Any idea how can i stitch these images?
OfF3nSiV3
by OfF3nSiV3 » Tue Jul 07, 2009 1:02 am
I took some photos of a circular object while moving, ie, i moved around the object and took photos, but Autopano (and others) are having a hard time stitching the thing. I upload the photos if anyone is willing to experiment.
Download pics
I know this is a big no no, but i managed to do the same to a straight wall (below).
digipano
by digipano » Tue Jul 07, 2009 6:00 am
I see many problems
You were too close to the subject fore ground which will not let you stitch perfectly, then your moment was irregular with different amount of overlap. I tried stitching them & found that not even (any) 2 images overlap perfectly so how would you get the final pano.
I have done 2 such panos from top of a crane & they were fine as I measured the outer ring on which I moved in equal distance & the scene was distant not so close, they worked fine for me.
wjh31
by wjh31 » Tue Jul 07, 2009 8:53 am
while the pictures download for me to try, i suggest to try changing the focal length in the image settings when you import them
now i have downloaded and had a look:
For a little hint as to why i suggested changing the focal length, see this thread: http://www.autopano.net/forum/t6053-linear-panoramas
taking your example of the straight wall, taking photos at low focal length moving along, is similar to taking photos from far away with a telel lens from an NPP, in doing this you are seeking an architectural projection, i.e an image like an architectureal drawing, its probably not actually called that (maybe more like http://en.wikipedia.org/wiki/Orthographic_projection). So you can kid APP into doing this be changing the focal length to something huge in the settings when you import the pictures. However this obviously is way off the NPP so will cause alot of parallax issues. But fortunately, parallax issues only happen when things are different distances from the camera. In your shot down the wall, everything is one distance from the camera, i.e its just the wall so it can stitch without too many errors, although id bet there are a few errors on the ground closer to the camera. With your second circular image, there are huge parallax issues, objects are at all sorts of different lengths from the camera, so whatever way you get them to stitch, you are going to get some crazy errors. With some carefull CP manipulation, you could get the foreground or background to be consistent, but not both, whichever isnt aligned properly is going to look awful. I have experimented with this sort of shot moving down a wall (http://lifeinmegapixels.com/location.php?location=kings3) which features both sections where everything is just one distance, and bits where things are all depths from the camera. You can see how the parts of consistend distance look nice and work well, but the other parts, e.g where the cars are parked closer to the camera are covered in ugly errors.
So no, its not a 'big no no' as you say, APP is meant for trying out new things and figureing out what the software can do beyond what it is merely meant to do, but for these types of images, there are just a couple of things you need to consider to make them work
OfF3nSiV3
by OfF3nSiV3 » Tue Jul 07, 2009 12:47 pm
i forgot to mention that i did try setting the focal length to 1000mm
i shall experiment with this technique, as i only did it once (the wall)
thank you guys
by mediavets » Tue Jul 07, 2009 1:02 pm
OfF3nSiV3 wrote:I took some photos of a circular object while moving, ie, i moved around the object and took photos, but Autopano (and others) are having a hard time stitching the thing. I upload the photos if anyone is willing to experiment.
Download pics
http://filipefreitas.net/blog/wp-content/uploads/2008/06/smartblend0000.jpg
Can't be done with APP/APG - what you are effectively trying to do is to make an object movie.
http://gardengnomesoftware.com/object2vr.php
The wall is a different issue altogether - this is essentially an orthogonal projection.
