Can someone straighten his pano? Need Help.
harryshin
by harryshin » Sat Jun 20, 2009 7:19 am
hi:
1. i'm having a very tough time trying to straighten this pano. i've tried the automatic leveling feature (didn't work). i then tried using the vertical line method--> i was able to straighten out the ocean horizon, but the ends of the pano was then problematic. what's frustrating is that i can get a very straight pano via stitcher, however the actual stitch job isn't as good as autopano. i wish one application would have the best of both worlds.
2. anyway, if anyone has a solution to this problem, i'd be much appreciated etc...
thanks. harry shin
digipano
by digipano » Sat Jun 20, 2009 11:31 am
This is a tough one for APP if the auto horizon tool cant align.
I recently witnessed a similar situation & I turned the pano 90° & then used vertical align tool by drawing the line on the horizon, that did the job & I again did -90°.
Try my method it might work in this case too.
OfF3nSiV3
by OfF3nSiV3 » Sun Jun 21, 2009 3:14 pm
i find beach panoramas very hard to align
i should try digipano's way to do it
[bo]
by [bo] » Mon Jun 22, 2009 7:58 am
Check the CPs! I've had plenty of those panos. Usually the problem is that in one set of images the CPs are set on the foreground and in another - on the far away landscape. What I do is set all CPs in all image pairs to the medium distance (by deleting the "wrong" ones first and adding new ones), then optimize and that's that.
