Im stupid, how do I setup plugins, shoot.py & Eos Utility
GRADGUY
by GRADGUY » Mon Sep 27, 2010 3:44 am
I'm having a lot of difficulty setting up Pappy Wizard and could use some explantion of whats should be done.
My setup is a Canon EOS 5D Mark II and I would like to run the EOS utility for bracketing / triggering.
I'm failing to understand how to set up the Autohotkey and Pappy Wizard plugin to synchronize everything correctly.
I've complied the code and have a EOSBracket.exe in my C:\Program Files\Papywizard directory. Also in that directory I have EOSBracket.ahk
In my "C:\Users\gradguy\AppData\Roaming\papywizard2\plugins" I have the newEOSplugin.py. Though I am not sure it that is the correct location for the plugins folder. I created it as it was not there to begin with nor was it anywhere else for that matter. So I placed the in that folder.
In Pappy Wizard I am not getting the preferences menu that I should now have.
Lastly I'm not sure where to get or make a shoot.py... or where it should go once I get it...
Anyway any help would great.
by fma38 » Mon Sep 27, 2010 6:31 am
I think you are not using the correct version of Papywizard; I suggest you use the latest dev. release (2.1.20).
GRADGUY
by GRADGUY » Mon May 21, 2012 2:33 am
Hi Fredric...
I downloaded it and to my great joy it worked. However I am now experiencing a rather annoying issue where the up and down control are reversed. I thought this could be adjusted under pappywizard's shooting menu. I have tried several combinations and nothing seems to reverse the pitch control in pappywizard. Because my canon g10's ports are all on its right side I can't rotate the camera around to face the other direction.
My other question is there a keyboard shutter release hotkey. I remember that one pappywizard version had trigger release under a menu item. But I haven't seen it in this latest build.
Any thoughts?
Thanks the reply.
Cheers,
by mediavets » Mon May 21, 2012 6:42 am
GRADGUY wrote:Hi Fredric...
I downloaded it and to my great joy it worked. However I am now experiencing a rather annoying issue where the up and down control are reversed. I thought this could be adjusted under papywizard's shooting menu. I have tried several combinations and nothing seems to reverse the pitch control in papywizard. Because my canon g10's ports are all on its right side I can't rotate the camera around to face the other direction.
Set the value for Pitch arm side to 'left' and for Camera orientation to 'landscape' - see screenshot 1.
My other question is there a keyboard shutter release hotkey. I remember that one Papywizard version had trigger release under a menu item. But I haven't seen it in this latest build.
Any thoughts?
It's under the Hardware menu - See screenshot 2.
