Cases were shooting session is terminated status displays fail
mamoo
by mamoo » Tue Nov 15, 2011 9:16 pm
Hi Frederic
Another problem is that I experienced.
Status:
Positioning error(red indicator) often appears during the course of shooting the sequence, if I continue to regard "fail" was forced to quit shooting sequences are displayed.
Panogear CPU and is connected with a TTL cable.
CPU Bluetooth adapter was disabled.
CPU:Windows xp sp3
2011-11-14 12:37:35,015::Spy::WARNING::MerlinOrionHardware.__sendCmd(): axis 1 can't sent command ':j1\r'. Retrying...
2011-11-14 12:37:37,405::Shooting::INFO::Stabilization
2011-11-14 12:37:37,405::Main::DEBUG::ShootController.__onShootingSequence(): sequence=stabilization
2011-11-14 12:37:37,905::Shooting::INFO::Shutter cycle
2011-11-14 12:37:37,905::Shooting::DEBUG::Shooting.start(): bracket #1 of 1
2011-11-14 12:37:37,905::Main::DEBUG::ShootController.__onShootingSequence(): sequence=shutter
2011-11-14 12:37:38,467::Shooting::DEBUG::Data.addPicture(): bracket=1, yaw=-0.1, pitch=30.3, roll=0.0
2011-11-14 12:37:38,467::Shooting::DEBUG::Data._addNode(): parent=shoot, tag=pict, value=None, attr={'bracket': '1', 'id': '23'}
2011-11-14 12:37:38,467::Shooting::DEBUG::Data._addNode(): parent=pict, tag=time, value=2011-11-14_12h37m38s, attr={}
2011-11-14 12:37:38,483::Shooting::DEBUG::Data._addNode(): parent=pict, tag=position, value=None, attr={'yaw': '-0.1', 'roll': '0.0', 'pitch': '30.3'}
2011-11-14 12:37:39,967::Main::DEBUG::ShootController.__onShootingUpdate(): index=(23, 5, 3), yaw=-0.1, pitch=30.3, state=ok, next=None
2011-11-14 12:37:40,015::Shooting::DEBUG::Shooting.start(): position index=(24, 6, 3), yaw=8.6, pitch=30.3
2011-11-14 12:37:40,030::Main::DEBUG::ShootController.__onShootingUpdate(): index=(24, 6, 3), yaw=8.6, pitch=30.3, state=None, next=True
2011-11-14 12:37:40,092::Shooting::DEBUG::Shooting.start(): pict #24 of 72, index=(24, 6, 3), yaw=8.6, pitch=30.3
2011-11-14 12:37:40,092::Main::DEBUG::ShootController.__onShootingUpdate(): index=(24, 6, 3), yaw=8.6, pitch=30.3, state=None, next=True
2011-11-14 12:37:40,125::Shooting::INFO::Moving
2011-11-14 12:37:40,125::Main::DEBUG::ShootController.__onShootingSequence(): sequence=moving
2011-11-14 12:37:40,125::Shooting::DEBUG::MerlinOrionAxis.drive(): 'yawAxis' drive to 8.6
2011-11-14 12:37:40,155::Shooting::DEBUG::MerlinOrionAxis.drive(): 'pitchAxis' drive to -30.3
2011-11-14 12:37:44,140::Shooting::EXCEPTION::MerlinOrionHardware.__sendCmd
  File "papywizard\hardware\merlinOrionHardware.pyo", line 145, in __sendCmd
  File "papywizard\driver\serialDriver.pyo", line 115, in read
IOError: Timeout while reading on serial bus (size=1, data='')
2011-11-14 12:37:44,140::Shooting::WARNING::MerlinOrionHardware.__sendCmd(): axis 1 can't sent command ':f1\r'. Retrying...
2011-11-14 12:37:46,296::Shooting::INFO::Stabilization
2011-11-14 12:37:46,296::Main::DEBUG::ShootController.__onShootingSequence(): sequence=stabilization
2011-11-14 12:37:46,796::Shooting::INFO::Shutter cycle
2011-11-14 12:37:46,796::Shooting::DEBUG::Shooting.start(): bracket #1 of 1
2011-11-14 12:37:46,796::Main::DEBUG::ShootController.__onShootingSequence(): sequence=shutter
2011-11-14 12:37:47,390::Shooting::DEBUG::Data.addPicture(): bracket=1, yaw=8.6, pitch=30.3, roll=0.0
2011-11-14 12:37:47,390::Shooting::DEBUG::Data._addNode(): parent=shoot, tag=pict, value=None, attr={'bracket': '1', 'id': '24'}
2011-11-14 12:37:47,390::Shooting::DEBUG::Data._addNode(): parent=pict, tag=time, value=2011-11-14_12h37m47s, attr={}
2011-11-14 12:37:47,390::Shooting::DEBUG::Data._addNode(): parent=pict, tag=position, value=None, attr={'yaw': '8.6', 'roll': '0.0', 'pitch': '30.3'}
2011-11-14 12:37:48,905::Main::DEBUG::ShootController.__onShootingUpdate(): index=(24, 6, 3), yaw=8.6, pitch=30.3, state=ok, next=None
2011-11-14 12:37:48,953::Shooting::DEBUG::Shooting.start(): position index=(25, 7, 3), yaw=17.2, pitch=30.3
2011-11-14 12:37:48,953::Main::DEBUG::ShootController.__onShootingUpdate(): index=(25, 7, 3), yaw=17.2, pitch=30.3, state=None, next=True
2011-11-14 12:37:49,015::Shooting::DEBUG::Shooting.start(): pict #25 of 72, index=(25, 7, 3), yaw=17.2, pitch=30.3
2011-11-14 12:37:49,015::Main::DEBUG::ShootController.__onShootingUpdate(): index=(25, 7, 3), yaw=17.2, pitch=30.3, state=None, next=True
2011-11-14 12:37:49,046::Shooting::INFO::Moving
2011-11-14 12:37:49,062::Main::DEBUG::ShootController.__onShootingSequence(): sequence=moving
2011-11-14 12:37:49,062::Shooting::DEBUG::MerlinOrionAxis.drive(): 'yawAxis' drive to 17.2
2011-11-14 12:37:49,078::Shooting::DEBUG::MerlinOrionAxis.drive(): 'pitchAxis' drive to -30.3
2011-11-14 12:37:55,125::Shooting::INFO::Stabilization
2011-11-14 12:37:55,125::Main::DEBUG::ShootController.__onShootingSequence(): sequence=stabilization
2011-11-14 12:37:55,625::Shooting::INFO::Shutter cycle
2011-11-14 12:37:55,625::Shooting::DEBUG::Shooting.start(): bracket #1 of 1
2011-11-14 12:37:55,625::Main::DEBUG::ShootController.__onShootingSequence(): sequence=shutter
2011-11-14 12:37:56,217::Shooting::DEBUG::Data.addPicture(): bracket=1, yaw=17.2, pitch=30.3, roll=0.0
2011-11-14 12:37:56,217::Shooting::DEBUG::Data._addNode(): parent=shoot, tag=pict, value=None, attr={'bracket': '1', 'id': '25'}
2011-11-14 12:37:56,217::Shooting::DEBUG::Data._addNode(): parent=pict, tag=time, value=2011-11-14_12h37m56s, attr={}
2011-11-14 12:37:56,217::Shooting::DEBUG::Data._addNode(): parent=pict, tag=position, value=None, attr={'yaw': '17.2', 'roll': '0.0', 'pitch': '30.3'}
2011-11-14 12:37:57,733::Main::DEBUG::ShootController.__onShootingUpdate(): index=(25, 7, 3), yaw=17.2, pitch=30.3, state=ok, next=None
2011-11-14 12:37:57,780::Shooting::DEBUG::Shooting.start(): position index=(26, 8, 3), yaw=25.9, pitch=30.3
2011-11-14 12:37:57,780::Main::DEBUG::ShootController.__onShootingUpdate(): index=(26, 8, 3), yaw=25.9, pitch=30.3, state=None, next=True
2011-11-14 12:37:57,842::Shooting::DEBUG::Shooting.start(): pict #26 of 72, index=(26, 8, 3), yaw=25.9, pitch=30.3
2011-11-14 12:37:57,842::Main::DEBUG::ShootController.__onShootingUpdate(): index=(26, 8, 3), yaw=25.9, pitch=30.3, state=None, next=True
2011-11-14 12:37:57,875::Shooting::INFO::Moving
2011-11-14 12:37:57,875::Main::DEBUG::ShootController.__onShootingSequence(): sequence=moving
2011-11-14 12:37:57,875::Shooting::DEBUG::MerlinOrionAxis.drive(): 'yawAxis' drive to 25.9
2011-11-14 12:37:57,905::Shooting::DEBUG::MerlinOrionAxis.drive(): 'pitchAxis' drive to -30.3
2011-11-14 12:38:03,921::Shooting::INFO::Stabilization
2011-11-14 12:38:03,921::Main::DEBUG::ShootController.__onShootingSequence(): sequence=stabilization
2011-11-14 12:38:04,421::Shooting::INFO::Shutter cycle
2011-11-14 12:38:04,421::Shooting::DEBUG::Shooting.start(): bracket #1 of 1
2011-11-14 12:38:04,421::Main::DEBUG::ShootController.__onShootingSequence(): sequence=shutter
2011-11-14 12:38:05,030::Shooting::DEBUG::Data.addPicture(): bracket=1, yaw=25.9, pitch=30.3, roll=0.0
2011-11-14 12:38:05,030::Shooting::DEBUG::Data._addNode(): parent=shoot, tag=pict, value=None, attr={'bracket': '1', 'id': '26'}
2011-11-14 12:38:05,030::Shooting::DEBUG::Data._addNode(): parent=pict, tag=time, value=2011-11-14_12h38m05s, attr={}
2011-11-14 12:38:05,030::Shooting::DEBUG::Data._addNode(): parent=pict, tag=position, value=None, attr={'yaw': '25.9', 'roll': '0.0', 'pitch': '30.3'}
2011-11-14 12:38:06,546::Main::DEBUG::ShootController.__onShootingUpdate(): index=(26, 8, 3), yaw=25.9, pitch=30.3, state=ok, next=None
2011-11-14 12:38:06,592::Shooting::DEBUG::Shooting.start(): position index=(27, 9, 3), yaw=34.6, pitch=30.3
2011-11-14 12:38:06,608::Main::DEBUG::ShootController.__onShootingUpdate(): index=(27, 9, 3), yaw=34.6, pitch=30.3, state=None, next=True
2011-11-14 12:38:06,655::Shooting::DEBUG::Shooting.start(): pict #27 of 72, index=(27, 9, 3), yaw=34.6, pitch=30.3
2011-11-14 12:38:06,671::Main::DEBUG::ShootController.__onShootingUpdate(): index=(27, 9, 3), yaw=34.6, pitch=30.3, state=None, next=True
2011-11-14 12:38:06,687::Shooting::INFO::Moving
2011-11-14 12:38:06,703::Main::DEBUG::ShootController.__onShootingSequence(): sequence=moving
2011-11-14 12:38:06,703::Shooting::DEBUG::MerlinOrionAxis.drive(): 'yawAxis' drive to 34.6
2011-11-14 12:38:06,717::Shooting::DEBUG::MerlinOrionAxis.drive(): 'pitchAxis' drive to -30.3
2011-11-14 12:38:11,937::Spy::EXCEPTION::Spy.refresh(): can't read position
  File "papywizard\controller\spy.pyo", line 131, in refresh
  File "papywizard\model\head.pyo", line 155, in readPosition
  File "papywizard\plugins\merlinOrionPlugins.pyo", line 204, in read
  File "papywizard\hardware\merlinOrionHardware.pyo", line 210, in read
  File "papywizard\hardware\merlinOrionHardware.pyo", line 84, in __decodeAxisValue
  File "<string>", line 1
     0xD?
 SyntaxError: unexpected EOF while parsing
2011-11-14 12:38:12,703::Shooting::INFO::Stabilization
2011-11-14 12:38:12,703::Main::DEBUG::ShootController.__onShootingSequence(): sequence=stabilization
2011-11-14 12:38:13,203::Shooting::INFO::Shutter cycle
2011-11-14 12:38:13,203::Shooting::DEBUG::Shooting.start(): bracket #1 of 1
2011-11-14 12:38:13,203::Main::DEBUG::ShootController.__onShootingSequence(): sequence=shutter
2011-11-14 12:38:13,812::Shooting::DEBUG::Data.addPicture(): bracket=1, yaw=34.6, pitch=30.3, roll=0.0
2011-11-14 12:38:13,812::Shooting::DEBUG::Data._addNode(): parent=shoot, tag=pict, value=None, attr={'bracket': '1', 'id': '27'}
2011-11-14 12:38:13,812::Shooting::DEBUG::Data._addNode(): parent=pict, tag=time, value=2011-11-14_12h38m13s, attr={}
2011-11-14 12:38:13,812::Shooting::DEBUG::Data._addNode(): parent=pict, tag=position, value=None, attr={'yaw': '34.6', 'roll': '0.0', 'pitch': '30.3'}
2011-11-14 12:38:15,328::Main::DEBUG::ShootController.__onShootingUpdate(): index=(27, 9, 3), yaw=34.6, pitch=30.3, state=ok, next=None
2011-11-14 12:38:15,375::Shooting::DEBUG::Shooting.start(): position index=(28, 9, 4), yaw=34.6, pitch=24.2
2011-11-14 12:38:15,375::Main::DEBUG::ShootController.__onShootingUpdate(): index=(28, 9, 4), yaw=34.6, pitch=24.2, state=None, next=True
2011-11-14 12:38:15,437::Shooting::DEBUG::Shooting.start(): pict #28 of 72, index=(28, 9, 4), yaw=34.6, pitch=24.2
2011-11-14 12:38:15,437::Main::DEBUG::ShootController.__onShootingUpdate(): index=(28, 9, 4), yaw=34.6, pitch=24.2, state=None, next=True
2011-11-14 12:38:15,467::Shooting::INFO::Moving
2011-11-14 12:38:15,467::Main::DEBUG::ShootController.__onShootingSequence(): sequence=moving
2011-11-14 12:38:15,467::Shooting::DEBUG::MerlinOrionAxis.drive(): 'yawAxis' drive to 34.6
2011-11-14 12:38:15,500::Shooting::DEBUG::MerlinOrionAxis.drive(): 'pitchAxis' drive to -24.2
2011-11-14 12:38:21,265::Shooting::INFO::Stabilization
2011-11-14 12:38:21,265::Main::DEBUG::ShootController.__onShootingSequence(): sequence=stabilization
2011-11-14 12:38:21,765::Shooting::INFO::Shutter cycle
2011-11-14 12:38:21,765::Shooting::DEBUG::Shooting.start(): bracket #1 of 1
2011-11-14 12:38:21,765::Main::DEBUG::ShootController.__onShootingSequence(): sequence=shutter
2011-11-14 12:38:22,358::Shooting::DEBUG::Data.addPicture(): bracket=1, yaw=34.6, pitch=24.3, roll=0.0
2011-11-14 12:38:22,358::Shooting::DEBUG::Data._addNode(): parent=shoot, tag=pict, value=None, attr={'bracket': '1', 'id': '28'}
2011-11-14 12:38:22,358::Shooting::DEBUG::Data._addNode(): parent=pict, tag=time, value=2011-11-14_12h38m22s, attr={}
2011-11-14 12:38:22,358::Shooting::DEBUG::Data._addNode(): parent=pict, tag=position, value=None, attr={'yaw': '34.6', 'roll': '0.0', 'pitch': '24.3'}
2011-11-14 12:38:23,875::Main::DEBUG::ShootController.__onShootingUpdate(): index=(28, 9, 4), yaw=34.6, pitch=24.2, state=ok, next=None
2011-11-14 12:38:23,921::Shooting::DEBUG::Shooting.start(): position index=(29, 8, 4), yaw=25.9, pitch=24.2
2011-11-14 12:38:23,921::Main::DEBUG::ShootController.__onShootingUpdate(): index=(29, 8, 4), yaw=25.9, pitch=24.2, state=None, next=True
2011-11-14 12:38:23,983::Shooting::DEBUG::Shooting.start(): pict #29 of 72, index=(29, 8, 4), yaw=25.9, pitch=24.2
2011-11-14 12:38:23,983::Main::DEBUG::ShootController.__onShootingUpdate(): index=(29, 8, 4), yaw=25.9, pitch=24.2, state=None, next=True
2011-11-14 12:38:24,015::Shooting::INFO::Moving
2011-11-14 12:38:24,015::Main::DEBUG::ShootController.__onShootingSequence(): sequence=moving
2011-11-14 12:38:24,030::Shooting::DEBUG::MerlinOrionAxis.drive(): 'yawAxis' drive to 25.9
2011-11-14 12:38:24,046::Shooting::DEBUG::MerlinOrionAxis.drive(): 'pitchAxis' drive to -24.2
2011-11-14 12:38:30,046::Shooting::INFO::Stabilization
2011-11-14 12:38:30,046::Main::DEBUG::ShootController.__onShootingSequence(): sequence=stabilization
2011-11-14 12:38:30,546::Shooting::INFO::Shutter cycle
2011-11-14 12:38:30,546::Shooting::DEBUG::Shooting.start(): bracket #1 of 1
2011-11-14 12:38:30,546::Main::DEBUG::ShootController.__onShootingSequence(): sequence=shutter
2011-11-14 12:38:31,140::Shooting::DEBUG::Data.addPicture(): bracket=1, yaw=25.9, pitch=24.3, roll=0.0
2011-11-14 12:38:31,140::Shooting::DEBUG::Data._addNode(): parent=shoot, tag=pict, value=None, attr={'bracket': '1', 'id': '29'}
2011-11-14 12:38:31,140::Shooting::DEBUG::Data._addNode(): parent=pict, tag=time, value=2011-11-14_12h38m31s, attr={}
2011-11-14 12:38:31,140::Shooting::DEBUG::Data._addNode(): parent=pict, tag=position, value=None, attr={'yaw': '25.9', 'roll': '0.0', 'pitch': '24.3'}
2011-11-14 12:38:32,640::Main::DEBUG::ShootController.__onShootingUpdate(): index=(29, 8, 4), yaw=25.9, pitch=24.2, state=ok, next=None
2011-11-14 12:38:32,687::Shooting::DEBUG::Shooting.start(): position index=(30, 7, 4), yaw=17.2, pitch=24.2
2011-11-14 12:38:32,687::Main::DEBUG::ShootController.__onShootingUpdate(): index=(30, 7, 4), yaw=17.2, pitch=24.2, state=None, next=True
2011-11-14 12:38:32,750::Shooting::DEBUG::Shooting.start(): pict #30 of 72, index=(30, 7, 4), yaw=17.2, pitch=24.2
2011-11-14 12:38:32,750::Main::DEBUG::ShootController.__onShootingUpdate(): index=(30, 7, 4), yaw=17.2, pitch=24.2, state=None, next=True
2011-11-14 12:38:32,780::Shooting::INFO::Moving
2011-11-14 12:38:32,780::Main::DEBUG::ShootController.__onShootingSequence(): sequence=moving
2011-11-14 12:38:32,796::Shooting::DEBUG::MerlinOrionAxis.drive(): 'yawAxis' drive to 17.2
2011-11-14 12:38:32,842::Shooting::DEBUG::MerlinOrionAxis.drive(): 'pitchAxis' drive to -24.2
2011-11-14 12:38:38,890::Shooting::INFO::Stabilization
2011-11-14 12:38:38,890::Main::DEBUG::ShootController.__onShootingSequence(): sequence=stabilization
2011-11-14 12:38:39,390::Shooting::INFO::Shutter cycle
2011-11-14 12:38:39,390::Shooting::DEBUG::Shooting.start(): bracket #1 of 1
2011-11-14 12:38:39,390::Main::DEBUG::ShootController.__onShootingSequence(): sequence=shutter
2011-11-14 12:38:40,000::Shooting::DEBUG::Data.addPicture(): bracket=1, yaw=17.3, pitch=24.3, roll=0.0
2011-11-14 12:38:40,000::Shooting::DEBUG::Data._addNode(): parent=shoot, tag=pict, value=None, attr={'bracket': '1', 'id': '30'}
2011-11-14 12:38:40,000::Shooting::DEBUG::Data._addNode(): parent=pict, tag=time, value=2011-11-14_12h38m40s, attr={}
2011-11-14 12:38:40,015::Shooting::DEBUG::Data._addNode(): parent=pict, tag=position, value=None, attr={'yaw': '17.3', 'roll': '0.0', 'pitch': '24.3'}
2011-11-14 12:38:41,530::Main::DEBUG::ShootController.__onShootingUpdate(): index=(30, 7, 4), yaw=17.2, pitch=24.2, state=ok, next=None
2011-11-14 12:38:41,578::Shooting::DEBUG::Shooting.start(): position index=(31, 6, 4), yaw=8.6, pitch=24.2
2011-11-14 12:38:41,578::Main::DEBUG::ShootController.__onShootingUpdate(): index=(31, 6, 4), yaw=8.6, pitch=24.2, state=None, next=True
2011-11-14 12:38:41,640::Shooting::DEBUG::Shooting.start(): pict #31 of 72, index=(31, 6, 4), yaw=8.6, pitch=24.2
2011-11-14 12:38:41,640::Main::DEBUG::ShootController.__onShootingUpdate(): index=(31, 6, 4), yaw=8.6, pitch=24.2, state=None, next=True
2011-11-14 12:38:41,671::Shooting::INFO::Moving
2011-11-14 12:38:41,671::Main::DEBUG::ShootController.__onShootingSequence(): sequence=moving
2011-11-14 12:38:41,687::Shooting::DEBUG::MerlinOrionAxis.drive(): 'yawAxis' drive to 8.6
2011-11-14 12:38:41,717::Shooting::DEBUG::MerlinOrionAxis.drive(): 'pitchAxis' drive to -24.2
2011-11-14 12:38:47,703::Shooting::INFO::Stabilization
2011-11-14 12:38:47,703::Main::DEBUG::ShootController.__onShootingSequence(): sequence=stabilization
2011-11-14 12:38:48,203::Shooting::INFO::Shutter cycle
2011-11-14 12:38:48,203::Shooting::DEBUG::Shooting.start(): bracket #1 of 1
2011-11-14 12:38:48,203::Main::DEBUG::ShootController.__onShootingSequence(): sequence=shutter
2011-11-14 12:38:48,780::Shooting::DEBUG::Data.addPicture(): bracket=1, yaw=8.6, pitch=24.3, roll=0.0
2011-11-14 12:38:48,780::Shooting::DEBUG::Data._addNode(): parent=shoot, tag=pict, value=None, attr={'bracket': '1', 'id': '31'}
2011-11-14 12:38:48,780::Shooting::DEBUG::Data._addNode(): parent=pict, tag=time, value=2011-11-14_12h38m48s, attr={}
2011-11-14 12:38:48,796::Shooting::DEBUG::Data._addNode(): parent=pict, tag=position, value=None, attr={'yaw': '8.6', 'roll': '0.0', 'pitch': '24.3'}
2011-11-14 12:38:50,437::Main::DEBUG::ShootController.__onShootingUpdate(): index=(31, 6, 4), yaw=8.6, pitch=24.2, state=ok, next=None
2011-11-14 12:38:50,483::Shooting::DEBUG::Shooting.start(): position index=(32, 5, 4), yaw=-0.1, pitch=24.2
2011-11-14 12:38:50,500::Main::DEBUG::ShootController.__onShootingUpdate(): index=(32, 5, 4), yaw=-0.1, pitch=24.2, state=None, next=True
2011-11-14 12:38:50,562::Shooting::DEBUG::Shooting.start(): pict #32 of 72, index=(32, 5, 4), yaw=-0.1, pitch=24.2
2011-11-14 12:38:50,562::Main::DEBUG::ShootController.__onShootingUpdate(): index=(32, 5, 4), yaw=-0.1, pitch=24.2, state=None, next=True
2011-11-14 12:38:50,592::Shooting::INFO::Moving
2011-11-14 12:38:50,592::Main::DEBUG::ShootController.__onShootingSequence(): sequence=moving
2011-11-14 12:38:50,608::Shooting::DEBUG::MerlinOrionAxis.drive(): 'yawAxis' drive to -0.1
2011-11-14 12:38:50,625::Shooting::DEBUG::MerlinOrionAxis.drive(): 'pitchAxis' drive to -24.2
2011-11-14 12:38:56,608::Shooting::INFO::Stabilization
2011-11-14 12:38:56,608::Main::DEBUG::ShootController.__onShootingSequence(): sequence=stabilization
2011-11-14 12:38:57,108::Shooting::INFO::Shutter cycle
2011-11-14 12:38:57,108::Shooting::DEBUG::Shooting.start(): bracket #1 of 1
2011-11-14 12:38:57,108::Main::DEBUG::ShootController.__onShootingSequence(): sequence=shutter
2011-11-14 12:38:57,703::Shooting::DEBUG::Data.addPicture(): bracket=1, yaw=-0.1, pitch=24.3, roll=0.0
2011-11-14 12:38:57,703::Shooting::DEBUG::Data._addNode(): parent=shoot, tag=pict, value=None, attr={'bracket': '1', 'id': '32'}
2011-11-14 12:38:57,703::Shooting::DEBUG::Data._addNode(): parent=pict, tag=time, value=2011-11-14_12h38m57s, attr={}
2011-11-14 12:38:57,703::Shooting::DEBUG::Data._addNode(): parent=pict, tag=position, value=None, attr={'yaw': '-0.1', 'roll': '0.0', 'pitch': '24.3'}
2011-11-14 12:38:59,217::Main::DEBUG::ShootController.__onShootingUpdate(): index=(32, 5, 4), yaw=-0.1, pitch=24.2, state=ok, next=None
2011-11-14 12:38:59,265::Shooting::DEBUG::Shooting.start(): position index=(33, 4, 4), yaw=-8.8, pitch=24.2
2011-11-14 12:38:59,265::Main::DEBUG::ShootController.__onShootingUpdate(): index=(33, 4, 4), yaw=-8.8, pitch=24.2, state=None, next=True
2011-11-14 12:38:59,328::Shooting::DEBUG::Shooting.start(): pict #33 of 72, index=(33, 4, 4), yaw=-8.8, pitch=24.2
2011-11-14 12:38:59,328::Main::DEBUG::ShootController.__onShootingUpdate(): index=(33, 4, 4), yaw=-8.8, pitch=24.2, state=None, next=True
2011-11-14 12:38:59,375::Shooting::INFO::Moving
2011-11-14 12:38:59,375::Main::DEBUG::ShootController.__onShootingSequence(): sequence=moving
2011-11-14 12:38:59,375::Shooting::DEBUG::MerlinOrionAxis.drive(): 'yawAxis' drive to -8.8
2011-11-14 12:38:59,421::Shooting::DEBUG::MerlinOrionAxis.drive(): 'pitchAxis' drive to -24.2
2011-11-14 12:39:05,328::Shooting::INFO::Stabilization
2011-11-14 12:39:05,328::Main::DEBUG::ShootController.__onShootingSequence(): sequence=stabilization
2011-11-14 12:39:05,828::Shooting::INFO::Shutter cycle
2011-11-14 12:39:05,828::Shooting::DEBUG::Shooting.start(): bracket #1 of 1
2011-11-14 12:39:05,828::Main::DEBUG::ShootController.__onShootingSequence(): sequence=shutter
2011-11-14 12:39:06,421::Shooting::DEBUG::Data.addPicture(): bracket=1, yaw=-8.7, pitch=24.3, roll=0.0
2011-11-14 12:39:06,421::Shooting::DEBUG::Data._addNode(): parent=shoot, tag=pict, value=None, attr={'bracket': '1', 'id': '33'}
2011-11-14 12:39:06,421::Shooting::DEBUG::Data._addNode(): parent=pict, tag=time, value=2011-11-14_12h39m06s, attr={}
2011-11-14 12:39:06,421::Shooting::DEBUG::Data._addNode(): parent=pict, tag=position, value=None, attr={'yaw': '-8.7', 'roll': '0.0', 'pitch': '24.3'}
2011-11-14 12:39:07,937::Main::DEBUG::ShootController.__onShootingUpdate(): index=(33, 4, 4), yaw=-8.8, pitch=24.2, state=ok, next=None
2011-11-14 12:39:07,983::Shooting::DEBUG::Shooting.start(): position index=(34, 3, 4), yaw=-17.4, pitch=24.2
2011-11-14 12:39:08,000::Main::DEBUG::ShootController.__onShootingUpdate(): index=(34, 3, 4), yaw=-17.4, pitch=24.2, state=None, next=True
2011-11-14 12:39:08,062::Shooting::DEBUG::Shooting.start(): pict #34 of 72, index=(34, 3, 4), yaw=-17.4, pitch=24.2
2011-11-14 12:39:08,062::Main::DEBUG::ShootController.__onShootingUpdate(): index=(34, 3, 4), yaw=-17.4, pitch=24.2, state=None, next=True
2011-11-14 12:39:08,092::Shooting::INFO::Moving
2011-11-14 12:39:08,092::Main::DEBUG::ShootController.__onShootingSequence(): sequence=moving
2011-11-14 12:39:08,092::Shooting::DEBUG::MerlinOrionAxis.drive(): 'yawAxis' drive to -17.4
2011-11-14 12:39:08,125::Shooting::DEBUG::MerlinOrionAxis.drive(): 'pitchAxis' drive to -24.2
2011-11-14 12:39:14,125::Shooting::INFO::Stabilization
2011-11-14 12:39:14,125::Main::DEBUG::ShootController.__onShootingSequence(): sequence=stabilization
2011-11-14 12:39:14,625::Shooting::INFO::Shutter cycle
2011-11-14 12:39:14,625::Shooting::DEBUG::Shooting.start(): bracket #1 of 1
2011-11-14 12:39:14,625::Main::DEBUG::ShootController.__onShootingSequence(): sequence=shutter
2011-11-14 12:39:15,217::Shooting::DEBUG::Data.addPicture(): bracket=1, yaw=-17.4, pitch=24.3, roll=0.0
2011-11-14 12:39:15,217::Shooting::DEBUG::Data._addNode(): parent=shoot, tag=pict, value=None, attr={'bracket': '1', 'id': '34'}
2011-11-14 12:39:15,217::Shooting::DEBUG::Data._addNode(): parent=pict, tag=time, value=2011-11-14_12h39m15s, attr={}
2011-11-14 12:39:15,217::Shooting::DEBUG::Data._addNode(): parent=pict, tag=position, value=None, attr={'yaw': '-17.4', 'roll': '0.0', 'pitch': '24.3'}
2011-11-14 12:39:16,733::Main::DEBUG::ShootController.__onShootingUpdate(): index=(34, 3, 4), yaw=-17.4, pitch=24.2, state=ok, next=None
2011-11-14 12:39:16,780::Shooting::DEBUG::Shooting.start(): position index=(35, 2, 4), yaw=-26.1, pitch=24.2
2011-11-14 12:39:16,780::Main::DEBUG::ShootController.__onShootingUpdate(): index=(35, 2, 4), yaw=-26.1, pitch=24.2, state=None, next=True
2011-11-14 12:39:16,842::Shooting::DEBUG::Shooting.start(): pict #35 of 72, index=(35, 2, 4), yaw=-26.1, pitch=24.2
2011-11-14 12:39:16,842::Main::DEBUG::ShootController.__onShootingUpdate(): index=(35, 2, 4), yaw=-26.1, pitch=24.2, state=None, next=True
2011-11-14 12:39:16,875::Shooting::INFO::Moving
2011-11-14 12:39:16,875::Main::DEBUG::ShootController.__onShootingSequence(): sequence=moving
2011-11-14 12:39:16,890::Shooting::DEBUG::MerlinOrionAxis.drive(): 'yawAxis' drive to -26.1
2011-11-14 12:39:16,905::Shooting::DEBUG::MerlinOrionAxis.drive(): 'pitchAxis' drive to -24.2
2011-11-14 12:39:22,953::Shooting::INFO::Stabilization
2011-11-14 12:39:22,953::Main::DEBUG::ShootController.__onShootingSequence(): sequence=stabilization
2011-11-14 12:39:23,453::Shooting::INFO::Shutter cycle
2011-11-14 12:39:23,453::Shooting::DEBUG::Shooting.start(): bracket #1 of 1
2011-11-14 12:39:23,453::Main::DEBUG::ShootController.__onShootingSequence(): sequence=shutter
2011-11-14 12:39:24,062::Shooting::DEBUG::Data.addPicture(): bracket=1, yaw=-26.1, pitch=24.3, roll=0.0
2011-11-14 12:39:24,062::Shooting::DEBUG::Data._addNode(): parent=shoot, tag=pict, value=None, attr={'bracket': '1', 'id': '35'}
2011-11-14 12:39:24,062::Shooting::DEBUG::Data._addNode(): parent=pict, tag=time, value=2011-11-14_12h39m24s, attr={}
2011-11-14 12:39:24,062::Shooting::DEBUG::Data._addNode(): parent=pict, tag=position, value=None, attr={'yaw': '-26.1', 'roll': '0.0', 'pitch': '24.3'}
2011-11-14 12:39:25,578::Main::DEBUG::ShootController.__onShootingUpdate(): index=(35, 2, 4), yaw=-26.1, pitch=24.2, state=ok, next=None
2011-11-14 12:39:25,625::Shooting::DEBUG::Shooting.start(): position index=(36, 1, 4), yaw=-34.7, pitch=24.2
2011-11-14 12:39:25,625::Main::DEBUG::ShootController.__onShootingUpdate(): index=(36, 1, 4), yaw=-34.7, pitch=24.2, state=None, next=True
2011-11-14 12:39:25,687::Shooting::DEBUG::Shooting.start(): pict #36 of 72, index=(36, 1, 4), yaw=-34.7, pitch=24.2
2011-11-14 12:39:25,687::Main::DEBUG::ShootController.__onShootingUpdate(): index=(36, 1, 4), yaw=-34.7, pitch=24.2, state=None, next=True
2011-11-14 12:39:25,733::Shooting::INFO::Moving
2011-11-14 12:39:25,733::Main::DEBUG::ShootController.__onShootingSequence(): sequence=moving
2011-11-14 12:39:25,733::Shooting::DEBUG::MerlinOrionAxis.drive(): 'yawAxis' drive to -34.7
2011-11-14 12:39:25,780::Shooting::DEBUG::MerlinOrionAxis.drive(): 'pitchAxis' drive to -24.2
2011-11-14 12:39:31,812::Shooting::INFO::Stabilization
2011-11-14 12:39:31,812::Main::DEBUG::ShootController.__onShootingSequence(): sequence=stabilization
2011-11-14 12:39:32,312::Shooting::INFO::Shutter cycle
2011-11-14 12:39:32,312::Shooting::DEBUG::Shooting.start(): bracket #1 of 1
2011-11-14 12:39:32,312::Main::DEBUG::ShootController.__onShootingSequence(): sequence=shutter
2011-11-14 12:39:32,905::Shooting::DEBUG::Data.addPicture(): bracket=1, yaw=-34.7, pitch=24.3, roll=0.0
2011-11-14 12:39:32,905::Shooting::DEBUG::Data._addNode(): parent=shoot, tag=pict, value=None, attr={'bracket': '1', 'id': '36'}
2011-11-14 12:39:32,905::Shooting::DEBUG::Data._addNode(): parent=pict, tag=time, value=2011-11-14_12h39m32s, attr={}
2011-11-14 12:39:32,905::Shooting::DEBUG::Data._addNode(): parent=pict, tag=position, value=None, attr={'yaw': '-34.7', 'roll': '0.0', 'pitch': '24.3'}
2011-11-14 12:39:34,437::Main::DEBUG::ShootController.__onShootingUpdate(): index=(36, 1, 4), yaw=-34.7, pitch=24.2, state=ok, next=None
2011-11-14 12:39:34,483::Shooting::DEBUG::Shooting.start(): position index=(37, 1, 5), yaw=-34.7, pitch=18.2
2011-11-14 12:39:34,483::Main::DEBUG::ShootController.__onShootingUpdate(): index=(37, 1, 5), yaw=-34.7, pitch=18.2, state=None, next=True
2011-11-14 12:39:34,546::Shooting::DEBUG::Shooting.start(): pict #37 of 72, index=(37, 1, 5), yaw=-34.7, pitch=18.2
2011-11-14 12:39:34,546::Main::DEBUG::ShootController.__onShootingUpdate(): index=(37, 1, 5), yaw=-34.7, pitch=18.2, state=None, next=True
2011-11-14 12:39:34,592::Shooting::INFO::Moving
2011-11-14 12:39:34,592::Main::DEBUG::ShootController.__onShootingSequence(): sequence=moving
2011-11-14 12:39:34,592::Shooting::DEBUG::MerlinOrionAxis.drive(): 'yawAxis' drive to -34.7
2011-11-14 12:39:34,625::Shooting::DEBUG::MerlinOrionAxis.drive(): 'pitchAxis' drive to -18.2
2011-11-14 12:39:40,358::Shooting::INFO::Stabilization
2011-11-14 12:39:40,358::Main::DEBUG::ShootController.__onShootingSequence(): sequence=stabilization
2011-11-14 12:39:40,858::Shooting::INFO::Shutter cycle
2011-11-14 12:39:40,858::Shooting::DEBUG::Shooting.start(): bracket #1 of 1
2011-11-14 12:39:40,858::Main::DEBUG::ShootController.__onShootingSequence(): sequence=shutter
2011-11-14 12:39:41,421::Shooting::DEBUG::Data.addPicture(): bracket=1, yaw=-34.7, pitch=18.2, roll=0.0
2011-11-14 12:39:41,421::Shooting::DEBUG::Data._addNode(): parent=shoot, tag=pict, value=None, attr={'bracket': '1', 'id': '37'}
2011-11-14 12:39:41,421::Shooting::DEBUG::Data._addNode(): parent=pict, tag=time, value=2011-11-14_12h39m41s, attr={}
2011-11-14 12:39:41,421::Shooting::DEBUG::Data._addNode(): parent=pict, tag=position, value=None, attr={'yaw': '-34.7', 'roll': '0.0', 'pitch': '18.2'}
2011-11-14 12:39:42,937::Main::DEBUG::ShootController.__onShootingUpdate(): index=(37, 1, 5), yaw=-34.7, pitch=18.2, state=ok, next=None
2011-11-14 12:39:42,983::Shooting::DEBUG::Shooting.start(): position index=(38, 2, 5), yaw=-26.1, pitch=18.2
2011-11-14 12:39:42,983::Main::DEBUG::ShootController.__onShootingUpdate(): index=(38, 2, 5), yaw=-26.1, pitch=18.2, state=None, next=True
2011-11-14 12:39:43,046::Shooting::DEBUG::Shooting.start(): pict #38 of 72, index=(38, 2, 5), yaw=-26.1, pitch=18.2
2011-11-14 12:39:43,046::Main::DEBUG::ShootController.__onShootingUpdate(): index=(38, 2, 5), yaw=-26.1, pitch=18.2, state=None, next=True
2011-11-14 12:39:43,078::Shooting::INFO::Moving
2011-11-14 12:39:43,078::Main::DEBUG::ShootController.__onShootingSequence(): sequence=moving
2011-11-14 12:39:43,078::Shooting::DEBUG::MerlinOrionAxis.drive(): 'yawAxis' drive to -26.1
2011-11-14 12:39:43,108::Shooting::DEBUG::MerlinOrionAxis.drive(): 'pitchAxis' drive to -18.2
2011-11-14 12:39:49,108::Shooting::INFO::Stabilization
2011-11-14 12:39:49,108::Main::DEBUG::ShootController.__onShootingSequence(): sequence=stabilization
2011-11-14 12:39:49,608::Shooting::INFO::Shutter cycle
2011-11-14 12:39:49,608::Shooting::DEBUG::Shooting.start(): bracket #1 of 1
2011-11-14 12:39:49,608::Main::DEBUG::ShootController.__onShootingSequence(): sequence=shutter
2011-11-14 12:39:50,203::Shooting::DEBUG::Data.addPicture(): bracket=1, yaw=-26.1, pitch=18.2, roll=0.0
2011-11-14 12:39:50,203::Shooting::DEBUG::Data._addNode(): parent=shoot, tag=pict, value=None, attr={'bracket': '1', 'id': '38'}
2011-11-14 12:39:50,203::Shooting::DEBUG::Data._addNode(): parent=pict, tag=time, value=2011-11-14_12h39m50s, attr={}
2011-11-14 12:39:50,203::Shooting::DEBUG::Data._addNode(): parent=pict, tag=position, value=None, attr={'yaw': '-26.1', 'roll': '0.0', 'pitch': '18.2'}
2011-11-14 12:39:51,733::Main::DEBUG::ShootController.__onShootingUpdate(): index=(38, 2, 5), yaw=-26.1, pitch=18.2, state=ok, next=None
2011-11-14 12:39:51,780::Shooting::DEBUG::Shooting.start(): position index=(39, 3, 5), yaw=-17.4, pitch=18.2
2011-11-14 12:39:51,780::Main::DEBUG::ShootController.__onShootingUpdate(): index=(39, 3, 5), yaw=-17.4, pitch=18.2, state=None, next=True
2011-11-14 12:39:51,842::Shooting::DEBUG::Shooting.start(): pict #39 of 72, index=(39, 3, 5), yaw=-17.4, pitch=18.2
2011-11-14 12:39:51,842::Main::DEBUG::ShootController.__onShootingUpdate(): index=(39, 3, 5), yaw=-17.4, pitch=18.2, state=None, next=True
2011-11-14 12:39:51,875::Shooting::INFO::Moving
2011-11-14 12:39:51,875::Main::DEBUG::ShootController.__onShootingSequence(): sequence=moving
2011-11-14 12:39:51,875::Shooting::DEBUG::MerlinOrionAxis.drive(): 'yawAxis' drive to -17.4
2011-11-14 12:39:51,937::Shooting::DEBUG::MerlinOrionAxis.drive(): 'pitchAxis' drive to -18.2
2011-11-14 12:39:58,000::Shooting::INFO::Stabilization
2011-11-14 12:39:58,000::Main::DEBUG::ShootController.__onShootingSequence(): sequence=stabilization
2011-11-14 12:39:58,500::Shooting::INFO::Shutter cycle
2011-11-14 12:39:58,500::Shooting::DEBUG::Shooting.start(): bracket #1 of 1
2011-11-14 12:39:58,500::Main::DEBUG::ShootController.__onShootingSequence(): sequence=shutter
2011-11-14 12:39:59,092::Shooting::DEBUG::Data.addPicture(): bracket=1, yaw=-17.4, pitch=18.2, roll=0.0
2011-11-14 12:39:59,092::Shooting::DEBUG::Data._addNode(): parent=shoot, tag=pict, value=None, attr={'bracket': '1', 'id': '39'}
2011-11-14 12:39:59,092::Shooting::DEBUG::Data._addNode(): parent=pict, tag=time, value=2011-11-14_12h39m59s, attr={}
2011-11-14 12:39:59,092::Shooting::DEBUG::Data._addNode(): parent=pict, tag=position, value=None, attr={'yaw': '-17.4', 'roll': '0.0', 'pitch': '18.2'}
2011-11-14 12:40:00,608::Main::DEBUG::ShootController.__onShootingUpdate(): index=(39, 3, 5), yaw=-17.4, pitch=18.2, state=ok, next=None
2011-11-14 12:40:00,655::Shooting::DEBUG::Shooting.start(): position index=(40, 4, 5), yaw=-8.8, pitch=18.2
2011-11-14 12:40:00,671::Main::DEBUG::ShootController.__onShootingUpdate(): index=(40, 4, 5), yaw=-8.8, pitch=18.2, state=None, next=True
2011-11-14 12:40:00,717::Shooting::DEBUG::Shooting.start(): pict #40 of 72, index=(40, 4, 5), yaw=-8.8, pitch=18.2
2011-11-14 12:40:00,733::Main::DEBUG::ShootController.__onShootingUpdate(): index=(40, 4, 5), yaw=-8.8, pitch=18.2, state=None, next=True
2011-11-14 12:40:00,750::Shooting::INFO::Moving
2011-11-14 12:40:00,765::Main::DEBUG::ShootController.__onShootingSequence(): sequence=moving
2011-11-14 12:40:00,765::Shooting::DEBUG::MerlinOrionAxis.drive(): 'yawAxis' drive to -8.8
2011-11-14 12:40:00,812::Shooting::DEBUG::MerlinOrionAxis.drive(): 'pitchAxis' drive to -18.2
2011-11-14 12:40:06,780::Shooting::INFO::Stabilization
2011-11-14 12:40:06,780::Main::DEBUG::ShootController.__onShootingSequence(): sequence=stabilization
2011-11-14 12:40:07,280::Shooting::INFO::Shutter cycle
2011-11-14 12:40:07,280::Shooting::DEBUG::Shooting.start(): bracket #1 of 1
2011-11-14 12:40:07,280::Main::DEBUG::ShootController.__onShootingSequence(): sequence=shutter
2011-11-14 12:40:07,858::Shooting::DEBUG::Data.addPicture(): bracket=1, yaw=-8.8, pitch=18.2, roll=0.0
2011-11-14 12:40:07,858::Shooting::DEBUG::Data._addNode(): parent=shoot, tag=pict, value=None, attr={'bracket': '1', 'id': '40'}
2011-11-14 12:40:07,875::Shooting::DEBUG::Data._addNode(): parent=pict, tag=time, value=2011-11-14_12h40m07s, attr={}
2011-11-14 12:40:07,875::Shooting::DEBUG::Data._addNode(): parent=pict, tag=position, value=None, attr={'yaw': '-8.8', 'roll': '0.0', 'pitch': '18.2'}
2011-11-14 12:40:09,405::Main::DEBUG::ShootController.__onShootingUpdate(): index=(40, 4, 5), yaw=-8.8, pitch=18.2, state=ok, next=None
2011-11-14 12:40:09,453::Shooting::DEBUG::Shooting.start(): position index=(41, 5, 5), yaw=-0.1, pitch=18.2
2011-11-14 12:40:09,467::Main::DEBUG::ShootController.__onShootingUpdate(): index=(41, 5, 5), yaw=-0.1, pitch=18.2, state=None, next=True
2011-11-14 12:40:09,530::Shooting::DEBUG::Shooting.start(): pict #41 of 72, index=(41, 5, 5), yaw=-0.1, pitch=18.2
2011-11-14 12:40:09,530::Main::DEBUG::ShootController.__onShootingUpdate(): index=(41, 5, 5), yaw=-0.1, pitch=18.2, state=None, next=True
2011-11-14 12:40:09,562::Shooting::INFO::Moving
2011-11-14 12:40:09,562::Main::DEBUG::ShootController.__onShootingSequence(): sequence=moving
2011-11-14 12:40:09,578::Shooting::DEBUG::MerlinOrionAxis.drive(): 'yawAxis' drive to -0.1
2011-11-14 12:40:09,608::Shooting::DEBUG::MerlinOrionAxis.drive(): 'pitchAxis' drive to -18.2
2011-11-14 12:40:14,640::Spy::EXCEPTION::MerlinOrionHardware.__sendCmd
2011-11-14 12:40:14,640::Spy::WARNING::MerlinOrionHardware.__sendCmd(): axis 1 can't sent command ':j1\r'. Retrying...
2011-11-14 12:40:15,530::Shooting::INFO::Stabilization
2011-11-14 12:40:15,530::Main::DEBUG::ShootController.__onShootingSequence(): sequence=stabilization
2011-11-14 12:40:16,030::Shooting::INFO::Shutter cycle
2011-11-14 12:40:16,030::Shooting::DEBUG::Shooting.start(): bracket #1 of 1
2011-11-14 12:40:16,030::Main::DEBUG::ShootController.__onShootingSequence(): sequence=shutter
2011-11-14 12:40:16,608::Shooting::DEBUG::Data.addPicture(): bracket=1, yaw=-0.1, pitch=18.2, roll=0.0
2011-11-14 12:40:16,608::Shooting::DEBUG::Data._addNode(): parent=shoot, tag=pict, value=None, attr={'bracket': '1', 'id': '41'}
2011-11-14 12:40:16,625::Shooting::DEBUG::Data._addNode(): parent=pict, tag=time, value=2011-11-14_12h40m16s, attr={}
2011-11-14 12:40:16,625::Shooting::DEBUG::Data._addNode(): parent=pict, tag=position, value=None, attr={'yaw': '-0.1', 'roll': '0.0', 'pitch': '18.2'}
2011-11-14 12:40:18,280::Main::DEBUG::ShootController.__onShootingUpdate(): index=(41, 5, 5), yaw=-0.1, pitch=18.2, state=ok, next=None
2011-11-14 12:40:18,328::Shooting::DEBUG::Shooting.start(): position index=(42, 6, 5), yaw=8.6, pitch=18.2
2011-11-14 12:40:18,328::Main::DEBUG::ShootController.__onShootingUpdate(): index=(42, 6, 5), yaw=8.6, pitch=18.2, state=None, next=True
2011-11-14 12:40:18,405::Shooting::DEBUG::Shooting.start(): pict #42 of 72, index=(42, 6, 5), yaw=8.6, pitch=18.2
2011-11-14 12:40:18,405::Main::DEBUG::ShootController.__onShootingUpdate(): index=(42, 6, 5), yaw=8.6, pitch=18.2, state=None, next=True
2011-11-14 12:40:18,437::Shooting::INFO::Moving
2011-11-14 12:40:18,437::Main::DEBUG::ShootController.__onShootingSequence(): sequence=moving
2011-11-14 12:40:18,437::Shooting::DEBUG::MerlinOrionAxis.drive(): 'yawAxis' drive to 8.6
2011-11-14 12:40:18,453::Shooting::DEBUG::MerlinOrionAxis.drive(): 'pitchAxis' drive to -18.2
2011-11-14 12:40:24,405::Shooting::INFO::Stabilization
2011-11-14 12:40:24,405::Main::DEBUG::ShootController.__onShootingSequence(): sequence=stabilization
2011-11-14 12:40:24,905::Shooting::INFO::Shutter cycle
2011-11-14 12:40:24,905::Shooting::DEBUG::Shooting.start(): bracket #1 of 1
2011-11-14 12:40:24,905::Main::DEBUG::ShootController.__onShootingSequence(): sequence=shutter
2011-11-14 12:40:25,483::Shooting::DEBUG::Data.addPicture(): bracket=1, yaw=8.6, pitch=18.2, roll=0.0
2011-11-14 12:40:25,483::Shooting::DEBUG::Data._addNode(): parent=shoot, tag=pict, value=None, attr={'bracket': '1', 'id': '42'}
2011-11-14 12:40:25,483::Shooting::DEBUG::Data._addNode(): parent=pict, tag=time, value=2011-11-14_12h40m25s, attr={}
2011-11-14 12:40:25,483::Shooting::DEBUG::Data._addNode(): parent=pict, tag=position, value=None, attr={'yaw': '8.6', 'roll': '0.0', 'pitch': '18.2'}
2011-11-14 12:40:27,015::Main::DEBUG::ShootController.__onShootingUpdate(): index=(42, 6, 5), yaw=8.6, pitch=18.2, state=ok, next=None
2011-11-14 12:40:27,062::Shooting::DEBUG::Shooting.start(): position index=(43, 7, 5), yaw=17.2, pitch=18.2
2011-11-14 12:40:27,062::Main::DEBUG::ShootController.__onShootingUpdate(): index=(43, 7, 5), yaw=17.2, pitch=18.2, state=None, next=True
2011-11-14 12:40:27,125::Shooting::DEBUG::Shooting.start(): pict #43 of 72, index=(43, 7, 5), yaw=17.2, pitch=18.2
2011-11-14 12:40:27,125::Main::DEBUG::ShootController.__onShootingUpdate(): index=(43, 7, 5), yaw=17.2, pitch=18.2, state=None, next=True
2011-11-14 12:40:27,155::Shooting::INFO::Moving
2011-11-14 12:40:27,155::Main::DEBUG::ShootController.__onShootingSequence(): sequence=moving
2011-11-14 12:40:27,171::Shooting::DEBUG::MerlinOrionAxis.drive(): 'yawAxis' drive to 17.2
2011-11-14 12:40:27,187::Shooting::DEBUG::MerlinOrionAxis.drive(): 'pitchAxis' drive to -18.2
2011-11-14 12:40:33,171::Shooting::INFO::Stabilization
2011-11-14 12:40:33,171::Main::DEBUG::ShootController.__onShootingSequence(): sequence=stabilization
2011-11-14 12:40:33,671::Shooting::INFO::Shutter cycle
2011-11-14 12:40:33,671::Shooting::DEBUG::Shooting.start(): bracket #1 of 1
2011-11-14 12:40:33,671::Main::DEBUG::ShootController.__onShootingSequence(): sequence=shutter
2011-11-14 12:40:34,265::Shooting::DEBUG::Data.addPicture(): bracket=1, yaw=17.2, pitch=18.2, roll=0.0
2011-11-14 12:40:34,265::Shooting::DEBUG::Data._addNode(): parent=shoot, tag=pict, value=None, attr={'bracket': '1', 'id': '43'}
2011-11-14 12:40:34,265::Shooting::DEBUG::Data._addNode(): parent=pict, tag=time, value=2011-11-14_12h40m34s, attr={}
2011-11-14 12:40:34,265::Shooting::DEBUG::Data._addNode(): parent=pict, tag=position, value=None, attr={'yaw': '17.2', 'roll': '0.0', 'pitch': '18.2'}
2011-11-14 12:40:35,500::Spy::EXCEPTION::MerlinOrionHardware.__sendCmd
2011-11-14 12:40:35,500::Spy::WARNING::MerlinOrionHardware.__sendCmd(): axis 2 can't sent command ':j2\r'. Retrying...
2011-11-14 12:40:35,780::Main::DEBUG::ShootController.__onShootingUpdate(): index=(43, 7, 5), yaw=17.2, pitch=18.2, state=ok, next=None
2011-11-14 12:40:35,828::Shooting::DEBUG::Shooting.start(): position index=(44, 8, 5), yaw=25.9, pitch=18.2
2011-11-14 12:40:35,842::Main::DEBUG::ShootController.__onShootingUpdate(): index=(44, 8, 5), yaw=25.9, pitch=18.2, state=None, next=True
2011-11-14 12:40:35,905::Shooting::DEBUG::Shooting.start(): pict #44 of 72, index=(44, 8, 5), yaw=25.9, pitch=18.2
2011-11-14 12:40:35,905::Main::DEBUG::ShootController.__onShootingUpdate(): index=(44, 8, 5), yaw=25.9, pitch=18.2, state=None, next=True
2011-11-14 12:40:35,937::Shooting::INFO::Moving
2011-11-14 12:40:35,937::Main::DEBUG::ShootController.__onShootingSequence(): sequence=moving
2011-11-14 12:40:35,937::Shooting::DEBUG::MerlinOrionAxis.drive(): 'yawAxis' drive to 25.9
2011-11-14 12:40:36,530::Spy::EXCEPTION::MerlinOrionHardware.__sendCmd
2011-11-14 12:40:36,530::Spy::WARNING::MerlinOrionHardware.__sendCmd(): axis 2 can't sent command ':j2\r'. Retrying...
2011-11-14 12:40:36,562::Shooting::DEBUG::MerlinOrionAxis.drive(): 'pitchAxis' drive to -18.2
2011-11-14 12:40:36,625::Shooting::EXCEPTION::Shooting.start()
  File "papywizard\model\shooting.pyo", line 557, in start
  File "papywizard\model\head.pyo", line 170, in gotoPosition
  File "papywizard\plugins\merlinOrionPlugins.pyo", line 209, in drive
     0x5
 SyntaxError: invalid syntax
2011-11-14 12:40:36,625::Shooting::ERROR::Unhandled exception in shoot process
2011-11-14 12:40:36,625::Main::DEBUG::ShootController.__onShootingStopped(): status=fail
2011-11-14 12:40:39,546::Spy::EXCEPTION::MerlinOrionHardware.__sendCmd
2011-11-14 12:40:39,546::Spy::WARNING::MerlinOrionHardware.__sendCmd(): axis 1 can't sent command ':j1\r'. Retrying...
2011-11-14 12:41:32,890::Main::INFO::Stopping connection. Please wait...
2011-11-14 12:41:32,905::Main::DEBUG::PluginsConnector.start(): 'yawAxis' shutdown
2011-11-14 12:41:32,921::Main::DEBUG::PluginsConnector.start(): 'yawAxis' stop connection
2011-11-14 12:41:32,921::Main::DEBUG::PluginsConnector.start(): 'pitchAxis' shutdown
2011-11-14 12:41:32,937::Main::DEBUG::PluginsConnector.start(): 'pitchAxis' stop connection
2011-11-14 12:41:32,937::Main::DEBUG::PluginsConnector.start(): 'shutter' shutdown
2011-11-14 12:41:32,953::Spy::INFO::Spy suspended
2011-11-14 12:41:32,953::Main::DEBUG::PluginsConnector.start(): 'shutter' stop connection
2011-11-14 12:41:33,078::Main::INFO::Connection stopped
2011-11-14 12:41:33,108::Main::INFO::Shuting down GUI...
2011-11-14 12:41:33,125::Main::INFO::Shuting down Spy...
2011-11-14 12:41:33,125::Main::DEBUG::Waiting Spy thread to terminate...
2011-11-14 12:41:33,155::Spy::INFO::Spy resumed
2011-11-14 12:41:33,155::Spy::INFO::Spy stopped
2011-11-14 12:41:33,155::Main::INFO::Shuting down model...
2011-11-14 12:41:33,155::Main::WARNING::Shooting.shutdown(): shutdown plugins here?
2011-11-14 12:41:33,171::Main::DEBUG::Configuration saved
2011-11-14 12:41:33,171::Main::INFO::Cleaning up resources...
2011-11-14 12:41:33,171::Main::INFO::Papywizard stopped
Logging is the second part was published.
I hope to hang on to identify the cause of this log.
Best regads.
Blog:http://uhrp.imagefitter.com/
Panogear(FW 020781);BT (Serial COM40);Pw(FW 2.1.20-1);Dell vostro1200(xp sp3)
TouchCP(FW 2.0) Autopano Giga(v2.0.9)
Nikon D300S;Nikkor AF 28-200mm;Nikkor AF-S 300mm
by fma38 » Wed Nov 16, 2011 7:26 am
There are some communication problems (timeout or bad chars received).
Try to double check all the connections (soldering and so). You may try to change the resistor value of the TTL cable/bluetooth module on the RX line: 220 Ohm -> 100 Ohm (keep the 220 Ohm on the TX line). Ask Claude for help about this.
mamoo
by mamoo » Wed Nov 16, 2011 8:33 am
Hi Frédéric
Thanks for quick reply.
I tried to connect using Bluetooth, the result is good.
Looks like something is wrong with TTL cable as you say. But to repair this weekend.
Arigato!
claudevh
by claudevh » Thu Nov 17, 2011 12:03 am
Hello Mamoo,
I confirm the diagnostic of Frederic !
This is a problem with the connections cables.
Arigato!
:cool: Claude :cool:
mamoo
by mamoo » Thu Nov 17, 2011 5:19 am
Hi Claude!
I advise you that we can fully understand, thank you very much.
But I have this technology, Nantes break ... now what I created.
Now, we have taken with a Bluetooth adapter. I did a good job all PC · Bluetooth adapter Panogear. Hagoki is my kidney.
Arigato!
mamoo
by mamoo » Sat Nov 19, 2011 2:21 am
Hi Frédéric & Claude!
Cable is damaged, as was pointed out of you.
My technique was a big deal What is reminded not to.
Nevertheless,Papywizard is a great system.
Arigato!
