What happened to "Orion TeleTrack altazimuth tracking mount"?
yoshiharra
by yoshiharra » Fri Jun 01, 2012 4:13 pm
I am looking to buy "Orion TeleTrack altazimuth tracking mount", but nowhere to be found in US?!!
Can anyone tell me when and were I can buy one? If not, what is a good substitute that will work intend? :(
Thanks in advance
Yosshiharra
Canon EOS T3i, EF 100-400mm, Tokina 100mm, Sigma 15mm, Samyang 8mm, Nodal Ninja 5L & R10, Merlin - Papywizard on Nokia N810
by mediavets » Fri Jun 01, 2012 7:18 pm
Welcome to the forum...
It seems this mount is no longer marketed in the USA.
You can either import a Merlin-branded one from Europe, or the Panogear-branded model from Kolor or SkiVR, or look at the newer larger heavier Celestron Sky-watcher Allview mount which is reported to be compatible with Papywizard:
http://www.celestron.com/astronomy/mounts/celestron-allview-mount.html
See: http://www.kolor.com/forum/viewtopic.php?id=11240&p=2
yoshiharra
by yoshiharra » Fri Jun 01, 2012 7:54 pm
Hi mediavets
Thanks for your prompt reply. Couple of questions,
1. Can this be setup with bluetooth dongle for use with Nokia 810 and Android Tablet?
2. Can you provide links to Orion TeleTrack vender in Europe?
yoshiharra
by mediavets » Fri Jun 01, 2012 9:17 pm
yoshiharra wrote:Hi mediavets
Kolor reported that they had tested a prototype with papytwizard and it worked fine - so I imagine that's a 'yes' but I have no personal experience of the Allview model.
I think it may be best that you contact the person who reported owning one in that forum therad I referenced in my previous post.
and Android Tablet?
I don't know but if it works with Papywizard it should work with the software that's in development for Android.
Here you are - it is marketed as the Merlin in Europe:
http://www.autopano.net/wiki-en/action/view/PapyMerlin_FAQ#Where_to_buy_a_Merlin_mount_.3F
yoshiharra
by yoshiharra » Fri Jun 01, 2012 11:31 pm
Thanks a lot! :D
