[Papywizard] How Can I add waiting time after every shoot
yuca
by yuca » Wed Oct 24, 2012 10:45 pm
Hello Friends ;
I'm new on forum, on panogear, on papywizard :)
I am using panogear and papywizard. And I want to take HDR panoramas.
I'm taking 3 photo for HDR. (As you known; Canon 550d automates this)
But when camera taking second pictures, PanoGear going to next coordinate.
I created custom preset file for Papywizard.
But I must add wait time after every shoot. (like sleep command or like wait command)
What is the command for papywizard file ?
How can I do ?
Thank you and so sorry for my bad English.
Have a nice day.
Content of my preset file :
<?xml version="1.0" encoding="utf-8"?>
<papywizard>
    <preset name="(ROKINON 5X72)+ZENIT+NADIR">
        <tooltip>
            TEST5
        </tooltip>
        <shoot>
            <pict yaw="0" pitch="0."/>
            <pict yaw="72" pitch="0."/>
            <pict yaw="144" pitch="0."/>
            <pict yaw="216" pitch="0."/>
            <pict yaw="288" pitch="0."/>
            <pict yaw="None" pitch="90."/>
            <pict yaw="None" pitch="-90."/>
        </shoot>
    </preset>
</papywizard>
by klausesser » Wed Oct 24, 2012 11:37 pm
yuca wrote:Hello Friends ;
How can I do ?
Have a nice day.
<papywizard>
        <tooltip>
            TEST5
        </tooltip>
        <shoot>
        </shoot>
    </preset>
</papywizard>
How do you control the head? You can set a wait-time on your controlling device (laptop, Nokia N800/810 or TC-handheld). As example: given your bracketing-sequence needs 5 sec. set the wait-time on your device to 6 sec. Then the head waits 6 sec until your sequence of shots is done before it moves to the next position.
You find the setting in the PapyWizard-menue.
RobSherratt
by RobSherratt » Thu Oct 25, 2012 3:14 am
Make sure you have the latest Papywizard version. Try modifying your preset file as follows, let me know if it works?
The <timeValue>3.0</timeValue> means PapyWizard should hold the shutter down for 3 seconds allowing autobracketed exposure on your EOS 550D
<papywizard version="c">
    <preset name="Canon EOS 550D HDR Pano with bracketing">
    <camera>
            <bracketing nbPicts="3"/>
        </camera>
        <tooltip>
            TEST5
        </tooltip>
        <shoot>
        </shoot>
    </preset>
</papywizard>
The <bracketing nbPicts="3"/> in the header is probably not necessary until you import to AutoPano or PTGuiPro.
To handle auto-import of your bracketed exposures I think you will also need these entries, these are not needed in your preset for shooting, but I think are needed to handle HDR assembly correctly.
<shoot>
    <pict bracket="001" id="0001"><position pitch="0.0" roll="90.0" yaw="0.0"/></pict>
    <pict bracket="002" id="0002"><position pitch="0.0" roll="90.0" yaw="0.0"/></pict>
    <pict bracket="003" id="0003"><position pitch="0.0" roll="90.0" yaw="0.0"/></pict>
    <pict bracket="001" id="0004"><position pitch="72.0" roll="90.0" yaw="0.0"/></pict>
    <pict bracket="002" id="0005"><position pitch="72.0" roll="90.0" yaw="0.0"/></pict>
    <pict bracket="003" id="0006"><position pitch="72.0" roll="90.0" yaw="0.0"/></pict>
    <pict bracket="001" id="0007"><position pitch="144.0" roll="90.0" yaw="0.0"/></pict>
    <pict bracket="002" id="0008"><position pitch="144.0" roll="90.0" yaw="0.0"/></pict>
    <pict bracket="003" id="0009"><position pitch="144.0" roll="90.0" yaw="0.0"/></pict>
    <pict bracket="001" id="0010"><position pitch="216.0" roll="90.0" yaw="0.0"/></pict>
    <pict bracket="002" id="0011"><position pitch="216.0" roll="90.0" yaw="0.0"/></pict>
    <pict bracket="003" id="0012"><position pitch="216.0" roll="90.0" yaw="0.0"/></pict>
    <pict bracket="001" id="0013"><position pitch="288.0" roll="90.0" yaw="0.0"/></pict>
    <pict bracket="002" id="0014"><position pitch="288.0" roll="90.0" yaw="0.0"/></pict>
    <pict bracket="003" id="0015"><position pitch="288.0" roll="90.0" yaw="0.0"/></pict>
    <pict bracket="001" id="0016"><position pitch="None" roll="90.0" yaw="90.0"/></pict>
    <pict bracket="002" id="0017"><position pitch="None" roll="90.0" yaw="90.0"/></pict>
    <pict bracket="003" id="0018"><position pitch="None" roll="90.0" yaw="90.0"/></pict>
    <pict bracket="001" id="0019"><position pitch="None" roll="90.0" yaw="-90.0"/></pict>
    <pict bracket="002" id="0020"><position pitch="None" roll="90.0" yaw="-90.0"/></pict>
    <pict bracket="003" id="0021"><position pitch="None" roll="90.0" yaw="-90.0"/></pict>
</shoot>
Rob Sherratt, British ex-pat living in Corfu, Greece
Professional Engineer; Amateur Musician, Photographer and Motorcyclist; Novice Moderator for this part of Kolor Forum!
"If all life's a stage, how come I can't remember my lines?"
by klausesser » Thu Oct 25, 2012 3:54 am
Hey Rob!
No need for coding xml.. Type it into the dialogue-box and that´s it.
see here:
yuca
by yuca » Thu Oct 25, 2012 10:02 pm
Dear klausesser and RobSherratt ;
Thank you for your support :)
Yes, timing problem resolved now. I used <timeValue> parameter in my presets.xml. (And yes, it is the same with parameters dialog)
Now, it is taking 3 photo and waiting enough time. (5 sec.)
On the other hand, I'm having problem with papywizard yet.
When PapyWizard finished job and when it IDLE, Papywizard crashing with message "PapyWizard has stopped working, Windows checking for a solution .... etc ...".
Have you got any solution or opinion for this problem ?
I am using Windows 7 on a Asus Notebook PC.
I am using Bluetooth connection between papywizard and panogear.
Thank you very much...
by klausesser » Thu Oct 25, 2012 10:10 pm
yuca wrote:Have you got any solution or opinion for this problem ?
Sorry - i stopped using PapyWizard after starting to use the TC controller. So i can only tell on what i remember when i used it on my Nokia N800 about 3 Years ago.
yuca
by yuca » Fri Oct 26, 2012 7:54 pm
Anyway, thank you for your support Dear Klausesser ;
I resolved papywizard connection problem by removing and reinstalling blutooh driver.
