[Papywizard v2] New plugins - MacOS package - Translations
by fma38 » Fri Feb 04, 2011 10:10 am
Some new plugins have been developed by Papywizard users, for both DIY and commercial panoheads. I think it is time to put these plugins in the core of Papywizard.
So, guys, could you send me your current versions? I would like to release a new dev. version of Papywizard, with these plugins, and, if possible, a new stable release.
I would also like to add the needed files to generate the MacOS package; could someone from the Kolor team send them to me?
Last, it should be nice to update the Translation. I would like to know if all translators will have time to work on it?
Thanks!
Paul
by Paul » Fri Feb 04, 2011 10:20 am
fma38 wrote:Last, it should be nice to update the Translation. I would like to know if all translators will have time to work on it?
Yes, glad to help.
Paul
pu2wxp
by pu2wxp » Tue Feb 08, 2011 5:54 pm
Yes, glad to help.
Yes, i cando it to brasilian portuguese
Luciano Correa
Vista Panoramica
Campos do Jordao SP Brasil
by fma38 » Sat Mar 19, 2011 8:24 am
The plugin for the Clauss Rodeon head, written by Matrin Loyer, has been integrated in Papywizard main branch.
Greg, could you send me your OWL plugin, so I can make a quick review, and add it to Papywizard core? Then I will release the 2.1.21 version...
