MAC OSX 10.7
mawa_73527
MAC OSX 10.7
by mawa_73527 » Tue Jan 03, 2012 6:57 pm
Hi and Happy New Year,
any body out there using Mac OSX 10.7 Lion?
Can anyone tell me if a connection can be established using bluetooth?
I simply cannot get the a bluetooth connection working on MAC OSX 10.7 Lion.
If someone was able to get a connection please post some screen shots the manual PDF its outdated!
Have a nice one
Matthias
vincen
Kolor Certified Trainer
Likes: 23 posts
Liked in: 4 posts
by vincen » Wed Jan 04, 2012 7:24 am
HI Matthias,
Few experiences of Papywizard with Lion have been negative till now :( Did you link first the bluetooth dongle with Mac OSX ?
Vincèn
Blog: http://www.skivr.com
mawa_73527
by mawa_73527 » Wed Jan 04, 2012 8:18 am
I am using a bluetooth dongle from Belkin. The Bluetooth Menus in Lion have changes from what you can read in the manual. I got the the dongle to connect to the bt module but was not able to connect at all using Papywizard.
Matthias
P.S. Love your site and Panos!
DArt
by DArt » Wed Jan 04, 2012 8:42 am
vincen
Likes: 23 posts
Liked in: 4 posts
by vincen » Wed Jan 04, 2012 9:45 am
mawa_73527 wrote:I am using a bluetooth dongle from Belkin. The Bluetooth Menus in Lion have changes from what you can read in the manual. I got the the dongle to connect to the bt module but was not able to connect at all using Papywizard.
Why don't you use the dongle included with Panogear kit ? Have you been able to find in Lion the serial port created by Lion for the BT link created ?
mawa_73527 wrote:P.S. Love your site and Panos!
Thanks it's nice :P
mawa_73527
by mawa_73527 » Wed Jan 04, 2012 9:52 am
I tried to use it under Leopard and it never really worked with me. So Used a dongel from Belkin and it worked since then.
I will look if I can find any information on the serial port.
vincen
Likes: 23 posts
Liked in: 4 posts
by vincen » Wed Jan 04, 2012 10:05 am
mawa_73527 wrote:I tried to use it under Leopard and it never really worked with me. So Used a dongel from Belkin and it worked since then.
Once paired your Belkin dongle installed on your mac with the Merlin bluetooth dongle, your screen should look similar to that in System Preferences of Lion (see first capture). Don't forget to add the bluetooth device in favorite (with help of round icon at right of +/- at bottom of Bluetooth Window.
Then if you select on that same icon Modify Serial Port, you should get the second screen (below). You can then configure Papywizard to work in serial mode and copy/paste serial port of System Preferences in Papywizard and it should work fine ;)
Vincèn
mawa_73527
by mawa_73527 » Wed Jan 04, 2012 10:22 am
Yes just found this as well ... now is my setup in the papywizard correct?
With this setup my papywizard hangs!
mawa_73527
by mawa_73527 » Wed Jan 04, 2012 11:13 am
OK I got a connection got the head to rotate Now I am trying to get it to make 4 picts + nadir shot!
The image of the setting is beneath:
mawa_73527
by mawa_73527 » Wed Jan 04, 2012 11:34 am
Ok can control the panohead tilt turn it with the arrows ... I cannot get it to make a set of images. I was able to get it to make one image and then it stpped telling that it had failed to complete the request!
vincen
Likes: 23 posts
Liked in: 4 posts
by vincen » Wed Jan 04, 2012 11:36 am
mawa_73527 wrote:Ok can control the panohead tilt turn it with the arrows ... I cannot get it to make a set of images. I was able to get it to make one image and then it stpped telling that it had failed to complete the request!
oky cool at least connection is working now :) when you got the grid of shooting, did you get a green square or still yellow ? Did the camera trigger ?
mawa_73527
by mawa_73527 » Wed Jan 04, 2012 11:40 am
Hi
Here the results:
I wanted to reconnect and it worked. So this is secure.
The camera triggered once I could not get it to trigger again.
The yellow squares did not turn green!
by fma38 » Wed Jan 04, 2012 4:29 pm
Can you post the logs, right after the shooting failed?
mawa_73527
by mawa_73527 » Wed Jan 04, 2012 4:33 pm
2012-01-04 11:20:35,054::MainThread::EXCEPTION::Axis._sendCmdTraceback (most recent call last): File "papywizard/hardware/axis.pyc", line 236, in _sendCmd File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2012-01-04 11:20:35,055::MainThread::WARNING::Axis._sendCmd(): axis 2 can't sent command. Retrying...
2012-01-04 11:20:35,270::MainThread::EXCEPTION::Axis._sendCmdTraceback (most recent call last): File "papywizard/hardware/axis.pyc", line 236, in _sendCmd File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2012-01-04 11:20:35,271::MainThread::WARNING::Axis._sendCmd(): axis 2 can't sent command. Retrying...
2012-01-04 11:20:36,818::Spy::EXCEPTION::Axis._sendCmdTraceback (most recent call last): File "papywizard/hardware/axis.pyc", line 236, in _sendCmd File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2012-01-04 11:20:36,819::Spy::WARNING::Axis._sendCmd(): axis 2 can't sent command. Retrying...
2012-01-04 11:20:39,070::Spy::EXCEPTION::Axis._sendCmdTraceback (most recent call last): File "papywizard/hardware/axis.pyc", line 236, in _sendCmd File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2012-01-04 11:20:39,070::Spy::WARNING::Axis._sendCmd(): axis 2 can't sent command. Retrying...
by fma38 » Wed Jan 04, 2012 9:52 pm
There is a communication problem. Maybe a bad connection? Or too low batteries?
mawa_73527
by mawa_73527 » Thu Jan 05, 2012 7:19 pm
Ok I recharged the batteries ...
so now I got the head to move again and start a series of shots. But then it stops in the middle of the shoot. It will have made one shot then moved. Or it will have moved without making a shot ... spoke very unreliable to me!
Here is the log:
2012-01-05 19:17:42,615::MainThread::INFO::Starting Papywizard...
2012-01-05 19:17:42,765::MainThread::INFO::Importing modules...
2012-01-05 19:17:42,851::MainThread::DEBUG::Shooting.start(): loading user external shooting scriptTraceback (most recent call last):  File "papywizard/model/shooting.pyc", line 70, in <module>ImportError: No module named shoot
2012-01-05 19:17:42,852::MainThread::WARNING::No user external shooting script found
2012-01-05 19:17:42,934::MainThread::INFO::Loading i18n files...
2012-01-05 19:17:42,938::MainThread::DEBUG::Papywizard.i18n(): locale=de_DE
2012-01-05 19:17:42,938::MainThread::WARNING::Can't find qt translation file
2012-01-05 19:17:42,939::MainThread::INFO::Loading Style Sheets...
2012-01-05 19:17:42,973::MainThread::WARNING::No user Style Sheet found
2012-01-05 19:17:42,974::MainThread::INFO::Loading configuration...
2012-01-05 19:17:42,990::MainThread::DEBUG::ConfigManager.__init__(): versions: dist=['2', '0', '0'], user=[u'2', u'0', u'0']
2012-01-05 19:17:42,991::MainThread::DEBUG::ConfigManager.__init__(): user config. is up-to-date
2012-01-05 19:17:42,991::MainThread::INFO::Creating model...
2012-01-05 19:17:43,008::MainThread::INFO::Loading default presets
2012-01-05 19:17:43,019::MainThread::DEBUG::Preset.__init__(): loading name='4@0 + Z + N'
2012-01-05 19:17:43,020::MainThread::DEBUG::Preset.__init__(): loading name='4@-15 + Z'
2012-01-05 19:17:43,020::MainThread::DEBUG::Preset.__init__(): loading name='6@30 + 6@-15 + N'
2012-01-05 19:17:43,021::MainThread::DEBUG::Preset.__init__(): loading name='4@30 + 4@-30'
2012-01-05 19:17:43,021::MainThread::DEBUG::Preset.__init__(): loading name='3 + 6 + 12 + 6 + 3 (28mm)'
2012-01-05 19:17:43,022::MainThread::DEBUG::Preset.__init__(): loading name='4 + 12 + 12 + 12 + 8 (32mm)'
2012-01-05 19:17:43,023::MainThread::INFO::Loading user presets
2012-01-05 19:17:43,024::MainThread::WARNING::No user presets found
2012-01-05 19:17:43,024::MainThread::INFO::Starting Spy...
2012-01-05 19:17:43,024::MainThread::DEBUG::Spy.__init__(): yaw=0.0, pitch=0.0
2012-01-05 19:17:43,025::Spy::INFO::Starting Spy...
2012-01-05 19:17:43,025::MainThread::INFO::Creating GUI...
2012-01-05 19:17:43,159::MainThread::TRACE::MainController.__onTabWidgetCurrentChanged()
2012-01-05 19:17:43,161::MainThread::DEBUG::MainController.__onTabWidgetCurrentChanged(): shooting mode set to 'preset'
2012-01-05 19:17:50,746::MainThread::INFO::Connecting to real hardware...
2012-01-05 19:17:52,787::Dummy-4::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2012-01-05 19:17:52,788::Dummy-4::WARNING::Axis._sendCmd(): axis 1 can't sent command. Retrying...
2012-01-05 19:17:53,084::Dummy-4::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2012-01-05 19:17:53,085::Dummy-4::WARNING::Axis._sendCmd(): axis 1 can't sent command. Retrying...
2012-01-05 19:17:53,289::Dummy-4::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2012-01-05 19:17:53,290::Dummy-4::WARNING::Axis._sendCmd(): axis 1 can't sent command. Retrying...
2012-01-05 19:17:53,530::Dummy-4::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2012-01-05 19:17:53,531::Dummy-4::WARNING::Axis._sendCmd(): axis 1 can't sent command. Retrying...
2012-01-05 19:17:53,773::Dummy-4::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2012-01-05 19:17:53,773::Dummy-4::WARNING::Axis._sendCmd(): axis 1 can't sent command. Retrying...
2012-01-05 19:17:54,039::Dummy-4::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2012-01-05 19:17:54,039::Dummy-4::WARNING::Axis._sendCmd(): axis 1 can't sent command. Retrying...
2012-01-05 19:17:54,305::Dummy-4::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2012-01-05 19:17:54,305::Dummy-4::WARNING::Axis._sendCmd(): axis 2 can't sent command. Retrying...
2012-01-05 19:17:54,510::Dummy-4::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2012-01-05 19:17:54,511::Dummy-4::WARNING::Axis._sendCmd(): axis 2 can't sent command. Retrying...
2012-01-05 19:17:54,776::Dummy-4::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2012-01-05 19:17:54,777::Dummy-4::WARNING::Axis._sendCmd(): axis 2 can't sent command. Retrying...
2012-01-05 19:17:55,042::Dummy-4::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2012-01-05 19:17:55,043::Dummy-4::WARNING::Axis._sendCmd(): axis 2 can't sent command. Retrying...
2012-01-05 19:17:55,309::Dummy-4::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2012-01-05 19:17:55,310::Dummy-4::WARNING::Axis._sendCmd(): axis 2 can't sent command. Retrying...
2012-01-05 19:17:55,432::MainThread::INFO::Now connected to real hardware
2012-01-05 19:17:55,569::Spy::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2012-01-05 19:17:55,570::Spy::WARNING::Axis._sendCmd(): axis 1 can't sent command. Retrying...
2012-01-05 19:17:55,774::Spy::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2012-01-05 19:17:55,775::Spy::WARNING::Axis._sendCmd(): axis 1 can't sent command. Retrying...
2012-01-05 19:17:56,029::Spy::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2012-01-05 19:17:56,031::Spy::WARNING::Axis._sendCmd(): axis 1 can't sent command. Retrying...
2012-01-05 19:17:56,031::Spy::EXCEPTION::Spy.refresh(): can't read positionTraceback (most recent call last):  File "papywizard/controller/spy.pyc", line 157, in refresh  File "papywizard/hardware/head.pyc", line 149, in readPosition  File "papywizard/hardware/axis.pyc", line 273, in read  File "papywizard/hardware/axis.pyc", line 243, in _sendCmdHardwareError: Axis 1 can't send command
2012-01-05 19:17:56,795::Spy::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2012-01-05 19:17:56,796::Spy::WARNING::Axis._sendCmd(): axis 2 can't sent command. Retrying...
2012-01-05 19:17:59,521::MainThread::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2012-01-05 19:17:59,521::MainThread::WARNING::Axis._sendCmd(): axis 2 can't sent command. Retrying...
2012-01-05 19:17:59,789::MainThread::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2012-01-05 19:17:59,789::MainThread::WARNING::Axis._sendCmd(): axis 2 can't sent command. Retrying...
2012-01-05 19:18:00,055::Spy::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2012-01-05 19:18:00,056::Spy::WARNING::Axis._sendCmd(): axis 1 can't sent command. Retrying...
2012-01-05 19:18:00,274::Spy::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2012-01-05 19:18:00,275::Spy::WARNING::Axis._sendCmd(): axis 2 can't sent command. Retrying...
2012-01-05 19:18:00,540::Spy::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2012-01-05 19:18:00,540::Spy::WARNING::Axis._sendCmd(): axis 2 can't sent command. Retrying...
2012-01-05 19:18:02,380::Shooting::INFO::Start shooting process...
2012-01-05 19:18:02,397::Shooting::INFO::Moving
2012-01-05 19:18:02,790::Shooting::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2012-01-05 19:18:02,791::Shooting::WARNING::Axis._sendCmd(): axis 1 can't sent command. Retrying...
2012-01-05 19:18:03,031::Shooting::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2012-01-05 19:18:03,032::Shooting::WARNING::Axis._sendCmd(): axis 1 can't sent command. Retrying...
2012-01-05 19:18:03,275::Shooting::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2012-01-05 19:18:03,275::Shooting::WARNING::Axis._sendCmd(): axis 1 can't sent command. Retrying...
2012-01-05 19:18:03,541::Shooting::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2012-01-05 19:18:03,542::Shooting::WARNING::Axis._sendCmd(): axis 1 can't sent command. Retrying...
2012-01-05 19:18:03,809::Shooting::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2012-01-05 19:18:03,811::Shooting::WARNING::Axis._sendCmd(): axis 1 can't sent command. Retrying...
2012-01-05 19:18:04,026::Shooting::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2012-01-05 19:18:04,027::Shooting::WARNING::Axis._sendCmd(): axis 1 can't sent command. Retrying...
2012-01-05 19:18:04,292::Shooting::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2012-01-05 19:18:04,292::Shooting::WARNING::Axis._sendCmd(): axis 1 can't sent command. Retrying...
2012-01-05 19:18:04,293::Shooting::EXCEPTION::Shooting.start()Traceback (most recent call last):  File "papywizard/model/shooting.pyc", line 619, in start  File "papywizard/hardware/head.pyc", line 194, in stopAxis  File "papywizard/hardware/axis.pyc", line 372, in stop  File "papywizard/hardware/axis.pyc", line 243, in _sendCmdHardwareError: Axis 1 can't send command
2012-01-05 19:18:04,294::Shooting::ERROR::Shoot process failed
2012-01-05 19:18:04,582::Spy::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2012-01-05 19:18:04,583::Spy::WARNING::Axis._sendCmd(): axis 2 can't sent command. Retrying...
2012-01-05 19:18:04,785::Spy::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2012-01-05 19:18:04,786::Spy::WARNING::Axis._sendCmd(): axis 2 can't sent command. Retrying...
2012-01-05 19:18:10,822::Spy::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2012-01-05 19:18:10,823::Spy::WARNING::Axis._sendCmd(): axis 2 can't sent command. Retrying...
2012-01-05 19:18:12,330::Spy::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2012-01-05 19:18:12,331::Spy::WARNING::Axis._sendCmd(): axis 2 can't sent command. Retrying...
2012-01-05 19:18:19,069::Spy::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2012-01-05 19:18:19,070::Spy::WARNING::Axis._sendCmd(): axis 2 can't sent command. Retrying...
2012-01-05 19:18:20,574::Spy::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2012-01-05 19:18:20,576::Spy::WARNING::Axis._sendCmd(): axis 2 can't sent command. Retrying...
2012-01-05 19:18:25,082::Spy::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2012-01-05 19:18:25,083::Spy::WARNING::Axis._sendCmd(): axis 2 can't sent command. Retrying...
2012-01-05 19:18:27,493::Shooting::INFO::Start shooting process...
2012-01-05 19:18:27,509::Shooting::INFO::Moving
2012-01-05 19:18:27,790::Shooting::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2012-01-05 19:18:27,791::Shooting::WARNING::Axis._sendCmd(): axis 1 can't sent command. Retrying...
2012-01-05 19:18:28,031::Shooting::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2012-01-05 19:18:28,032::Shooting::WARNING::Axis._sendCmd(): axis 1 can't sent command. Retrying...
2012-01-05 19:18:28,272::Shooting::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2012-01-05 19:18:28,273::Shooting::WARNING::Axis._sendCmd(): axis 1 can't sent command. Retrying...
2012-01-05 19:18:28,539::Shooting::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2012-01-05 19:18:28,540::Shooting::WARNING::Axis._sendCmd(): axis 1 can't sent command. Retrying...
2012-01-05 19:18:29,019::Shooting::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2012-01-05 19:18:29,020::Shooting::WARNING::Axis._sendCmd(): axis 1 can't sent command. Retrying...
2012-01-05 19:18:29,287::Shooting::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2012-01-05 19:18:29,287::Shooting::WARNING::Axis._sendCmd(): axis 1 can't sent command. Retrying...
2012-01-05 19:18:29,555::Spy::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2012-01-05 19:18:29,555::Spy::WARNING::Axis._sendCmd(): axis 2 can't sent command. Retrying...
2012-01-05 19:18:29,773::Shooting::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2012-01-05 19:18:29,774::Shooting::WARNING::Axis._sendCmd(): axis 1 can't sent command. Retrying...
2012-01-05 19:18:30,029::Shooting::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2012-01-05 19:18:30,030::Shooting::WARNING::Axis._sendCmd(): axis 1 can't sent command. Retrying...
2012-01-05 19:18:30,296::Spy::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2012-01-05 19:18:30,297::Spy::WARNING::Axis._sendCmd(): axis 1 can't sent command. Retrying...
2012-01-05 19:18:30,529::Shooting::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2012-01-05 19:18:30,530::Shooting::WARNING::Axis._sendCmd(): axis 2 can't sent command. Retrying...
2012-01-05 19:18:30,770::Spy::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2012-01-05 19:18:30,771::Spy::WARNING::Axis._sendCmd(): axis 2 can't sent command. Retrying...
2012-01-05 19:18:31,037::Spy::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2012-01-05 19:18:31,038::Spy::WARNING::Axis._sendCmd(): axis 2 can't sent command. Retrying...
2012-01-05 19:18:31,304::Shooting::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2012-01-05 19:18:31,305::Shooting::WARNING::Axis._sendCmd(): axis 2 can't sent command. Retrying...
2012-01-05 19:18:31,521::Shooting::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2012-01-05 19:18:31,522::Shooting::WARNING::Axis._sendCmd(): axis 2 can't sent command. Retrying...
2012-01-05 19:18:31,806::Spy::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2012-01-05 19:18:31,807::Spy::WARNING::Axis._sendCmd(): axis 1 can't sent command. Retrying...
2012-01-05 19:18:32,042::Shooting::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2012-01-05 19:18:32,043::Shooting::WARNING::Axis._sendCmd(): axis 2 can't sent command. Retrying...
2012-01-05 19:18:32,290::Shooting::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2012-01-05 19:18:32,290::Shooting::WARNING::Axis._sendCmd(): axis 2 can't sent command. Retrying...
2012-01-05 19:18:32,330::Shooting::EXCEPTION::Shooting.start()Traceback (most recent call last):  File "papywizard/model/shooting.pyc", line 540, in start  File "papywizard/hardware/head.pyc", line 156, in gotoPosition  File "papywizard/hardware/axis.pyc", line 296, in drive  File "papywizard/hardware/axis.pyc", line 316, in _driveWithInternalClosedLoop  File "papywizard/hardware/axis.pyc", line 243, in _sendCmdHardwareError: Axis 1 can't send command
2012-01-05 19:18:32,331::Shooting::WARNING::Shooting.start(): position index=1, yaw=0.0, pitch=0.0 out of limits
2012-01-05 19:18:32,347::Shooting::INFO::Moving
2012-01-05 19:18:32,534::Spy::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2012-01-05 19:18:32,534::Spy::WARNING::Axis._sendCmd(): axis 2 can't sent command. Retrying...
2012-01-05 19:18:32,774::Spy::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2012-01-05 19:18:32,776::Spy::WARNING::Axis._sendCmd(): axis 2 can't sent command. Retrying...
2012-01-05 19:18:33,041::Spy::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2012-01-05 19:18:33,042::Spy::WARNING::Axis._sendCmd(): axis 2 can't sent command. Retrying...
2012-01-05 19:18:33,043::Spy::EXCEPTION::Spy.refresh(): can't read positionTraceback (most recent call last):  File "papywizard/controller/spy.pyc", line 157, in refresh  File "papywizard/hardware/head.pyc", line 150, in readPosition  File "papywizard/hardware/axis.pyc", line 273, in read  File "papywizard/hardware/axis.pyc", line 243, in _sendCmdHardwareError: Axis 2 can't send command
2012-01-05 19:18:33,307::Shooting::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2012-01-05 19:18:33,308::Shooting::WARNING::Axis._sendCmd(): axis 1 can't sent command. Retrying...
2012-01-05 19:18:33,526::Shooting::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2012-01-05 19:18:33,527::Shooting::WARNING::Axis._sendCmd(): axis 1 can't sent command. Retrying...
2012-01-05 19:18:33,792::Shooting::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2012-01-05 19:18:33,793::Shooting::WARNING::Axis._sendCmd(): axis 1 can't sent command. Retrying...
2012-01-05 19:18:34,035::Shooting::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2012-01-05 19:18:34,036::Shooting::WARNING::Axis._sendCmd(): axis 1 can't sent command. Retrying...
2012-01-05 19:18:34,286::Shooting::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2012-01-05 19:18:34,286::Shooting::WARNING::Axis._sendCmd(): axis 1 can't sent command. Retrying...
2012-01-05 19:18:34,527::Shooting::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2012-01-05 19:18:34,528::Shooting::WARNING::Axis._sendCmd(): axis 2 can't sent command. Retrying...
2012-01-05 19:18:34,795::Shooting::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2012-01-05 19:18:34,796::Shooting::WARNING::Axis._sendCmd(): axis 2 can't sent command. Retrying...
2012-01-05 19:18:35,038::Spy::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2012-01-05 19:18:35,039::Spy::WARNING::Axis._sendCmd(): axis 1 can't sent command. Retrying...
2012-01-05 19:18:35,281::Spy::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2012-01-05 19:18:35,281::Spy::WARNING::Axis._sendCmd(): axis 1 can't sent command. Retrying...
2012-01-05 19:18:35,530::Shooting::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2012-01-05 19:18:35,531::Shooting::WARNING::Axis._sendCmd(): axis 2 can't sent command. Retrying...
2012-01-05 19:18:35,772::Shooting::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2012-01-05 19:18:35,772::Shooting::WARNING::Axis._sendCmd(): axis 2 can't sent command. Retrying...
2012-01-05 19:18:36,037::Shooting::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2012-01-05 19:18:36,037::Shooting::WARNING::Axis._sendCmd(): axis 2 can't sent command. Retrying...
2012-01-05 19:18:36,277::Spy::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2012-01-05 19:18:36,278::Spy::WARNING::Axis._sendCmd(): axis 2 can't sent command. Retrying...
2012-01-05 19:18:36,521::Shooting::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2012-01-05 19:18:36,522::Shooting::WARNING::Axis._sendCmd(): axis 1 can't sent command. Retrying...
2012-01-05 19:18:36,798::Shooting::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2012-01-05 19:18:36,798::Shooting::WARNING::Axis._sendCmd(): axis 1 can't sent command. Retrying...
2012-01-05 19:18:37,065::Spy::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2012-01-05 19:18:37,066::Spy::WARNING::Axis._sendCmd(): axis 1 can't sent command. Retrying...
2012-01-05 19:18:37,282::Shooting::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2012-01-05 19:18:37,283::Shooting::WARNING::Axis._sendCmd(): axis 1 can't sent command. Retrying...
2012-01-05 19:18:37,540::Shooting::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2012-01-05 19:18:37,541::Shooting::WARNING::Axis._sendCmd(): axis 1 can't sent command. Retrying...
2012-01-05 19:18:37,783::Spy::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2012-01-05 19:18:37,783::Spy::WARNING::Axis._sendCmd(): axis 2 can't sent command. Retrying...
2012-01-05 19:18:38,030::Spy::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2012-01-05 19:18:38,030::Spy::WARNING::Axis._sendCmd(): axis 2 can't sent command. Retrying...
2012-01-05 19:18:38,271::Shooting::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2012-01-05 19:18:38,271::Shooting::WARNING::Axis._sendCmd(): axis 2 can't sent command. Retrying...
2012-01-05 19:18:38,538::Shooting::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2012-01-05 19:18:38,538::Shooting::WARNING::Axis._sendCmd(): axis 2 can't sent command. Retrying...
2012-01-05 19:18:38,804::Shooting::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2012-01-05 19:18:38,804::Shooting::WARNING::Axis._sendCmd(): axis 2 can't sent command. Retrying...
2012-01-05 19:18:39,022::Spy::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2012-01-05 19:18:39,023::Spy::WARNING::Axis._sendCmd(): axis 1 can't sent command. Retrying...
2012-01-05 19:18:39,288::Spy::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2012-01-05 19:18:39,288::Spy::WARNING::Axis._sendCmd(): axis 1 can't sent command. Retrying...
2012-01-05 19:18:39,531::Shooting::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2012-01-05 19:18:39,532::Shooting::WARNING::Axis._sendCmd(): axis 2 can't sent command. Retrying...
2012-01-05 19:18:39,574::Shooting::EXCEPTION::Shooting.start()Traceback (most recent call last):  File "papywizard/model/shooting.pyc", line 540, in start  File "papywizard/hardware/head.pyc", line 157, in gotoPosition  File "papywizard/hardware/axis.pyc", line 298, in drive  File "papywizard/hardware/axis.pyc", line 315, in _driveWithInternalClosedLoop  File "papywizard/hardware/axis.pyc", line 243, in _sendCmdHardwareError: Axis 2 can't send command
2012-01-05 19:18:39,574::Shooting::WARNING::Shooting.start(): position index=2, yaw=90.0, pitch=0.0 out of limits
2012-01-05 19:18:39,579::Shooting::INFO::Moving
2012-01-05 19:18:39,776::Spy::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2012-01-05 19:18:39,777::Spy::WARNING::Axis._sendCmd(): axis 2 can't sent command. Retrying...
2012-01-05 19:18:40,041::Spy::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2012-01-05 19:18:40,042::Spy::WARNING::Axis._sendCmd(): axis 2 can't sent command. Retrying...
2012-01-05 19:18:40,307::Shooting::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2012-01-05 19:18:40,308::Shooting::WARNING::Axis._sendCmd(): axis 1 can't sent command. Retrying...
2012-01-05 19:18:40,526::Shooting::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2012-01-05 19:18:40,527::Shooting::WARNING::Axis._sendCmd(): axis 1 can't sent command. Retrying...
2012-01-05 19:18:40,792::Shooting::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2012-01-05 19:18:40,793::Shooting::WARNING::Axis._sendCmd(): axis 1 can't sent command. Retrying...
2012-01-05 19:18:41,057::Shooting::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2012-01-05 19:18:41,058::Shooting::WARNING::Axis._sendCmd(): axis 1 can't sent command. Retrying...
2012-01-05 19:18:41,275::Shooting::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2012-01-05 19:18:41,275::Shooting::WARNING::Axis._sendCmd(): axis 1 can't sent command. Retrying...
2012-01-05 19:18:41,549::Shooting::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2012-01-05 19:18:41,550::Shooting::WARNING::Axis._sendCmd(): axis 1 can't sent command. Retrying...
2012-01-05 19:18:41,791::Shooting::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2012-01-05 19:18:41,792::Shooting::WARNING::Axis._sendCmd(): axis 2 can't sent command. Retrying...
2012-01-05 19:18:42,038::Shooting::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2012-01-05 19:18:42,038::Shooting::WARNING::Axis._sendCmd(): axis 2 can't sent command. Retrying...
2012-01-05 19:18:42,281::Spy::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2012-01-05 19:18:42,281::Spy::WARNING::Axis._sendCmd(): axis 1 can't sent command. Retrying...
2012-01-05 19:18:42,523::Spy::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2012-01-05 19:18:42,523::Spy::WARNING::Axis._sendCmd(): axis 1 can't sent command. Retrying...
2012-01-05 19:18:42,790::Spy::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2012-01-05 19:18:42,790::Spy::WARNING::Axis._sendCmd(): axis 1 can't sent command. Retrying...
2012-01-05 19:18:42,791::Spy::EXCEPTION::Spy.refresh(): can't read positionTraceback (most recent call last):  File "papywizard/controller/spy.pyc", line 157, in refresh  File "papywizard/hardware/head.pyc", line 149, in readPosition  File "papywizard/hardware/axis.pyc", line 273, in read  File "papywizard/hardware/axis.pyc", line 243, in _sendCmdHardwareError: Axis 1 can't send command
2012-01-05 19:18:43,055::Shooting::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2012-01-05 19:18:43,056::Shooting::WARNING::Axis._sendCmd(): axis 2 can't sent command. Retrying...
2012-01-05 19:18:43,280::Shooting::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2012-01-05 19:18:43,281::Shooting::WARNING::Axis._sendCmd(): axis 2 can't sent command. Retrying...
2012-01-05 19:18:43,521::Shooting::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2012-01-05 19:18:43,522::Shooting::WARNING::Axis._sendCmd(): axis 2 can't sent command. Retrying...
2012-01-05 19:18:43,790::Shooting::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2012-01-05 19:18:43,790::Shooting::WARNING::Axis._sendCmd(): axis 2 can't sent command. Retrying...
2012-01-05 19:18:44,035::Spy::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2012-01-05 19:18:44,036::Spy::WARNING::Axis._sendCmd(): axis 2 can't sent command. Retrying...
2012-01-05 19:18:44,276::Shooting::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2012-01-05 19:18:44,276::Shooting::WARNING::Axis._sendCmd(): axis 1 can't sent command. Retrying...
2012-01-05 19:18:44,525::Shooting::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2012-01-05 19:18:44,526::Shooting::WARNING::Axis._sendCmd(): axis 1 can't sent command. Retrying...
2012-01-05 19:18:44,766::Shooting::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2012-01-05 19:18:44,767::Shooting::WARNING::Axis._sendCmd(): axis 1 can't sent command. Retrying...
2012-01-05 19:18:45,036::Shooting::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2012-01-05 19:18:45,037::Shooting::WARNING::Axis._sendCmd(): axis 1 can't sent command. Retrying...
2012-01-05 19:18:45,285::Spy::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2012-01-05 19:18:45,285::Spy::WARNING::Axis._sendCmd(): axis 1 can't sent command. Retrying...
2012-01-05 19:18:45,537::Spy::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2012-01-05 19:18:45,538::Spy::WARNING::Axis._sendCmd(): axis 2 can't sent command. Retrying...
2012-01-05 19:18:45,795::Spy::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2012-01-05 19:18:45,796::Spy::WARNING::Axis._sendCmd(): axis 2 can't sent command. Retrying...
2012-01-05 19:18:46,037::Shooting::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2012-01-05 19:18:46,038::Shooting::WARNING::Axis._sendCmd(): axis 1 can't sent command. Retrying...
2012-01-05 19:18:46,280::Shooting::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2012-01-05 19:18:46,280::Shooting::WARNING::Axis._sendCmd(): axis 1 can't sent command. Retrying...
2012-01-05 19:18:46,523::Shooting::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2012-01-05 19:18:46,524::Shooting::WARNING::Axis._sendCmd(): axis 1 can't sent command. Retrying...
2012-01-05 19:18:46,791::Shooting::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2012-01-05 19:18:46,792::Shooting::WARNING::Axis._sendCmd(): axis 1 can't sent command. Retrying...
2012-01-05 19:18:47,040::Spy::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2012-01-05 19:18:47,041::Spy::WARNING::Axis._sendCmd(): axis 1 can't sent command. Retrying...
2012-01-05 19:18:47,282::Shooting::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2012-01-05 19:18:47,283::Shooting::WARNING::Axis._sendCmd(): axis 1 can't sent command. Retrying...
2012-01-05 19:18:47,526::Shooting::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2012-01-05 19:18:47,526::Shooting::WARNING::Axis._sendCmd(): axis 1 can't sent command. Retrying...
2012-01-05 19:18:47,772::Shooting::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2012-01-05 19:18:47,773::Shooting::WARNING::Axis._sendCmd(): axis 1 can't sent command. Retrying...
2012-01-05 19:18:47,774::Shooting::EXCEPTION::Shooting.start()Traceback (most recent call last):  File "papywizard/model/shooting.pyc", line 619, in start  File "papywizard/hardware/head.pyc", line 194, in stopAxis  File "papywizard/hardware/axis.pyc", line 373, in stop  File "papywizard/hardware/axis.pyc", line 402, in waitStop  File "papywizard/hardware/axis.pyc", line 273, in read  File "papywizard/hardware/axis.pyc", line 243, in _sendCmdHardwareError: Axis 1 can't send command
2012-01-05 19:18:47,774::Shooting::ERROR::Shoot process failed
2012-01-05 19:18:53,075::Spy::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2012-01-05 19:18:53,076::Spy::WARNING::Axis._sendCmd(): axis 2 can't sent command. Retrying...
2012-01-05 19:18:54,585::Spy::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2012-01-05 19:18:54,586::Spy::WARNING::Axis._sendCmd(): axis 2 can't sent command. Retrying...
