Serial link to NonGoTo Merlin. Help needed!
magic03
by magic03 » Thu Aug 09, 2012 6:10 pm
Hello Community :)
I've got my new Non GoTo Merlin recently and my adventure to easy panolife has began :)
My config: Win 7 x64/ Papywizard 2.1.21 / NK Remote for shutter release (Don't have Nikon D80 shutter cable yet).
10.08.12 Update: Ubuntu x86 / Papywizard 2.1.21 - same. No init response from mount
Mount works fine fom Hand control BUT can't start it from wire link.
I have found HL-340 USB to RS232 cable in a local store. ( Here are some details: http://hades.mech.northwestern.edu/index.php/PIC_RS232 )
I have added two 220ohms on RT&TX pins as described here in many posts from forum Gurus.
On connect in Papywizard I'm getting "Green" :) in Connect column and "Red" :( in Init.
Here is my log:
2012-08-09 22:30:13,200::Main::DEBUG::MainController.__onActionHardwareConnectToggled(True)
2012-08-09 22:30:13,200::Main::INFO::Starting connection. Please wait...
2012-08-09 22:30:13,213::Main::DEBUG::PluginsConnector.start(): 'yawAxis' establish connection
2012-08-09 22:30:13,217::Main::DEBUG::PluginsConnector.start(): 'yawAxis' init
2012-08-09 22:30:14,246::Main::EXCEPTION::MerlinOrionHardware.__sendCmd
File "papywizard\hardware\merlinOrionHardware.pyo", line 145, in __sendCmd
File "papywizard\driver\serialDriver.pyo", line 115, in read
IOError: Timeout while reading on serial bus (size=1, data='')
2012-08-09 22:30:14,246::Main::WARNING::MerlinOrionHardware.__sendCmd(): axis 1 can't sent command ':L1\r'. Retrying...
2012-08-09 22:30:15,275::Main::EXCEPTION::MerlinOrionHardware.__sendCmd
2012-08-09 22:30:15,275::Main::WARNING::MerlinOrionHardware.__sendCmd(): axis 1 can't sent command ':L1\r'. Retrying...
2012-08-09 22:30:16,303::Main::EXCEPTION::MerlinOrionHardware.__sendCmd
2012-08-09 22:30:16,303::Main::WARNING::MerlinOrionHardware.__sendCmd(): axis 1 can't sent command ':L1\r'. Retrying...
2012-08-09 22:30:16,303::Main::EXCEPTION::PluginsConnector.connectPlugins()
File "papywizard\plugins\pluginsConnector.pyo", line 89, in start
File "papywizard\plugins\merlinOrionPlugins.pyo", line 157, in init
File "papywizard\plugins\abstractHardwarePlugin.pyo", line 104, in init
File "papywizard\hardware\merlinOrionHardware.pyo", line 178, in init
File "papywizard\hardware\merlinOrionHardware.pyo", line 164, in __sendCmd
HardwareError: axis 1 can't send command ':L1\r'
2012-08-09 22:30:16,305::Main::DEBUG::PluginsConnector.start(): 'pitchAxis' establish connection
2012-08-09 22:30:16,305::Main::DEBUG::PluginsConnector.start(): 'pitchAxis' init
2012-08-09 22:30:17,334::Main::EXCEPTION::MerlinOrionHardware.__sendCmd
2012-08-09 22:30:17,334::Main::WARNING::MerlinOrionHardware.__sendCmd(): axis 2 can't sent command ':L2\r'. Retrying...
2012-08-09 22:30:18,362::Main::EXCEPTION::MerlinOrionHardware.__sendCmd
2012-08-09 22:30:18,362::Main::WARNING::MerlinOrionHardware.__sendCmd(): axis 2 can't sent command ':L2\r'. Retrying...
2012-08-09 22:30:19,391::Main::EXCEPTION::MerlinOrionHardware.__sendCmd
2012-08-09 22:30:19,391::Main::WARNING::MerlinOrionHardware.__sendCmd(): axis 2 can't sent command ':L2\r'. Retrying...
2012-08-09 22:30:19,391::Main::EXCEPTION::PluginsConnector.connectPlugins()
File "papywizard\plugins\pluginsConnector.pyo", line 108, in start
HardwareError: axis 2 can't send command ':L2\r'
2012-08-09 22:30:19,392::Main::DEBUG::PluginsConnector.start(): 'shutter' establish connection
2012-08-09 22:30:19,392::Main::DEBUG::PluginsConnector.start(): 'shutter' init
2012-08-09 22:30:19,392::Main::DEBUG::NkRemoteShutter.configure(): camera exposure compensation table=['+5', '+4 1/2', '+4', '+3 1/2', '+3', '+2 1/2', '+2', '+1 1/2', '+1', '+1/2', '0', '-1/2', '-1', '-1 1/2', '-2', '-2 1/2', '-3', '-3 1/2', '-4', '-4 1/2', '-5']
2012-08-09 22:30:19,394::Main::DEBUG::NkRemoteShutter.configure(): user exposure compensation list=[u'-2', u' 0', u' +2']
2012-08-09 22:30:19,394::Main::ERROR::Connection failed to start
2012-08-09 22:30:21,723::Main::DEBUG::MainController.__onActionHardwareConnectToggled(False)
2012-08-09 22:30:21,724::Main::DEBUG::PluginsConnector.start(): 'yawAxis' stop connection
2012-08-09 22:30:21,724::Main::DEBUG::PluginsConnector.start(): 'pitchAxis' stop connection
2012-08-09 22:30:21,726::Main::DEBUG::PluginsConnector.start(): 'shutter' shutdown
2012-08-09 22:30:21,726::Main::DEBUG::PluginsConnector.start(): 'shutter' stop connection
Would appreciate for any help! )
claudevh
by claudevh » Sun Aug 12, 2012 4:24 pm
Hello "Magic03", welcome on board.
I am affraid that you have not buy the right convertor !
Indeed the "HL-340 USB to RS232 Cable" deliver pure RS232 signal and this signal isn't appropriate for the Merlin processor who need TTL signal.
More then that you have a risk of deterioration of the Merlin processor with this RS232 12 Volt signal !!!
I fact you should use the "FTDIChip TTL-232R" who is a TTL device who can be understand by the Merlin (TTL 5V)
If you buy the FTDIChip TTL-232R you must buy the TTL 5V model and not the TTL 3.3V model .
:cool: Claude :cool:
magic03
by magic03 » Mon Aug 13, 2012 8:31 pm
Hello Claude!
Thanks for your answer. When I've checked signals on HL-340 and there was low voltage TTL as should be.
Mount needs TTL 5v but i have 3v cable. This is the key I think!
Actually I orderd already bluethooth adapter from Kolor.. but can't wait while La Poste will play with my parcel.. (it's fourth day at the sort center already)
So.. will continue my search )
