How to copy shooting-xml from N810 to laptop
trieutran
by trieutran » Mon Mar 12, 2012 3:04 pm
Hi all
I'm a newbie here.
I purchased the Merlin, Nokia N810, and Claude's Deltawave PapyMerlin BT module, shooting with a Nikon D700, 24, 50, and 85 mm lenses.
Everything works great. Papywizard is a fantastic program.
I'd like to copy the shooting-xml from Nokia N810 to a Windows laptop.
I think this topic was discussed in 2008 in the link below, but I could not find out how to do it.
http://www.kolor.com/forum/t4810-install-papywizard-on-nokia-770,n800-and-n810
Thanks in advance.
Trieu Tran
Atlanta, US
by fma38 » Mon Mar 12, 2012 3:39 pm
The easiest way is to use the µ-SD card. Just enter the correct path in Papywizard ('data' tab) ; it should be something like /dev/mmc1 or /dev/mmc2. Then, when you plug the nokia with the usb cable, the content of the card is seen from the computer as a mass media storage.
trieutran
by trieutran » Tue Mar 13, 2012 1:45 am
Thanks Frédéric,
This works very well
Trieu
