Hang up details Papywizard2.1.21
mamoo
by mamoo » Tue Nov 15, 2011 8:41 pm
Hi Frederic
I was able to get the log file when you hang up Papywizard thanks.
Status:
Panogear CPU and is connected with a TTL cable.
Happens, the CPU Bluetooth adapter was enabled.
CPU:Windows xp sp3
2011-11-13 10:37:36,500::Spy::WARNING::MerlinOrionHardware.__sendCmd(): axis 1 can't sent command ':j1\r'. Retrying...
2011-11-13 10:37:37,515::Spy::EXCEPTION::MerlinOrionHardware.__sendCmd
  File "papywizard\hardware\merlinOrionHardware.pyo", line 145, in __sendCmd
  File "papywizard\driver\serialDriver.pyo", line 115, in read
IOError: Timeout while reading on serial bus (size=1, data='')
2011-11-13 10:37:37,515::Spy::WARNING::MerlinOrionHardware.__sendCmd(): axis 1 can't sent command ':j1\r'. Retrying...
2011-11-13 10:37:37,515::Spy::EXCEPTION::Spy.refresh(): can't read position
  File "papywizard\controller\spy.pyo", line 131, in refresh
  File "papywizard\model\head.pyo", line 154, in readPosition
  File "papywizard\plugins\merlinOrionPlugins.pyo", line 204, in read
  File "papywizard\hardware\merlinOrionHardware.pyo", line 207, in read
  File "papywizard\hardware\merlinOrionHardware.pyo", line 164, in __sendCmd
HardwareError: axis 1 can't send command ':j1\r'
2011-11-13 10:37:38,733::Spy::EXCEPTION::MerlinOrionHardware.__sendCmd
2011-11-13 10:37:38,733::Spy::WARNING::MerlinOrionHardware.__sendCmd(): axis 1 can't sent command ':j1\r'. Retrying...
2011-11-13 10:37:39,750::Spy::EXCEPTION::MerlinOrionHardware.__sendCmd
2011-11-13 10:37:39,750::Spy::WARNING::MerlinOrionHardware.__sendCmd(): axis 1 can't sent command ':j1\r'. Retrying...
2011-11-13 10:37:40,765::Spy::EXCEPTION::MerlinOrionHardware.__sendCmd
2011-11-13 10:37:40,765::Spy::WARNING::MerlinOrionHardware.__sendCmd(): axis 1 can't sent command ':j1\r'. Retrying...
2011-11-13 10:37:40,765::Spy::EXCEPTION::Spy.refresh(): can't read position
2011-11-13 10:37:41,967::Spy::EXCEPTION::MerlinOrionHardware.__sendCmd
2011-11-13 10:37:41,967::Spy::WARNING::MerlinOrionHardware.__sendCmd(): axis 1 can't sent command ':j1\r'. Retrying...
2011-11-13 10:37:42,983::Spy::EXCEPTION::MerlinOrionHardware.__sendCmd
2011-11-13 10:37:42,983::Spy::WARNING::MerlinOrionHardware.__sendCmd(): axis 1 can't sent command ':j1\r'. Retrying...
2011-11-13 10:37:43,983::Spy::EXCEPTION::MerlinOrionHardware.__sendCmd
2011-11-13 10:37:43,983::Spy::WARNING::MerlinOrionHardware.__sendCmd(): axis 1 can't sent command ':j1\r'. Retrying...
2011-11-13 10:37:43,983::Spy::EXCEPTION::Spy.refresh(): can't read position
2011-11-13 10:37:45,187::Spy::EXCEPTION::MerlinOrionHardware.__sendCmd
2011-11-13 10:37:45,187::Spy::WARNING::MerlinOrionHardware.__sendCmd(): axis 1 can't sent command ':j1\r'. Retrying...
2011-11-13 10:37:46,203::Spy::EXCEPTION::MerlinOrionHardware.__sendCmd
2011-11-13 10:37:46,203::Spy::WARNING::MerlinOrionHardware.__sendCmd(): axis 1 can't sent command ':j1\r'. Retrying...
2011-11-13 10:37:47,203::Spy::EXCEPTION::MerlinOrionHardware.__sendCmd
2011-11-13 10:37:47,203::Spy::WARNING::MerlinOrionHardware.__sendCmd(): axis 1 can't sent command ':j1\r'. Retrying...
2011-11-13 10:37:47,203::Spy::EXCEPTION::Spy.refresh(): can't read position
2011-11-13 10:37:54,203::Spy::EXCEPTION::MerlinOrionHardware.__sendCmd
2011-11-13 10:37:54,203::Spy::WARNING::MerlinOrionHardware.__sendCmd(): axis 1 can't sent command ':j1\r'. Retrying...
2011-11-13 10:37:55,217::Spy::EXCEPTION::MerlinOrionHardware.__sendCmd
2011-11-13 10:37:55,217::Spy::WARNING::MerlinOrionHardware.__sendCmd(): axis 1 can't sent command ':j1\r'. Retrying...
2011-11-13 10:38:00,733::Spy::EXCEPTION::MerlinOrionHardware.__sendCmd
2011-11-13 10:38:00,733::Spy::WARNING::MerlinOrionHardware.__sendCmd(): axis 1 can't sent command ':j1\r'. Retrying...
2011-11-13 10:38:01,750::Spy::EXCEPTION::MerlinOrionHardware.__sendCmd
2011-11-13 10:38:01,750::Spy::WARNING::MerlinOrionHardware.__sendCmd(): axis 1 can't sent command ':j1\r'. Retrying...
2011-11-13 10:38:04,030::Spy::EXCEPTION::MerlinOrionHardware.__sendCmd
2011-11-13 10:38:04,030::Spy::WARNING::MerlinOrionHardware.__sendCmd(): axis 1 can't sent command ':j1\r'. Retrying...
2011-11-13 10:38:05,046::Spy::EXCEPTION::MerlinOrionHardware.__sendCmd
2011-11-13 10:38:05,046::Spy::WARNING::MerlinOrionHardware.__sendCmd(): axis 1 can't sent command ':j1\r'. Retrying...
2011-11-13 10:38:06,062::Spy::EXCEPTION::MerlinOrionHardware.__sendCmd
2011-11-13 10:38:06,062::Spy::WARNING::MerlinOrionHardware.__sendCmd(): axis 1 can't sent command ':j1\r'. Retrying...
2011-11-13 10:38:06,062::Spy::EXCEPTION::Spy.refresh(): can't read position
2011-11-13 10:38:07,280::Spy::EXCEPTION::MerlinOrionHardware.__sendCmd
2011-11-13 10:38:07,280::Spy::WARNING::MerlinOrionHardware.__sendCmd(): axis 1 can't sent command ':j1\r'. Retrying...
2011-11-13 10:38:09,296::Spy::EXCEPTION::MerlinOrionHardware.__sendCmd
2011-11-13 10:38:09,296::Spy::WARNING::MerlinOrionHardware.__sendCmd(): axis 1 can't sent command ':j1\r'. Retrying...
2011-11-13 10:38:10,312::Spy::EXCEPTION::MerlinOrionHardware.__sendCmd
2011-11-13 10:38:10,312::Spy::WARNING::MerlinOrionHardware.__sendCmd(): axis 1 can't sent command ':j1\r'. Retrying...
2011-11-13 10:38:11,328::Spy::EXCEPTION::MerlinOrionHardware.__sendCmd
2011-11-13 10:38:11,328::Spy::WARNING::MerlinOrionHardware.__sendCmd(): axis 1 can't sent command ':j1\r'. Retrying...
2011-11-13 10:38:11,328::Spy::EXCEPTION::Spy.refresh(): can't read position
2011-11-13 10:38:12,546::Spy::EXCEPTION::MerlinOrionHardware.__sendCmd
2011-11-13 10:38:12,546::Spy::WARNING::MerlinOrionHardware.__sendCmd(): axis 1 can't sent command ':j1\r'. Retrying...
2011-11-13 10:38:13,562::Spy::EXCEPTION::MerlinOrionHardware.__sendCmd
2011-11-13 10:38:13,562::Spy::WARNING::MerlinOrionHardware.__sendCmd(): axis 1 can't sent command ':j1\r'. Retrying...
2011-11-13 10:38:15,015::Shooting::INFO::Start shooting process...
2011-11-13 10:38:15,015::Shooting::DEBUG::Shooting.start(): create mosaic data object
2011-11-13 10:38:15,015::Shooting::DEBUG::Data.__init__(): create xml tree
2011-11-13 10:38:15,078::Shooting::DEBUG::Data.createHeader(): values={'comment': u'Generated by Papywizard 2.1.21', 'cameraOrientation': u'landscape', 'yawNbPicts': '4', 'timeValue': '0.5', 'pitchNbPicts': '6', 'title': u'Smart illumination Yokohama', 'bracketingNbPicts': '1', 'counter': '138', 'stabilizationDelay': '0.5', 'overlap': '0.25', 'headOrientation': 'up', 'lensType': u'rectilinear', 'yawRealOverlap': '0.28', 'pitchRealOverlap': '0.31', 'sensorCoef': '1.5', 'sensorRatio': u'3:2', 'roll': '0.0', 'focal': '105.0', 'gps': u'Here goes the location'}
2011-11-13 10:38:15,078::Shooting::DEBUG::Data._addNode(): parent=header, tag=general, value=None, attr={}
2011-11-13 10:38:15,078::Shooting::DEBUG::Data._addNode(): parent=general, tag=title, value=Smart illumination Yokohama, attr={}
2011-11-13 10:38:15,078::Shooting::DEBUG::Data._addNode(): parent=general, tag=gps, value=Here goes the location, attr={}
2011-11-13 10:38:15,092::Shooting::DEBUG::Data._addNode(): parent=general, tag=comment, value=Generated by Papywizard 2.1.21, attr={}
2011-11-13 10:38:15,092::Shooting::DEBUG::Data._addNode(): parent=header, tag=shooting, value=None, attr={'mode': 'mosaic'}
2011-11-13 10:38:15,092::Shooting::DEBUG::Data._addNode(): parent=shooting, tag=headOrientation, value=up, attr={}
2011-11-13 10:38:15,092::Shooting::DEBUG::Data._addNode(): parent=shooting, tag=cameraOrientation, value=landscape, attr={}
2011-11-13 10:38:15,092::Shooting::DEBUG::Data._addNode(): parent=shooting, tag=stabilizationDelay, value=0.5, attr={}
2011-11-13 10:38:15,092::Shooting::DEBUG::Data._addNode(): parent=shooting, tag=counter, value=138, attr={}
2011-11-13 10:38:15,092::Shooting::DEBUG::Data._addNode(): parent=shooting, tag=startTime, value=2011-11-13_10h38m15s, attr={}
2011-11-13 10:38:15,108::Shooting::DEBUG::Data._addNode(): parent=shooting, tag=endTime, value=2011-11-13_10h38m15s, attr={}
2011-11-13 10:38:15,108::Shooting::DEBUG::Data._addNode(): parent=header, tag=camera, value=None, attr={}
2011-11-13 10:38:15,108::Shooting::DEBUG::Data._addNode(): parent=camera, tag=timeValue, value=0.5, attr={}
2011-11-13 10:38:15,108::Shooting::DEBUG::Data._addNode(): parent=camera, tag=bracketing, value=None, attr={'nbPicts': '1'}
2011-11-13 10:38:15,108::Shooting::DEBUG::Data._addNode(): parent=camera, tag=sensor, value=None, attr={'ratio': u'3:2', 'coef': '1.5'}
2011-11-13 10:38:15,125::Shooting::DEBUG::Data._addNode(): parent=header, tag=lens, value=None, attr={'type': u'rectilinear'}
2011-11-13 10:38:15,125::Shooting::DEBUG::Data._addNode(): parent=lens, tag=focal, value=105.0, attr={}
2011-11-13 10:38:15,125::Shooting::DEBUG::Data._addNode(): parent=header, tag=mosaic, value=None, attr={}
2011-11-13 10:38:15,125::Shooting::DEBUG::Data._addNode(): parent=mosaic, tag=nbPicts, value=None, attr={'yaw': '4', 'pitch': '6'}
2011-11-13 10:38:15,125::Shooting::DEBUG::Data._addNode(): parent=mosaic, tag=overlap, value=None, attr={'yaw': '0.28', 'minimum': '0.25', 'pitch': '0.31'}
2011-11-13 10:38:15,296::Shooting::DEBUG::Configuration saved
2011-11-13 10:38:15,296::Shooting::DEBUG::Shooting.start(): repeat 1/1
2011-11-13 10:38:15,312::Shooting::DEBUG::Shooting.start(): pict #1 of 24, index=(1, 1, 1), yaw=-16.8, pitch=20.4
2011-11-13 10:38:15,312::Main::DEBUG::ShootController.__onShootingUpdate(): index=(1, 1, 1), yaw=-16.8, pitch=20.4, state=None, next=True
2011-11-13 10:38:15,342::Shooting::INFO::Moving
2011-11-13 10:38:15,358::Main::DEBUG::ShootController.__onShootingSequence(): sequence=moving
2011-11-13 10:38:15,358::Shooting::DEBUG::MerlinOrionAxis.drive(): 'yawAxis' drive to -16.8
2011-11-13 10:38:15,405::Shooting::DEBUG::MerlinOrionAxis.drive(): 'pitchAxis' drive to -20.4
2011-11-13 10:38:17,578::Spy::EXCEPTION::MerlinOrionHardware.__sendCmd
2011-11-13 10:38:17,578::Spy::WARNING::MerlinOrionHardware.__sendCmd(): axis 1 can't sent command ':j1\r'. Retrying...
2011-11-13 10:38:21,546::Shooting::INFO::Stabilization
2011-11-13 10:38:21,546::Main::DEBUG::ShootController.__onShootingSequence(): sequence=stabilization
2011-11-13 10:38:22,046::Shooting::INFO::Shutter cycle
2011-11-13 10:38:22,046::Shooting::DEBUG::Shooting.start(): bracket #1 of 1
2011-11-13 10:38:22,046::Main::DEBUG::ShootController.__onShootingSequence(): sequence=shutter
2011-11-13 10:38:23,078::Shooting::EXCEPTION::MerlinOrionHardware.__sendCmd
2011-11-13 10:38:23,078::Shooting::WARNING::MerlinOrionHardware.__sendCmd(): axis 1 can't sent command ':O11\r'. Retrying...
2011-11-13 10:38:23,453::Shooting::DEBUG::Data.addPicture(): bracket=1, yaw=-16.8, pitch=20.4, roll=0.0
2011-11-13 10:38:23,453::Shooting::DEBUG::Data._addNode(): parent=shoot, tag=pict, value=None, attr={'bracket': '1', 'id': '1'}
2011-11-13 10:38:23,453::Shooting::DEBUG::Data._addNode(): parent=pict, tag=time, value=2011-11-13_10h38m23s, attr={}
2011-11-13 10:38:23,453::Shooting::DEBUG::Data._addNode(): parent=pict, tag=position, value=None, attr={'yaw': '-16.8', 'roll': '0.0', 'pitch': '20.4'}
2011-11-13 10:38:23,530::Main::DEBUG::ShootController.__onShootingUpdate(): index=(1, 1, 1), yaw=-16.8, pitch=20.4, state=ok, next=None
2011-11-13 10:38:23,578::Shooting::DEBUG::Shooting.start(): position index=(2, 2, 1), yaw=-7.4, pitch=20.4
2011-11-13 10:38:23,592::Main::DEBUG::ShootController.__onShootingUpdate(): index=(2, 2, 1), yaw=-7.4, pitch=20.4, state=None, next=True
2011-11-13 10:38:23,655::Shooting::DEBUG::Shooting.start(): pict #2 of 24, index=(2, 2, 1), yaw=-7.4, pitch=20.4
2011-11-13 10:38:23,655::Main::DEBUG::ShootController.__onShootingUpdate(): index=(2, 2, 1), yaw=-7.4, pitch=20.4, state=None, next=True
2011-11-13 10:38:23,687::Shooting::INFO::Moving
2011-11-13 10:38:23,687::Main::DEBUG::ShootController.__onShootingSequence(): sequence=moving
2011-11-13 10:38:23,687::Shooting::DEBUG::MerlinOrionAxis.drive(): 'yawAxis' drive to -7.4
2011-11-13 10:38:23,717::Shooting::DEBUG::MerlinOrionAxis.drive(): 'pitchAxis' drive to -20.4
2011-11-13 10:38:26,328::Shooting::EXCEPTION::MerlinOrionHardware.__sendCmd
2011-11-13 10:38:26,328::Shooting::WARNING::MerlinOrionHardware.__sendCmd(): axis 1 can't sent command ':f1\r'. Retrying...
2011-11-13 10:38:29,858::Shooting::INFO::Stabilization
2011-11-13 10:38:29,858::Main::DEBUG::ShootController.__onShootingSequence(): sequence=stabilization
2011-11-13 10:38:30,358::Shooting::INFO::Shutter cycle
2011-11-13 10:38:30,358::Shooting::DEBUG::Shooting.start(): bracket #1 of 1
2011-11-13 10:38:30,358::Main::DEBUG::ShootController.__onShootingSequence(): sequence=shutter
2011-11-13 10:38:30,953::Shooting::DEBUG::Data.addPicture(): bracket=1, yaw=-7.4, pitch=20.4, roll=0.0
2011-11-13 10:38:30,953::Shooting::DEBUG::Data._addNode(): parent=shoot, tag=pict, value=None, attr={'bracket': '1', 'id': '2'}
2011-11-13 10:38:30,953::Shooting::DEBUG::Data._addNode(): parent=pict, tag=time, value=2011-11-13_10h38m30s, attr={}
2011-11-13 10:38:30,953::Shooting::DEBUG::Data._addNode(): parent=pict, tag=position, value=None, attr={'yaw': '-7.4', 'roll': '0.0', 'pitch': '20.4'}
2011-11-13 10:38:31,592::Main::DEBUG::ShootController.__onShootingUpdate(): index=(2, 2, 1), yaw=-7.4, pitch=20.4, state=ok, next=None
2011-11-13 10:38:31,640::Shooting::DEBUG::Shooting.start(): position index=(3, 3, 1), yaw=1.9, pitch=20.4
2011-11-13 10:38:31,640::Main::DEBUG::ShootController.__onShootingUpdate(): index=(3, 3, 1), yaw=1.9, pitch=20.4, state=None, next=True
2011-11-13 10:38:31,703::Shooting::DEBUG::Shooting.start(): pict #3 of 24, index=(3, 3, 1), yaw=1.9, pitch=20.4
2011-11-13 10:38:31,717::Main::DEBUG::ShootController.__onShootingUpdate(): index=(3, 3, 1), yaw=1.9, pitch=20.4, state=None, next=True
2011-11-13 10:38:31,733::Shooting::INFO::Moving
2011-11-13 10:38:31,750::Main::DEBUG::ShootController.__onShootingSequence(): sequence=moving
2011-11-13 10:38:31,750::Shooting::DEBUG::MerlinOrionAxis.drive(): 'yawAxis' drive to 1.9
2011-11-13 10:38:31,765::Shooting::DEBUG::MerlinOrionAxis.drive(): 'pitchAxis' drive to -20.4
2011-11-13 10:38:37,983::Shooting::INFO::Stabilization
2011-11-13 10:38:37,983::Main::DEBUG::ShootController.__onShootingSequence(): sequence=stabilization
2011-11-13 10:38:38,483::Shooting::INFO::Shutter cycle
2011-11-13 10:38:38,483::Shooting::DEBUG::Shooting.start(): bracket #1 of 1
2011-11-13 10:38:38,483::Main::DEBUG::ShootController.__onShootingSequence(): sequence=shutter
2011-11-13 10:38:39,108::Shooting::DEBUG::Data.addPicture(): bracket=1, yaw=1.9, pitch=20.4, roll=0.0
2011-11-13 10:38:39,108::Shooting::DEBUG::Data._addNode(): parent=shoot, tag=pict, value=None, attr={'bracket': '1', 'id': '3'}
2011-11-13 10:38:39,108::Shooting::DEBUG::Data._addNode(): parent=pict, tag=time, value=2011-11-13_10h38m39s, attr={}
2011-11-13 10:38:39,108::Shooting::DEBUG::Data._addNode(): parent=pict, tag=position, value=None, attr={'yaw': '1.9', 'roll': '0.0', 'pitch': '20.4'}
2011-11-13 10:38:39,328::Main::DEBUG::ShootController.__onShootingUpdate(): index=(3, 3, 1), yaw=1.9, pitch=20.4, state=ok, next=None
2011-11-13 10:38:39,375::Shooting::DEBUG::Shooting.start(): position index=(4, 4, 1), yaw=11.3, pitch=20.4
2011-11-13 10:38:39,390::Main::DEBUG::ShootController.__onShootingUpdate(): index=(4, 4, 1), yaw=11.3, pitch=20.4, state=None, next=True
2011-11-13 10:38:39,437::Shooting::DEBUG::Shooting.start(): pict #4 of 24, index=(4, 4, 1), yaw=11.3, pitch=20.4
2011-11-13 10:38:39,437::Main::DEBUG::ShootController.__onShootingUpdate(): index=(4, 4, 1), yaw=11.3, pitch=20.4, state=None, next=True
2011-11-13 10:38:39,483::Shooting::INFO::Moving
2011-11-13 10:38:39,483::Main::DEBUG::ShootController.__onShootingSequence(): sequence=moving
2011-11-13 10:38:39,483::Shooting::DEBUG::MerlinOrionAxis.drive(): 'yawAxis' drive to 11.3
2011-11-13 10:38:39,515::Shooting::DEBUG::MerlinOrionAxis.drive(): 'pitchAxis' drive to -20.4
2011-11-13 10:38:40,858::Shooting::EXCEPTION::MerlinOrionHardware.__sendCmd
2011-11-13 10:38:40,858::Shooting::WARNING::MerlinOrionHardware.__sendCmd(): axis 1 can't sent command ':f1\r'. Retrying...
2011-11-13 10:38:41,875::Shooting::EXCEPTION::MerlinOrionHardware.__sendCmd
2011-11-13 10:38:41,875::Shooting::WARNING::MerlinOrionHardware.__sendCmd(): axis 1 can't sent command ':f1\r'. Retrying...
2011-11-13 10:38:42,875::Shooting::EXCEPTION::MerlinOrionHardware.__sendCmd
2011-11-13 10:38:42,875::Shooting::WARNING::MerlinOrionHardware.__sendCmd(): axis 1 can't sent command ':f1\r'. Retrying...
2011-11-13 10:38:43,890::Spy::EXCEPTION::MerlinOrionHardware.__sendCmd
2011-11-13 10:38:43,890::Spy::WARNING::MerlinOrionHardware.__sendCmd(): axis 1 can't sent command ':j1\r'. Retrying...
2011-11-13 10:38:44,890::Spy::EXCEPTION::MerlinOrionHardware.__sendCmd
2011-11-13 10:38:44,890::Spy::WARNING::MerlinOrionHardware.__sendCmd(): axis 1 can't sent command ':j1\r'. Retrying...
2011-11-13 10:38:44,953::Shooting::EXCEPTION::Shooting.start()
  File "papywizard\model\shooting.pyo", line 557, in start
  File "papywizard\model\head.pyo", line 172, in gotoPosition
  File "papywizard\model\head.pyo", line 177, in waitEndOfDrive
  File "papywizard\plugins\merlinOrionPlugins.pyo", line 267, in waitEndOfDrive
  File "papywizard\plugins\merlinOrionPlugins.pyo", line 286, in isMoving
  File "papywizard\hardware\merlinOrionHardware.pyo", line 269, in getStatus
HardwareError: axis 1 can't send command ':f1\r'
2011-11-13 10:38:44,983::Main::DEBUG::ShootController.__onShootingUpdate(): index=(4, 4, 1), yaw=11.3, pitch=20.4, state=error, next=None
2011-11-13 10:38:45,030::Shooting::DEBUG::Shooting.start(): position index=(5, 4, 2), yaw=11.3, pitch=14.3
2011-11-13 10:38:45,046::Main::DEBUG::ShootController.__onShootingUpdate(): index=(5, 4, 2), yaw=11.3, pitch=14.3, state=None, next=True
2011-11-13 10:38:45,092::Shooting::DEBUG::Shooting.start(): pict #5 of 24, index=(5, 4, 2), yaw=11.3, pitch=14.3
2011-11-13 10:38:45,092::Main::DEBUG::ShootController.__onShootingUpdate(): index=(5, 4, 2), yaw=11.3, pitch=14.3, state=None, next=True
2011-11-13 10:38:45,125::Shooting::INFO::Moving
2011-11-13 10:38:45,125::Main::DEBUG::ShootController.__onShootingSequence(): sequence=moving
2011-11-13 10:38:45,125::Shooting::DEBUG::MerlinOrionAxis.drive(): 'yawAxis' drive to 11.3
2011-11-13 10:38:45,155::Shooting::DEBUG::MerlinOrionAxis.drive(): 'pitchAxis' drive to -14.3
2011-11-13 10:38:47,687::Spy::EXCEPTION::MerlinOrionHardware.__sendCmd
2011-11-13 10:38:47,687::Spy::WARNING::MerlinOrionHardware.__sendCmd(): axis 1 can't sent command ':j1\r'. Retrying...
2011-11-13 10:38:48,717::Shooting::EXCEPTION::MerlinOrionHardware.__sendCmd
  File "papywizard\hardware\merlinOrionHardware.pyo", line 152, in __sendCmd
2011-11-13 10:38:48,717::Shooting::WARNING::MerlinOrionHardware.__sendCmd(): axis 2 can't sent command ':f2\r'. Retrying...
2011-11-13 10:38:49,765::Spy::EXCEPTION::MerlinOrionHardware.__sendCmd
2011-11-13 10:38:49,765::Spy::WARNING::MerlinOrionHardware.__sendCmd(): axis 2 can't sent command ':j2\r'. Retrying...
2011-11-13 10:38:50,780::Spy::EXCEPTION::MerlinOrionHardware.__sendCmd
2011-11-13 10:38:50,780::Spy::WARNING::MerlinOrionHardware.__sendCmd(): axis 2 can't sent command ':j2\r'. Retrying...
2011-11-13 10:38:51,015::Shooting::INFO::Stabilization
2011-11-13 10:38:51,015::Main::DEBUG::ShootController.__onShootingSequence(): sequence=stabilization
2011-11-13 10:38:51,515::Shooting::INFO::Shutter cycle
2011-11-13 10:38:51,515::Shooting::DEBUG::Shooting.start(): bracket #1 of 1
2011-11-13 10:38:51,515::Main::DEBUG::ShootController.__onShootingSequence(): sequence=shutter
2011-11-13 10:38:52,108::Shooting::DEBUG::Data.addPicture(): bracket=1, yaw=11.3, pitch=14.3, roll=0.0
2011-11-13 10:38:52,108::Shooting::DEBUG::Data._addNode(): parent=shoot, tag=pict, value=None, attr={'bracket': '1', 'id': '4'}
2011-11-13 10:38:52,108::Shooting::DEBUG::Data._addNode(): parent=pict, tag=time, value=2011-11-13_10h38m52s, attr={}
2011-11-13 10:38:52,108::Shooting::DEBUG::Data._addNode(): parent=pict, tag=position, value=None, attr={'yaw': '11.3', 'roll': '0.0', 'pitch': '14.3'}
2011-11-13 10:38:52,875::Main::DEBUG::ShootController.__onShootingUpdate(): index=(5, 4, 2), yaw=11.3, pitch=14.3, state=ok, next=None
2011-11-13 10:38:52,921::Shooting::DEBUG::Shooting.start(): position index=(6, 3, 2), yaw=1.9, pitch=14.3
2011-11-13 10:38:52,921::Main::DEBUG::ShootController.__onShootingUpdate(): index=(6, 3, 2), yaw=1.9, pitch=14.3, state=None, next=True
2011-11-13 10:38:52,983::Shooting::DEBUG::Shooting.start(): pict #6 of 24, index=(6, 3, 2), yaw=1.9, pitch=14.3
2011-11-13 10:38:52,983::Main::DEBUG::ShootController.__onShootingUpdate(): index=(6, 3, 2), yaw=1.9, pitch=14.3, state=None, next=True
2011-11-13 10:38:53,015::Shooting::INFO::Moving
2011-11-13 10:38:53,030::Main::DEBUG::ShootController.__onShootingSequence(): sequence=moving
2011-11-13 10:38:53,030::Shooting::DEBUG::MerlinOrionAxis.drive(): 'yawAxis' drive to 1.9
2011-11-13 10:38:53,046::Shooting::DEBUG::MerlinOrionAxis.drive(): 'pitchAxis' drive to -14.3
2011-11-13 10:38:55,437::Spy::EXCEPTION::MerlinOrionHardware.__sendCmd
2011-11-13 10:38:55,437::Spy::WARNING::MerlinOrionHardware.__sendCmd(): axis 2 can't sent command ':j2\r'. Retrying...
2011-11-13 10:38:56,453::Spy::EXCEPTION::MerlinOrionHardware.__sendCmd
2011-11-13 10:38:56,453::Spy::WARNING::MerlinOrionHardware.__sendCmd(): axis 2 can't sent command ':j2\r'. Retrying...
2011-11-13 10:38:57,342::Shooting::INFO::Stop shooting
2011-11-13 10:38:57,342::Shooting::DEBUG::Shooting.start(): stop detected
2011-11-13 10:38:57,342::Shooting::WARNING::Shoot process canceled
2011-11-13 10:38:57,342::Main::DEBUG::ShootController.__onShootingStopped(): status=cancel
2011-11-13 10:39:04,546::Main::INFO::Stopping connection. Please wait...
2011-11-13 10:39:04,562::Main::DEBUG::PluginsConnector.start(): 'yawAxis' shutdown
2011-11-13 10:39:04,578::Main::DEBUG::PluginsConnector.start(): 'yawAxis' stop connection
2011-11-13 10:39:04,578::Main::DEBUG::PluginsConnector.start(): 'pitchAxis' shutdown
2011-11-13 10:39:04,592::Main::DEBUG::PluginsConnector.start(): 'pitchAxis' stop connection
2011-11-13 10:39:04,592::Main::DEBUG::PluginsConnector.start(): 'shutter' shutdown
2011-11-13 10:39:04,608::Main::DEBUG::PluginsConnector.start(): 'shutter' stop connection
2011-11-13 10:39:04,733::Main::INFO::Connection stopped
2011-11-13 10:39:04,750::Spy::INFO::Spy suspended
2011-11-13 10:39:04,780::Main::INFO::Shuting down GUI...
2011-11-13 10:39:04,780::Main::INFO::Shuting down Spy...
2011-11-13 10:39:04,780::Main::DEBUG::Waiting Spy thread to terminate...
2011-11-13 10:39:04,953::Spy::INFO::Spy resumed
2011-11-13 10:39:04,953::Spy::INFO::Spy stopped
2011-11-13 10:39:04,953::Main::INFO::Shuting down model...
2011-11-13 10:39:04,953::Main::WARNING::Shooting.shutdown(): shutdown plugins here?
2011-11-13 10:39:04,953::Main::DEBUG::Configuration saved
2011-11-13 10:39:04,953::Main::INFO::Cleaning up resources...
2011-11-13 10:39:04,967::Main::INFO::Papywizard stopped
2011-11-13 10:42:12,250::Main::INFO::Starting Papywizard...
2011-11-13 10:42:12,250::Main::DEBUG::main(): platform=win32
2011-11-13 10:42:12,375::Main::INFO::Importing modules...
2011-11-13 10:42:12,796::Main::INFO::Loading i18n files...
2011-11-13 10:42:12,796::Main::DEBUG::main(): locale=ja_JP
2011-11-13 10:42:12,796::Main::WARNING::Can't find qt translation file
2011-11-13 10:42:12,812::Main::WARNING::Can't find papywizard translation file
2011-11-13 10:42:12,812::Main::INFO::Loading Style Sheets...
2011-11-13 10:42:12,812::Main::WARNING::No user Style Sheet found
2011-11-13 10:42:12,812::Main::INFO::Loading configuration...
2011-11-13 10:42:12,828::Main::DEBUG::ConfigManager.__init__(): versions: dist=['2', '1', '21'], user=[u'2', u'1', u'21']
2011-11-13 10:42:12,828::Main::DEBUG::ConfigManager.__init__(): user config. is up-to-date
2011-11-13 10:42:12,828::Main::INFO::Load plugins...
2011-11-13 10:42:12,842::Main::DEBUG::DslrRemoteProShutter._defineConfig()
2011-11-13 10:42:12,842::Main::TRACE::AbstractPlugin._loadConfig()
2011-11-13 10:42:12,842::Main::DEBUG::AbstractPlugin._loadConfig(): config={'USER_EXPOSURE_COMPENSATION_LIST': '-2, 0, +2', 'DRY_RUN': False, 'MIRROR_LOCKUP': False, 'FILENAME_PREFIX': '', 'CAMERA_EXPOSURE_COMPENSATION_LIST': u'\xb12@1/3', 'OUTPUT_DIR': 'C:\\Documents and Settings\\mamoo', 'PROGRAM_PATH': 'C:\\Program Files\\BreezeSys\\DSLR Remote Pro\\DSLRRemoteTest\\DSLRRemoteTest.exe'}
2011-11-13 10:42:12,842::Main::DEBUG::PluginsManager.register(): added 'DSLR Remote Pro' plugin with capacity 'shutter'
2011-11-13 10:42:12,858::Main::TRACE::EOSUtilityShutter._defineConfig()
2011-11-13 10:42:12,858::Main::TRACE::AbstractPlugin._loadConfig()
2011-11-13 10:42:12,858::Main::DEBUG::AbstractPlugin._loadConfig(): config={'FOCUS_DIRECTION': u'far', 'BRACKETING_TYPE': '0-+', 'BULB_ENABLE': False, 'DRY_RUN': True, 'BULB_BASE_EXPOSURE': 1, 'FOCUS_NB_PICTS': 1, 'BRACKETING_NB_PICTS': 1, 'FOCUS_STEP_COUNT': 1, 'FOCUS_ENABLE': False, 'EOS_UTILITY_VERSION': u'new', 'PROGRAM_PATH': 'C:\\Program Files\\Papywizard\\EOSBracket.exe', 'BRACKETING_STEP': '1', 'FOCUS_STEP': u'medium'}
2011-11-13 10:42:12,858::Main::DEBUG::PluginsManager.register(): added 'EOS Utility' plugin with capacity 'shutter'
2011-11-13 10:42:12,858::Main::TRACE::GenericTetheredShutter._defineConfig()
2011-11-13 10:42:12,858::Main::DEBUG::AbstractPlugin._loadConfig(): config={'MIRROR_LOCKUP_COMMAND': 'gphoto2 --capture-image', 'MIRROR_LOCKUP': False, 'PARAM_4': '', 'PARAM_1': '', 'PARAM_0': '', 'SHOOT_COMMAND': 'gphoto2 --capture-image', 'PARAM_2': '', 'TIME_VALUE': 0.10000000000000001, 'PARAM_3': ''}
2011-11-13 10:42:12,858::Main::DEBUG::PluginsManager.register(): added 'Generic Tethered' plugin with capacity 'shutter'
2011-11-13 10:42:12,875::Main::TRACE::GigaPanBotAxis._init()
2011-11-13 10:42:12,875::Main::TRACE::AbstractHardwarePlugin._defineConfig()
2011-11-13 10:42:12,875::Main::TRACE::AbstractPlugin._loadConfig()
2011-11-13 10:42:12,875::Main::DEBUG::AbstractPlugin._loadConfig(): config={'HIGH_LIMIT': 360.0, 'DRIVER_TYPE': 'bluetooth', 'LOW_LIMIT': -360.0}
2011-11-13 10:42:12,875::Main::DEBUG::PluginsManager.register(): added 'GigaPanBot' plugin with capacity 'yawAxis'
2011-11-13 10:42:12,875::Main::DEBUG::PluginsManager.register(): added 'GigaPanBot' plugin with capacity 'pitchAxis'
2011-11-13 10:42:12,875::Main::TRACE::GigaPanBotShutter._init()
2011-11-13 10:42:12,890::Main::TRACE::ShutterPlugin._init()
2011-11-13 10:42:12,890::Main::TRACE::AbstractHardwarePlugin._defineConfig()
2011-11-13 10:42:12,890::Main::TRACE::ShutterPlugin._defineConfig()
2011-11-13 10:42:12,890::Main::TRACE::AbstractPlugin._loadConfig()
2011-11-13 10:42:12,890::Main::DEBUG::AbstractPlugin._loadConfig(): config={'DRIVER_TYPE': 'bluetooth', 'PULSE_WIDTH_LOW': 250, 'BULB_ENABLE': False, 'MIRROR_LOCKUP': False, 'BRACKETING_NB_PICTS': 1, 'TIME_VALUE': 0.5, 'PULSE_WIDTH_HIGH': 250, 'TRIGGER_ONLY_ONCE': False}
2011-11-13 10:42:12,890::Main::DEBUG::PluginsManager.register(): added 'GigaPanBot' plugin with capacity 'shutter'
2011-11-13 10:42:12,890::Main::TRACE::GphotoBracketShutter._defineConfig()
2011-11-13 10:42:12,890::Main::DEBUG::AbstractPlugin._loadConfig(): config={'BRACKETING_EV_STEP': 1, 'BRACKETING_EV_LIST': '0', 'BRACKETING_PLUS_STEP': 1, 'MIRROR_LOCKUP_COMMAND': 'gphoto2 --capture-image', 'MIRROR_LOCKUP': False, 'DOWNLOAD_DIR': 'C:\\Documents and Settings\\mamoo', 'BRACKETING_MINUS_STEP': 1, 'DOWNLOAD_ENABLE': False, 'BRACKETING_NB_PICTS': 1, 'BRACKETING_MINUS_NB_PICTS': 0, 'BRACKETING_EV_BIAS': 0, 'BRACKETING_ADVANCED': False, 'BRACKETING_PLUS_NB_PICTS': 0, 'DOWNLOAD_THEN_DELETE': False, 'PROGRAM_PATH': 'gphoto2', 'DOWNLOAD_AFTER': u'Each shot'}
2011-11-13 10:42:12,890::Main::DEBUG::PluginsManager.register(): added 'Gphoto Bracket' plugin with capacity 'shutter'
2011-11-13 10:42:12,905::Main::TRACE::MerlinOrionAxis._init()
2011-11-13 10:42:12,905::Main::TRACE::AbstractHardwarePlugin._defineConfig()
2011-11-13 10:42:12,905::Main::TRACE::AbstractPlugin._loadConfig()
2011-11-13 10:42:12,905::Main::DEBUG::AbstractPlugin._loadConfig(): config={'HIGH_LIMIT': 360.0, 'ALTERNATE_DRIVE_ANGLE': 7.0, 'INERTIA_ANGLE': 1.0, 'DRIVER_TYPE': u'serial', 'LOW_LIMIT': -360.0, 'ALTERNATE_DRIVE': False}
2011-11-13 10:42:12,905::Main::DEBUG::PluginsManager.register(): added 'Merlin-Orion' plugin with capacity 'yawAxis'
2011-11-13 10:42:12,921::Main::DEBUG::AbstractPlugin._loadConfig(): config={'HIGH_LIMIT': 360.0, 'ALTERNATE_DRIVE_ANGLE': 7.0, 'INERTIA_ANGLE': 1.0, 'DRIVER_TYPE': u'serial', 'LOW_LIMIT': -360.0, 'ALTERNATE_DRIVE': False}
2011-11-13 10:42:12,921::Main::TRACE::MerlinOrionAxis._init()
2011-11-13 10:42:12,921::Main::TRACE::AbstractHardwarePlugin._defineConfig()
2011-11-13 10:42:12,921::Main::TRACE::AbstractPlugin._loadConfig()
2011-11-13 10:42:12,921::Main::DEBUG::PluginsManager.register(): added 'Merlin-Orion' plugin with capacity 'pitchAxis'
2011-11-13 10:42:12,921::Main::TRACE::MerlinOrionShutter._init()
2011-11-13 10:42:12,921::Main::TRACE::ShutterPlugin._init()
2011-11-13 10:42:12,921::Main::TRACE::ShutterPlugin._defineConfig()
2011-11-13 10:42:12,921::Main::DEBUG::AbstractPlugin._loadConfig(): config={'DRIVER_TYPE': u'serial', 'PULSE_WIDTH_LOW': 250, 'BULB_ENABLE': False, 'MIRROR_LOCKUP': False, 'BRACKETING_NB_PICTS': 1, 'TIME_VALUE': 0.5, 'PULSE_WIDTH_HIGH': 250, 'TRIGGER_ONLY_ONCE': False}
2011-11-13 10:42:12,937::Main::TRACE::ShutterPlugin._init()
2011-11-13 10:42:12,937::Main::TRACE::AbstractHardwarePlugin._defineConfig()
2011-11-13 10:42:12,937::Main::TRACE::ShutterPlugin._defineConfig()
2011-11-13 10:42:12,937::Main::TRACE::AbstractPlugin._loadConfig()
2011-11-13 10:42:12,937::Main::DEBUG::AbstractPlugin._loadConfig(): config={'DRIVER_TYPE': u'serial', 'PULSE_WIDTH_LOW': 250, 'BULB_ENABLE': False, 'MIRROR_LOCKUP': False, 'BRACKETING_NB_PICTS': 1, 'TIME_VALUE': 0.5, 'PULSE_WIDTH_HIGH': 250, 'TRIGGER_ONLY_ONCE': False}
2011-11-13 10:42:12,937::Main::DEBUG::PluginsManager.register(): added 'Merlin-Orion' plugin with capacity 'shutter'
2011-11-13 10:42:12,937::Main::DEBUG::NkRemoteShutter._defineConfig()
2011-11-13 10:42:12,937::Main::DEBUG::AbstractPlugin._loadConfig(): config={'USER_EXPOSURE_COMPENSATION_LIST': '-2, 0, +2', 'DRY_RUN': False, 'MIRROR_LOCKUP': False, 'FILENAME_PREFIX': '', 'CAMERA_EXPOSURE_COMPENSATION_LIST': u'\xb15@1/2', 'OUTPUT_DIR': 'C:\\Documents and Settings\\mamoo', 'PROGRAM_PATH': 'C:\\Program Files\\BreezeSys\\NKRemote\\NKRemoteLibTest.exe'}
2011-11-13 10:42:12,937::Main::DEBUG::PluginsManager.register(): added 'NK Remote' plugin with capacity 'shutter'
2011-11-13 10:42:12,953::Main::TRACE::PanoduinoAxis._init()
2011-11-13 10:42:12,953::Main::TRACE::AbstractHardwarePlugin._defineConfig()
2011-11-13 10:42:12,953::Main::TRACE::AbstractPlugin._loadConfig()
2011-11-13 10:42:12,953::Main::DEBUG::AbstractPlugin._loadConfig(): config={'NEUTRAL_POSITION': 1000, 'HIGH_LIMIT': 360.0, 'DIRECTION': u'forward', 'ANGLE_1MS': 315.0, 'ACCEL': 1, 'LOW_LIMIT': -360.0, 'DRIVER_TYPE': 'bluetooth', 'ADDITIONAL_DELAY': 0.5, 'SPEED': 5, 'CHANNEL': 0}
2011-11-13 10:42:12,953::Main::DEBUG::PluginsManager.register(): added 'Panoduino' plugin with capacity 'yawAxis'
2011-11-13 10:42:12,953::Main::DEBUG::AbstractPlugin._loadConfig(): config={'NEUTRAL_POSITION': 1500, 'HIGH_LIMIT': 360.0, 'DIRECTION': u'reverse', 'ANGLE_1MS': 330.0, 'ACCEL': 1, 'LOW_LIMIT': -360.0, 'DRIVER_TYPE': 'bluetooth', 'ADDITIONAL_DELAY': 0.5, 'SPEED': 5, 'CHANNEL': 1}
2011-11-13 10:42:12,953::Main::DEBUG::PluginsManager.register(): added 'Panoduino' plugin with capacity 'pitchAxis'
2011-11-13 10:42:12,953::Main::TRACE::PanoduinoShutter._init()
2011-11-13 10:42:12,953::Main::TRACE::ShutterPlugin._init()
2011-11-13 10:42:12,953::Main::TRACE::ShutterPlugin._defineConfig()
2011-11-13 10:42:12,967::Main::DEBUG::AbstractPlugin._loadConfig(): config={'DRIVER_TYPE': 'bluetooth', 'PULSE_WIDTH_LOW': 250, 'BULB_ENABLE': False, 'MIRROR_LOCKUP': False, 'SHUTTER_ON': 2000, 'SHUTTER_OFF': 1000, 'BRACKETING_NB_PICTS': 1, 'TIME_VALUE': 0.5, 'CHANNEL': 2, 'PULSE_WIDTH_HIGH': 250, 'TRIGGER_ONLY_ONCE': False}
2011-11-13 10:42:12,967::Main::DEBUG::PluginsManager.register(): added 'Panoduino' plugin with capacity 'shutter'
2011-11-13 10:42:12,967::Main::TRACE::PixOrbAxis._init()
2011-11-13 10:42:12,967::Main::TRACE::AbstractHardwarePlugin._defineConfig()
2011-11-13 10:42:12,967::Main::TRACE::AbstractPlugin._loadConfig()
2011-11-13 10:42:12,967::Main::DEBUG::AbstractPlugin._loadConfig(): config={'AXIS_ACCURACY': 0.10000000000000001, 'HIGH_LIMIT': 360.0, 'DRIVER_TYPE': 'bluetooth', 'LOW_LIMIT': -360.0, 'SPEED_INDEX': 9, 'AXIS_WITH_BREAK': False}
2011-11-13 10:42:12,967::Main::DEBUG::PluginsManager.register(): added 'PixOrb' plugin with capacity 'yawAxis'
2011-11-13 10:42:12,983::Main::DEBUG::PluginsManager.register(): added 'PixOrb' plugin with capacity 'pitchAxis'
2011-11-13 10:42:12,983::Main::TRACE::PixOrbShutter._init()
2011-11-13 10:42:12,983::Main::TRACE::ShutterPlugin._init()
2011-11-13 10:42:12,983::Main::TRACE::AbstractHardwarePlugin._defineConfig()
2011-11-13 10:42:12,983::Main::TRACE::ShutterPlugin._defineConfig()
2011-11-13 10:42:12,983::Main::TRACE::AbstractPlugin._loadConfig()
2011-11-13 10:42:12,983::Main::DEBUG::AbstractPlugin._loadConfig(): config={'DRIVER_TYPE': 'bluetooth', 'PULSE_WIDTH_LOW': 250, 'BULB_ENABLE': False, 'MIRROR_LOCKUP': False, 'BRACKETING_NB_PICTS': 1, 'TIME_VALUE': 0.5, 'PULSE_WIDTH_HIGH': 250, 'TRIGGER_ONLY_ONCE': False}
2011-11-13 10:42:12,983::Main::DEBUG::PluginsManager.register(): added 'PixOrb' plugin with capacity 'shutter'
2011-11-13 10:42:12,983::Main::DEBUG::AbstractPlugin._loadConfig(): config={'HIGH_LIMIT': 360.0, 'SPEED': 30, 'LOW_LIMIT': -360.0}
2011-11-13 10:42:12,983::Main::DEBUG::PluginsManager.register(): added 'Simulation' plugin with capacity 'yawAxis'
2011-11-13 10:42:13,000::Main::DEBUG::PluginsManager.register(): added 'Simulation' plugin with capacity 'pitchAxis'
2011-11-13 10:42:13,000::Main::TRACE::AbstractShutterPlugin._defineConfig()
2011-11-13 10:42:13,000::Main::TRACE::AbstractPlugin._loadConfig()
2011-11-13 10:42:13,000::Main::DEBUG::AbstractPlugin._loadConfig(): config={'TIME_VALUE': 0.5, 'TRIGGER_ONLY_ONCE': False, 'BRACKETING_NB_PICTS': 1, 'MIRROR_LOCKUP': False}
2011-11-13 10:42:13,000::Main::DEBUG::PluginsManager.register(): added 'Simulation' plugin with capacity 'shutter'
2011-11-13 10:42:13,000::Main::TRACE::TimelordShutter._defineConfig()
2011-11-13 10:42:13,000::Main::DEBUG::AbstractPlugin._loadConfig(): config={'PROGRAM_PATH': 'C:\\Program Files\\OxfordEye\\Timelord\\Timelord.exe', 'LRD_FILE': 'C:\\Documents and Settings\\win2k\\My Documents\\timelord.lrd'}
2011-11-13 10:42:13,000::Main::DEBUG::PluginsManager.register(): added 'Timelord' plugin with capacity 'shutter'
2011-11-13 10:42:13,000::Main::TRACE::UrsaMinorBt2Shutter._init()
2011-11-13 10:42:13,000::Main::TRACE::ShutterPlugin._init()
2011-11-13 10:42:13,000::Main::TRACE::UrsaMinorBt2Shutter._defineConfig()
2011-11-13 10:42:13,015::Main::TRACE::AbstractHardwarePlugin._defineConfig()
2011-11-13 10:42:13,015::Main::TRACE::ShutterPlugin._defineConfig()
2011-11-13 10:42:13,015::Main::TRACE::AbstractPlugin._loadConfig()
2011-11-13 10:42:13,015::Main::DEBUG::AbstractPlugin._loadConfig(): config={'DRIVER_TYPE': 'bluetooth', 'PULSE_WIDTH_LOW': 250, 'BULB_ENABLE': False, 'MIRROR_LOCKUP': False, 'FOCUS_PULSE_WIDTH': 0.5, 'FOCUS_MAINTAIN': False, 'BRACKETING_NB_PICTS': 1, 'TIME_VALUE': 0.5, 'FOCUS_ENABLE': False, 'PULSE_WIDTH_HIGH': 250, 'TRIGGER_ONLY_ONCE': False}
2011-11-13 10:42:13,015::Main::TRACE::UrsaMinorBt2Shutter._init()
2011-11-13 10:42:13,015::Main::TRACE::ShutterPlugin._init()
2011-11-13 10:42:13,015::Main::TRACE::UrsaMinorBt2Shutter._defineConfig()
2011-11-13 10:42:13,015::Main::DEBUG::PluginsManager.register(): added 'Ursa Minor BT2' plugin with capacity 'shutter'
2011-11-13 10:42:13,015::Main::TRACE::UrsaMinorUsbShutter._init()
2011-11-13 10:42:13,030::Main::TRACE::UrsaMinorUsbShutter._defineConfig()
2011-11-13 10:42:13,030::Main::TRACE::AbstractHardwarePlugin._defineConfig()
2011-11-13 10:42:13,030::Main::TRACE::ShutterPlugin._defineConfig()
2011-11-13 10:42:13,030::Main::TRACE::AbstractPlugin._loadConfig()
2011-11-13 10:42:13,030::Main::DEBUG::AbstractPlugin._loadConfig(): config={'DRIVER_TYPE': 'bluetooth', 'PULSE_WIDTH_LOW': 250, 'BULB_ENABLE': False, 'MIRROR_LOCKUP': False, 'TRIGGER_LINE_INVERTED': False, 'BRACKETING_NB_PICTS': 1, 'TRIGGER_LINE': 'RTS', 'TIME_VALUE': 0.5, 'PULSE_WIDTH_HIGH': 250, 'TRIGGER_ONLY_ONCE': False}
2011-11-13 10:42:13,030::Main::DEBUG::PluginsManager.register(): added 'Ursa Minor USB' plugin with capacity 'shutter'
2011-11-13 10:42:13,030::Main::TRACE::ClaussAxis._init()
2011-11-13 10:42:13,030::Main::DEBUG::AbstractPlugin._loadConfig(): config={'HIGH_LIMIT': 360.0, 'PARK_POSITION': '0.', 'SPEED_FAST': 100, 'DRIVER_TYPE': 'bluetooth', 'LOW_LIMIT': -360.0, 'PARK_ENABLE': False, 'SPEED_NORMAL': 50, 'SPEED_SLOW': 10}
2011-11-13 10:42:13,030::Main::DEBUG::PluginsManager.register(): added 'Clauss' plugin with capacity 'yawAxis'
Logging is the second part was published.
I hope to hang on to identify the cause of this log.
Best regads.
Blog:http://uhrp.imagefitter.com/
Panogear(FW 020781);BT (Serial COM40);Pw(FW 2.1.20-1);Dell vostro1200(xp sp3)
TouchCP(FW 2.0) Autopano Giga(v2.0.9)
Nikon D300S;Nikkor AF 28-200mm;Nikkor AF-S 300mm
by fma38 » Wed Nov 16, 2011 7:27 am
Has said in the other thread: communication problems.
