TC-Controller+Merlin+APG: How to get 360°x180° (with full nadir)
Undertable
by Undertable » Mon Aug 22, 2011 7:20 pm
Hi community,
last weekend I tried to produce equirectangular (spheric) panoramas by the use of Canon EOS400D+50mm prime lens and Merlin-head for the first time controlled by TC-Controller.
My first impression of TC-Control is very good. It seems easy to use and I believe that in fact Merklin head moves faster as with Nokia Tablet.
I typed in the sensor-size, lens data and selceted "spheric" pano (20% overlap).
TC-Control calculated the necessary number of shoots and started the sequence.
After this I connected TC-Control to the PC and selected "readout" so that the associated .xml. with positioning data was generated.
In AutopanoGiga I imported the .xml and the associated pics.
I started detection (use hard links) and the result was actually good.
And now the only problem: probably because of merlin`s big footprint (battery housing) TC-Control droped the nadir pics.
I know that merlin head is rather applicative for Gigapixel panos than for full 360°x180° spherical panos but I own this head and I would like to produce also such panos even if more retouching is necessary.
For nadir retouching I usually open the stitched panoramic pic in Pano2VR.
I chose a new correction, pan -90° downwards (nadir position) and extract this nadir shot to retouch it in photoshop then.
Normally I get either the tripod/pano head or simply a hole in this shot but now there is no hole.
Around the area of missing nadir-images the stitched pano-pic is pulled together and useless for my purpose.
In APG I tried to extend the missing area before rendering without success.
In papywizard on the nokia tablet I would modify the .xml to get those nadir-shots but in TC-Control the .xml was generated afterwards so I have no effect on it.
What can I do to get this hole (or image of merlin`s battery cover) for retouching?
Regards Oliver
by mediavets » Mon Aug 22, 2011 8:02 pm
Regards Oliver
Force a 360x180 pano FOV in APG.
Undertable
by Undertable » Mon Aug 22, 2011 9:15 pm
Hi Andrew,
I tried it out and that`s it - problem solved
Thank You very much!
