Papywizard Fail on shooting
caretaker360
by caretaker360 » Thu Dec 29, 2011 9:54 pm
PW v2.0.0-1 on Win XP and an Asus EeePc
Everything workds as it should except if I enable the data option, I get a Fail as soon as I try to shoot. If the data option is off, it will shoot correctly. I made sure the path to the saving file was ok. Checked the time/date formats were correct. I uninstalled /reinstalled PW, same with the BT dongle.
I am at a loss. Only thing I can think of is that the EeePc is on a french version of the OS (should not make a difference). Here is the log :
2011-12-29 15:05:49,437::MainThread::DEBUG::PresetScan.generatePositions(): preset=<Preset name=3@-15 + Z>
2011-12-29 15:05:49,437::MainThread::DEBUG::ShootController._initWidgets()Traceback (most recent call last):  File "papywizard\controller\shootController.pyo", line 147, in _initWidgets  File "papywizard\model\scan.pyo", line 104, in _setIndexIndexError: position index out of range
2011-12-29 15:05:51,937::Shooting::INFO::Start shooting process...
2011-12-29 15:05:51,937::Shooting::DEBUG::Shooting.start(): create preset data object
2011-12-29 15:05:51,937::Shooting::DEBUG::Data.__init__(): create xml tree
2011-12-29 15:05:51,937::Shooting::DEBUG::Data.createHeader(): values={'comment': u'G\xe9n\xe9r\xe9 par Papywizard 2.0.0', 'cameraOrientation': u'portrait', 'name': u'3@-15 + Z', 'title': u'photo360', 'bracketingNbPicts': '1', 'timeValue': '0.5', 'stabilizationDelay': '0.5', 'headOrientation': 'up', 'lensType': u'rectilinear', 'focal': '20.0', 'sensorCoef': '1.6', 'sensorRatio': u'3:2', 'roll': '90.0', 'bracketingIntent': u'exposure', 'gps': u'Here goes the location'}
2011-12-29 15:05:51,937::Shooting::DEBUG::Data._addNode(): parent=header, tag=general, value=None, attr={}
2011-12-29 15:05:51,937::Shooting::DEBUG::Data._addNode(): parent=general, tag=title, value=photo360, attr={}
2011-12-29 15:05:51,937::Shooting::DEBUG::Data._addNode(): parent=general, tag=gps, value=Here goes the location, attr={}
2011-12-29 15:05:51,937::Shooting::DEBUG::Data._addNode(): parent=general, tag=comment, value=Généré par Papywizard 2.0.0, attr={}
2011-12-29 15:05:51,937::Shooting::DEBUG::Data._addNode(): parent=header, tag=shooting, value=None, attr={'mode': 'preset'}
2011-12-29 15:05:51,937::Shooting::DEBUG::Data._addNode(): parent=shooting, tag=headOrientation, value=up, attr={}
2011-12-29 15:05:51,953::Shooting::DEBUG::Data._addNode(): parent=shooting, tag=cameraOrientation, value=portrait, attr={}
2011-12-29 15:05:51,953::Shooting::DEBUG::Data._addNode(): parent=shooting, tag=stabilizationDelay, value=0.5, attr={}
2011-12-29 15:05:51,953::Shooting::DEBUG::Data._addNode(): parent=shooting, tag=startTime, value=2011-12-29_15h05m51s, attr={}
2011-12-29 15:05:51,953::Shooting::DEBUG::Data._addNode(): parent=shooting, tag=endTime, value=2011-12-29_15h05m51s, attr={}
2011-12-29 15:05:51,953::Shooting::DEBUG::Data._addNode(): parent=header, tag=camera, value=None, attr={}
2011-12-29 15:05:51,953::Shooting::DEBUG::Data._addNode(): parent=camera, tag=timeValue, value=0.5, attr={}
2011-12-29 15:05:51,953::Shooting::DEBUG::Data._addNode(): parent=camera, tag=bracketing, value=None, attr={'nbPicts': '1', 'intent': u'exposure'}
2011-12-29 15:05:51,953::Shooting::DEBUG::Data._addNode(): parent=camera, tag=sensor, value=None, attr={'ratio': u'3:2', 'coef': '1.6'}
2011-12-29 15:05:51,953::Shooting::DEBUG::Data._addNode(): parent=header, tag=lens, value=None, attr={'type': u'rectilinear'}
2011-12-29 15:05:51,953::Shooting::DEBUG::Data._addNode(): parent=lens, tag=focal, value=20.0, attr={}
2011-12-29 15:05:51,953::Shooting::DEBUG::Data._addNode(): parent=header, tag=preset, value=None, attr={'name': u'3@-15 + Z'}
2011-12-29 15:05:51,967::Shooting::EXCEPTION::Shooting.start()Traceback (most recent call last):
  File "papywizard\model\shooting.pyo", line 517, in start
  File "papywizard\model\data.pyo", line 285, in createHeader
  File "papywizard\model\data.pyo", line 180, in _serialize
  File "xml\dom\minidom.pyo", line 1744, in writexml
  File "xml\dom\minidom.pyo", line 814, in writexml
  File "xml\dom\minidom.pyo", line 1033, in writexml
  File "xml\dom\minidom.pyo", line 301, in _write_dataUnicodeEncodeError: 'ascii' codec can't encode character u'\xe9' in position 17: ordinal not in range(128)
2011-12-29 15:05:51,967::Shooting::ERROR::Shoot process failed
2011-12-29 15:05:51,967::MainThread::DEBUG::ShootController.__onShootingStopped(): status=fail
Thanks guys, BTW Happy Holidays to all :cool:
Christian
Montreal
Evolution invented panoramic vision, Kodak invented the 4:3 format.
Nikon D2x, 7000. Glass: 10.5 fe, 14mm asph, 20 , 50, 105, 24-120, 70-200
Panogear, BT dongel , Nokia n800 , PC's on W7 ..... now that I look at this, everything but time!
by fma38 » Thu Dec 29, 2011 11:19 pm
Yes, I think the problem comes from the 'Généré' word, which contents some non ascii chars. I suggest you don't use this release, which is not really stable; try the latest dev. one (2.1.21), which is much better ;)
caretaker360
by caretaker360 » Fri Dec 30, 2011 5:53 am
Merci ! Je test ça vendredi matin :-)
caretaker360
by caretaker360 » Sat Dec 31, 2011 2:08 am
Eureka ! 2.1.21 did the trick :)
Merci !
by fma38 » Sat Dec 31, 2011 6:06 pm
Cool :)
Joyeux réveillon !
