papywizard on a mac
mawa_73527
papywizard on a mac
by mawa_73527 » Fri Jan 21, 2011 7:05 am
anyone using pappywiard on a mac?
If so which version and which setup do you use? Do you use the internal BT transmitter or an external one?
I simply cannot get my pappywizard to work on a macbook pro with the latest os!
would appreciate some feedback!
Matthias
by fma38 » Fri Jan 21, 2011 7:18 am
AFAIK, you need an external bluetooth dongle...
120to120
by 120to120 » Fri Jan 21, 2011 8:01 am
Hi mawa,
mit einem ext. bluetooth dongle bist du auf der sicheren Seite.
(*Merlin/Orion_BT - teleskop-austria.*); FTDI USB-TTL cable; Macbook (Intel) OS X10.5.6 / ext. Bluetooth Dongle_VIVANCO_B1002270209 / PW 2.1.20; Go-To / TA *Nokia N810 / PW 2.1.20 * Sony F717 / Sony R1 ; JJC SR-828; 15m Mast;
mawa_73527
by mawa_73527 » Fri Jan 21, 2011 8:29 am
welchen Dongle verwendest du?
120to120 wrote:Hi mawa,
vincen
Kolor Certified Trainer
Likes: 23 posts
Liked in: 4 posts
by vincen » Fri Jan 21, 2011 8:58 am
You have to use Papywizard 2.0 and not 2.1 if you are working with Snow Leopard (Mac OSX 10.6) and it should work fine. YOu have to pair the head with the Bluetooth of the Mac in Settings Preferences in Mac OSX and setup Papywizard to use the serial port of that pairing. We updated documentation of Panogear so it should help you ;) http://www.kolor.com/buydev/media/pages/products/panohead/panogear-manuel-en.pdf
Blog: http://www.skivr.com
mawa_73527
by mawa_73527 » Fri Jan 21, 2011 9:18 am
vincen wrote:You have to use Papywizard 2.0 and not 2.1 if you are working with Snow Leopard (Mac OSX 10.6) and it should work fine. YOu have to pair the head with the Bluetooth of the Mac in Settings Preferences in Mac OSX and setup Papywizard to use the serial port of that pairing. We updated documentation of Panogear so it should help you ;) http://www.kolor.com/buydev/media/pages/products/panohead/panogear-manuel-en.pdf
Yes, thanks I know that. My problem is that everything is working except when I press shoot it will not work! I am currently using the internal BT of my macbook pro
vincen
Likes: 23 posts
Liked in: 4 posts
by vincen » Fri Jan 21, 2011 9:20 am
mawa_73527 wrote:Yes, thanks I know that. My problem is that everything is working except when I press shoot it will not work! I am currently using the internal BT of my macbook pro
Are you at least able to move head with arrows in Papywizard application ? Do you succeed to establish connection between Papywizard and head ?
Vincèn
mawa_73527
by mawa_73527 » Fri Jan 21, 2011 9:22 am
Vincèn
Yes I can do this the head will move with the arrows ... the connection is good ... only when I press shoot I get error messages in the log something about axis1 or 2 cannot be set!
by fma38 » Fri Jan 21, 2011 12:37 pm
I propose we switch on this thread:
http://www.autopano.net/forum/t10995-shutter-release-is-not-workong
as it is only problem remaining.
