No Render icon
mwr
No Render icon
by mwr » Sun Jan 25, 2009 6:16 pm
I just downloaded and installed APP v1.4.2 Trial Version and I can't see any Render icon; also can't get render to run by using the "Auto render" option. The Batch Render icon is present but no other Render icon. I may be missing something basic here.
by mediavets » Sun Jan 25, 2009 6:32 pm
mwr wrote:I just downloaded and installed APP v1.4.2 Trial Version and I can't see any Render icon; also can't get render to run by using the "Auto render" option. The Batch Render icon is present but no other Render icon. I may be missing something basic here.
Did you check out the video tutorial?:
http://www.autopano.net/wiki/action/view/Your_first_panorama
mwr
by mwr » Sun Jan 25, 2009 6:58 pm
The video stopped playing before I got very far into it, but I did see the split screen so then found the Split 50% option which displayed the rendered pano (I assume from the Auto Render option) and also the Render icon. I wasn't displaying that view at all. Thanks!
mediavets wrote:Did you check out the video tutorial?:
by mediavets » Sun Jan 25, 2009 7:26 pm
See these two screenshots - the Edit button opens the second screenshot (Editor) view and from there select the Render icon (blue cogwheel).
OK? This had me 'fooled' when I started out too - "where's the render button?"
