Strange system behavior
surami
by surami » Fri Aug 12, 2011 4:22 pm
I'm using/controlling Merlin head with Windows 7 64 bit + Papywizard 2.1.21 + Ursaminor Bluetooth interface.
I did some test shoot-circles (without DSLR, but with trigger cable, because I need rail and plate too to set NPP. So only headmove, preset: 6@0 + Z + N) and I got only one or two succesfull circles from start to the end spots.
Different examples for behavior:
1: The head stopped working between to horizontal spots, the BT interface light was continous, PW was frozen.
2: The vertical motor of the head was moving from Zenith to Nadir, so between the two spots the motor got slower and slower and gave unusual high-pitched voice, I have to turn it of manualy, PW was frozen after swith OFF.
Strange, because when I move the head with Goto function, the head, the PW and the BT works very well without strange behaviors.
I don't know where is the bug in the system...
surami
by mediavets » Fri Aug 12, 2011 4:35 pm
Can you move the head using the arrow icons on both axes without any problem?
The other thing that can sometimes affect positioning is if light leaks through the base of the bubble level and affects the optical encoders.
Check that the base of the bubble level (inside the battery compartment) is opaque. If not cover it with some opaque tape or paint.
Are you isng internal battries or an external power source?
If internal batteries, what type? AA NiMH rechargable or the Panogear Li-Ion battery conversion.
surami
by surami » Fri Aug 12, 2011 6:10 pm
mediavets wrote:Can you move the head using the arrow icons on both axes without any problem?
No.
mediavets wrote:The other thing that can sometimes affect positioning is if light leaks through the base of the bubble level and affects the optical encoders.
The base of the bubble level is opaque, but I just covered the whole bubble level and possible leaks outside with some black textile.
mediavets wrote:Are you isng internal battries or an external power source?
I'm using external 12V power source (network + 12V adapter) at the hole OUT (as manual said, I have to connect their).
surami
by mediavets » Fri Aug 12, 2011 8:22 pm
No.
So what happens when you use the arrow icons to move the head.
Do you get movement on the Yaw axis?
Do you get movement on the Pitch axis?
by mediavets » Fri Aug 12, 2011 8:24 pm
It may make no difference but I always connect my external 12V battery pack to the IN socket.
surami
by surami » Sat Aug 13, 2011 10:19 am
mediavets wrote:So what happens when you use the arrow icons to move the head.
I don't get any movements on both axis.
mediavets wrote:It may make no difference but I always connect my external 12V battery pack to the IN socket.
I thought too, that I have to connect the power to IN socket, but I read in manual that I should connect to OUT... I didn't find logic in this.
surami
by fma38 » Sat Aug 13, 2011 1:25 pm
Have a look to the logs to see if there are strange things...
surami
by surami » Wed Aug 24, 2011 9:35 am
fma38 wrote:Have a look to the logs to see if there are strange things...
Which line do we need?
ps: sorry for the lately answer, I on holiday.
surami
by fma38 » Wed Aug 24, 2011 10:08 am
Look for warnings or errors...
surami
by surami » Wed Sep 07, 2011 10:57 pm
fma38 wrote:Look for warnings or errors...
I couldn't look into the log after the head stopped, the problem "killed" the Papywizard too.
But... I was in the shop today, where I bought the head and it seems the Merlin was the bad thing in the system, so I got another one and it works now. :)
surami
