thank you all for your support during all these years; it has been great to work with you! :)
by klausesser » Wed Oct 31, 2012 2:36 pm
fma38 wrote:Hi all,
Hi Frédéric!
We all owe you our deepest thanks! You led us the way to make our hobby or our profession a joy by using PapyWizard
as an open and free platform.
I didn´t read you explanation in french yet - but i will do.
All the best to you and good luck for everything you´re planning and going to do, Klaus
by fma38 » Wed Oct 31, 2012 3:51 pm
Thank you for these nice words, and thank you for all the support arround Papywizard. You are a major actor!
Christian Stüben
Likes: 3 posts
Liked in: 8 posts
by Christian Stüben » Wed Oct 31, 2012 5:57 pm
fma38 wrote:Hi all,
Hi Frédéric,
that sounds like bad news for many of us :(
But ... on papywizard.com i see there is the source code.
For Windows there is a installer version 2.1.22, but the source code only 2.1.21.r2509.
If i should decide to make a current version for windows, that doesnt show the "spinn forever" fault, is there any chance to get version 2.1.22 as annotated and commented source? Especially the communication between PC and Panogear would be biggest problem...
Greetings from germany
Chris
ps.: and good luck with you low energy house!
Last edited by Christian Stüben on Wed Oct 31, 2012 6:18 pm, edited 1 time in total.
by fma38 » Wed Oct 31, 2012 10:57 pm
Yes, sure, I can provide you the latest files from subversion repository. I'll send them to you.
by fma38 » Sat Nov 03, 2012 9:56 am
Ok, you can find it here:
http://www.papywizard.org/static/download/src/papywizard_2.1.21-r2522_src.zip
If you can fix the bug, feel free to send the patch, so I can put it in subversion. I can also make the window/linux packages.
