Critical Error - cannot write into file
mbeaudry
by mbeaudry » Fri Aug 20, 2010 12:05 am
Hi All,
I was happily moving along and suddenly, I received the following critical error message when I tried to render:
cannot write into file "C:/documents and settings/User Name/Local Settings/Temp/APP2_Blended Layer.tif"
I didn't have any funky naming schemes.
Can anyone offer suggestions?
Thanks,
Martha
mbeaudry
by mbeaudry » Fri Aug 20, 2010 1:04 am
I rebooted my computer. That seemed to have solved the problem. *sheepis grin*
hankkarl
by hankkarl » Fri Aug 20, 2010 4:55 am
Now you should write a "thank you" note to Bill Gates :)
leedsjoe
by leedsjoe » Fri Aug 20, 2010 6:26 am
I would like someone else to confrim this but I seem to recall getting this message as one of the (many possible) symptoms of memory getting low. Kolor have done work to improve memory management but haven't removed all the problems.
zdepski
by zdepski » Sat Jul 09, 2011 1:46 pm
Having exactly the same problem.
However, it is only rarely resolved by a complete restart.
Have 24 GIG Ram on a Windows 7 Service Pack Intel.
Tried adjusting the RAM in preferences, with no change.
Only stiching 30 - 50 1900x1200 images.
by mediavets » Sat Jul 09, 2011 1:58 pm
zdepski wrote:Having exactly the same problem.
Which version of APP or APG are you using?
zdepski
by zdepski » Sat Jul 09, 2011 2:02 pm
Giga 2.52 (Trial Version) 64 Bit
Testing software prior to University purchase.
by AlexandreJ » Mon Jul 11, 2011 10:20 am
Can you try changing the default temp folder (restart autopano) before doing the rendering ?
Sometimes, the default folder can have strange authorization.
