PanoramaApp exprimental Android application
vincen
Kolor Certified Trainer
Likes: 23 posts
Liked in: 4 posts
by vincen » Thu Feb 16, 2012 7:32 am
skyml wrote:How's progress on this going? Would love to see an android app that can control my merlin. Focus for me would be panos and time lapse.
Search for "PanoramaApp" on Android Market :)
Vincèn
DIRECT LINK to PanoramaApp !
https://play.google.com/store/apps/details?id=com.skywatcher.PanoramaApp&feature=search_result#?t=W251bGwsMSwyLDEsImNvbS5za3l3YXRjaGVyLlBhbm9yYW1hQXBwIl0.
The actual objectives of the PanoramApp:
claudevh wrote:I am really happy if you try PanoramApp.
This is just a test using the Skywatcher API put at disposal "officially" by Skywtacher.
My son have prepared a ".APK" for Android solving some BT issues.
The future objectives are:
- to let this application run on the "smallest" Android smartphone. (Anroid 2.2 = the lower target !)
- to built-in the Papywizard Preset utilisation and generate the Kolor presets.
- to built-in some "timelapse" functionalities.
This development will stay "open" like Papywizard ...
BUT this is still "in development"
Blog: http://www.skivr.com
skyml
by skyml » Thu Feb 16, 2012 8:10 am
Vincèn - WOW! :D Downloaded the App and it's working pretty damn good. It's not fully capable like papywizard yet but looks very functional. Will have to play with it more and figure how to set the FOV for my lenses and test with my camera mounted. Will definatley mention this app to users of the Merlin on the Time Scapes forum... though I see no time lapse function it will be worth looking at for wireless control. I permanetly wired one of Claudes BT adapters into one of my Merlins and added a switch to turn it on when I'm not using the MX2 to control it. Being able to flip a switch and use the app on my Droid to manually control the head is pretty cool.
Mike Lanfor
Celestron Skywatcher Panohead (firmeware version=010981), Papywizard, Nokia 800 (OS2008), Win 7 64 on Sony VIAO, Canon 7D, 40D, 30D with Canon 70-200mm F2.8L IS, 24-135mm F3.5 IS, Sigma 15mm F2.8, Vivitar 7mm f3.5 Fisheye for Canon (manual lens), Sigma 135-500mm f3.5/5.6.
Focus Time Lapse and Spherical Pano's/pano tours (Autopano gig and Tour). Dynamic Perception Dolly with MX2.
claudevh
by claudevh » Thu Mar 15, 2012 12:15 am
This is a post of "gkaefer" who as been lost !
Herafter what he said about "PanoramAPP"
gkaefer wrote:did install the panoramaAPP from android marked to my Sony Xperia X10 with android 3.2
I could connect to a BT modul coming from Teleskop Austria
and I could use the left,up,down,right button to move my merlin.
what I discovered: if my mobile changes from portrait to landscape screen modus, the Bluethooth connection is gone I've to reconnect inkl. using password for peering again.
same if screensaver is being enabled or the app is in background.
keep on going!
UPS - CORRECTION "android 2.3.3" is correct
Thank-you for your feedback Georg !
:cool: Claude :cool:
vincen
Likes: 23 posts
Liked in: 4 posts
by vincen » Thu Mar 15, 2012 10:48 am
Just noticed something, it's no more able to connect since I upgraded my Samsung Galaxy SII to ICS (Ice Cream Sandwich). Any ideas what's wrong ?
Thanks,
claudevh
by claudevh » Thu Mar 15, 2012 5:18 pm
No idea Vincèn ...
We will investigate !
vincen
Likes: 23 posts
Liked in: 4 posts
by vincen » Thu Mar 15, 2012 7:18 pm
claudevh wrote:No idea Vincèn ...
no problem, let me know if you need I test something special or some logs or whatever ;)
Vincèn
claudevh
by claudevh » Fri Mar 16, 2012 12:18 am
A comment send by email on March, 14 :
johnfor wrote:Claude this app is very nice it connected perfect to your BT. (used a
samsung galacy 1)
Look more promissing than sticking to Nokia's Maemo!
The interface has a steep learning curve but it is a step forwards.
Lens configuration is one to look at.
One button script action (importing scripts)
I will follow this closely.
alexdziga
by alexdziga » Tue May 22, 2012 11:19 am
Hello ,
I just test panoramaApp on my phone sony ericsson wi19 and he work perfectly
but i dont understand preset, i am newer with merlin.
I want to make a spherical pano , what preset i must use?
Where i can find manual ?
I have nikon d7000 with 10,5 nikkor
by mediavets » Tue May 22, 2012 12:44 pm
alexdziga wrote:Hello ,
You can find description of Papywizard custom preset files here:
http://www.papywizard.org/wiki/UserGuideSvn#Custompresets
You can create custom preset files with any text editor - however they must be saved with UTF-8 encoding; this can be done easily with Windows Notepad.
With a DX Nikon and the Nikkor 10.5mm fisheye I use one of two shooting patterns.
1. Used outdoors - 6 around at approx. -15 degrees and one or two up and approx. +65 degrees (if two shots then with say 120 degree yaw separation). This covers the zenith but you'll have 'hole' at the nadir - quite large with Merlin mount vs. a manual panohead - that you'll have to handle separately.
2. Used indoors - 6 around at approx. -15 degrees and a second row of 6 around at approx +50 degrees pitch - this also covers the zenith but you'll have 'hole' at the nadir - quite large with Merlin mount vs. a manual panohead - that you'll have to handle separately. I find two rows of 6 around results in a better stitch when shooting domestic scale inetrior spherical panos.
claudevh
by claudevh » Tue May 22, 2012 3:50 pm
Hello "alexdziga" ,
Pay attention that PanoramaApp is still a "experimental" application in development ...
So it is actually impossible to use the "Papywizard Presets" with PanoramaApp.
But this will be updated soon ...
Anyway, when you have configured and saved your scenario in PanaramaApp, this stay availlable you have just to recall the scenario and play it again !
Have fun.
And share your experiences.
Claude
P.S. The link to your web site in the signature DON'T work !!!
kwalter
by kwalter » Wed Sep 26, 2012 4:51 pm
Can you tell me what changes her son has made ​​to the Bluetooth settings?
When I compile the source code of http://code.google.com/p/skywatcher/
I have big problems with the Bluetooth connection!
The PanoramaApp of her son on the other hand connects without problems, unfortunately I have no source code thereof.
Greetings
kwalter
