PanoramaApp + Skywatcher + BT Home (Dealextreme module 6$) + Android
FLA
by FLA » Wed Oct 10, 2012 2:04 pm
Good morning.
I do not speak English ...sorry
This is a translation of google
From Zaragoza, Spain
I'm new and I come to the forum
I'm Fernando and this is my set for panoramic photography.
Nikon D7000
Nikkor 24 70 2.8 G
Merlin GOTO Skywatcher
Bluetooth adapter home
PanoramaApp Android in HTC Desire HD
I put a video about this.....
http://youtu.be/a0rIvHF1iWI
Regards
Fernando
FLA
by FLA » Wed Oct 10, 2012 9:30 pm
by klausesser » Wed Oct 10, 2012 9:44 pm
FLA wrote:GoodNight....
Another sample...
Hi Fernando!
I suggest to use an additional rail for moving the camera back to match the vertical and horizontal NoParallaxPoint (NPP - vulgo "Nodal-point") by sliding the camera/lens sidewards and for- backwards.
You can find the NPP in some tables like this one: http://wiki.panotools.org/Entrance_Pupil_Database
I can´t see any stitch-errors in your panos - too small - but i bet they´re there ;).
best and good luck, Klaus
FLA
by FLA » Wed Oct 10, 2012 9:54 pm
Hi Klaus!
Thank you very much for the info.
greetings
Fernando
claudevh
by claudevh » Tue Oct 16, 2012 4:35 pm
Excellent job Fernando !
Could-you explain more about the connection between the Android device and the Merlin head ?
:cool: Claude :cool:
Christian Stüben
Likes: 3 posts
Liked in: 9 posts
by Christian Stüben » Tue Oct 16, 2012 10:09 pm
claudevh wrote:Could-you explain more about the connection between the Android device and the Merlin head ?
Yes, please ... i am searching for a portable, programmable device for controling my panogear.
Does the android app support predefined shooting pattern? Does it generate a xml file with the exact position of each shot?
greetings from germany
Chris
Sà­, por favor ... estoy buscando un dispositivo portà¡til y programable para controlando mi panogear.
¿La aplicacià³n android apoyar patrà³n predefinido foto? ¿Genera un fichero xml con la posicià³n exacta de cada uno de fotos?
Saludos desde Alemania
Chris
(esta google translate tambien :P )
FLA
by FLA » Tue Oct 16, 2012 10:52 pm
Hello.
The device is relatively simple to build and works just like the more expensive commercial.
14$
The components needed are:
1. - Bluetooth module like this:
http://dx.com/p/jy-mcu-arduino-bluetooth-wireless-serial-port-module-104299?item=128
2.-adapter TTL / RS232 like this:
http://dx.com/p/mini-rs232-to-ttl-converter-module-board-3-5v-132934?item=1
3. - 5V stabilizer (e.g. 78L05)
4.-A bit of soldering skills
The scheme is below ..
Uploaded with ImageShack.us
Also works ok with papywizard
Imagen_Completa_1 por Fernando Lamarca FLA, en Flickr
Imagen_Conexion_PC por Fernando Lamarca FLA, en Flickr
Greetings
Fernando
yoshiharra
by yoshiharra » Sun Nov 11, 2012 9:42 pm
FLA wrote:Hello.
14$
[url]http://imageshack.us/a/img824/6020/modbtsynscan.jpg[/url]
Greetings
Fernando
Can you upload a picture of the assembled BT (the inner guts)? Thnaks
Canon EOS T3i, EF 100-400mm, Tokina 100mm, Sigma 15mm, Samyang 8mm, Nodal Ninja 5L & R10, Merlin - Papywizard on Nokia N810
FLA
by FLA » Mon Nov 12, 2012 12:00 am
Hello.
Unfortunately, the device is put into a plastic shrink tubing to protect the inside and I can not remove it to show the interior.
The assembly is as describe in the previous post ...
Any questions you have can you ask without problems ...
greetings
Fernando
FelixAutopano
by FelixAutopano » Thu Feb 28, 2013 8:01 pm
Will this be functional with Merlin head itself connected to N800 or PC with BT?
Is this working same as BT module from Kolor or UrsaMinor?
The God is Out There
FLA
by FLA » Thu Feb 28, 2013 10:45 pm
claudevh
by claudevh » Sun Mar 31, 2013 10:22 am
Hello all ...
To "darkskies"
In the post mentionned by you,
http://www.kolor.com/forum/p110966-2013-01-23-18-32-01#p110966
there is only a "BT to TTL 5v module" who should be plugged directly into the base of the Allview mount or in the base of the Merlin head !
When you plug directly in the base, you should remove the hand controler.
This type of module will not work when plugged into the Goto Handcontroler, anyway this module have a RJ12 connector who will not fit at the base of the hand controler !!!!
In the present post,
http://www.kolor.com/forum/p106366-2012-10-16-23-52-46#p106366
there is a BT to RS232 module (with a TTL to RS232 additional convertor) who should be plugged into the Goto Hand controler RS232 port and the Goto hand controler should be set to "Direct PC mode"
The wiring schema's are not the same !!!
