3 of 4 images imported
gcarr
by gcarr » Wed Jan 14, 2009 9:33 pm
I have 4 images and when I imported them they showed up as attached. However when I clicked the arrow only 3 images were transferred. The message states that the stitching quality is very good - 2.68. The image missing is well lit and sharp. Why would it not be transferred? Image 1,2,3 is missing.
by mediavets » Wed Jan 14, 2009 9:43 pm
Upload the images somewhere where I can download them and I'll tell you why?
hankkarl
by hankkarl » Thu Jan 15, 2009 1:52 pm
Try selecting "force every image to be in the same panorama" see http://www.autopano.net/wiki/action/view/Application_Settings#Detection
by klausesser » Thu Jan 15, 2009 3:40 pm
gcarr wrote:I have 4 images and when I imported them they showed up as attached. However when I clicked the arrow only 3 images were transferred. The message states that the stitching quality is very good - 2.68. The image missing is well lit and sharp. Why would it not be transferred? Image 1,2,3 is missing.
Did you try "detection=high" in the editor?
beeloba
by beeloba » Thu Jan 15, 2009 3:53 pm
Other suggestion…
As it is tonne-mapped tif, you may have some mess in the exif, can you check in the detection properties if the focal length is correct.
by GURL » Fri Jan 16, 2009 11:01 am
beeloba wrote:you may have some mess in the exif, can you check in the detection properties if the focal length is correct.
"No EXIF" is displayed in the bottom left corner of the screen capture.
My guess is that this should not prevent correct control points placement but could result in a somewhat distorted pano. Anyway, manually entering the corect focal length will no hurt!
As displayed in the capture, thumbnails are very small, but it looks like the overlap between some of them is not large enough.
gcarr
by gcarr » Fri Jan 16, 2009 11:35 pm
hankkarl wrote:Try selecting "force every image to be in the same panorama" see http://www.autopano.net/wiki/action/view/Application_Settings#Detection
tried that and the result SAID 4 images imported however there was no change - still the same three.
gcarr
by gcarr » Fri Jan 16, 2009 11:36 pm
mediavets wrote:Upload the images somewhere where I can download them and I'll tell you why?
I sent you the email- did you not receive?
Gary
gcarr
by gcarr » Fri Jan 16, 2009 11:45 pm
IT WORKED! However the lake is not joined well 'note '
Thank you.
gcarr
by gcarr » Fri Jan 16, 2009 11:54 pm
What do you mean by 'EXIF'? What is it ? Where is it"
Here is one I did that worked and I don't see EXIF anywhere.
by mediavets » Sat Jan 17, 2009 12:01 am
EXIF is data about the camera, lens and camera settings - it is normally stored within the image files.
Pre-processing images such as you did can strip this EXIF data from images.
APP uses the EXIF data, it can cause problems if it is missing.
gcarr
by gcarr » Sat Jan 17, 2009 4:37 pm
Hi Andrew - I'm using an Nikon D80 and shooting in aperture priority so focal length shouldn't be an issue. I assume when you say pre-processing you're referring to HDR. I did convert them them to HDR and THEN converted them in APP. Does APP then prevent you from processing in HDR?
I'm also on a MAC G5 OX10.
Thanks, Gary
gcarr
by gcarr » Sat Jan 17, 2009 4:39 pm
Georges - can you send me or show me an example of EXIF shown?
by mediavets » Sat Jan 17, 2009 4:56 pm
In APP, open a new group, add some images (just as they come from the camera with no pre-processing), double click on any image thumbnail and you get a window as shown below. You can see some of the EXIF data displayed on an overlay which can be toggled on/off via the EXIF button.
If you want to see all the EXIF data stored in your images then download the free Opanda EXIF viewer for Windows:
http://www.opanda.com/en/iexif/index.html
by mediavets » Sat Jan 17, 2009 5:02 pm
gcarr wrote:Hi Andrew - I'm using an Nikon D80 and shooting in aperture priority so focal length shouldn't be an issue. I assume when you say pre-processing you're referring to HDR. I did convert them them to HDR and THEN converted them in APP. Does APP then prevent you from processing in HDR?
Thanks, Gary
1. What does Aperture priority have to do with focal length?
2. Conversion to HDR before stitching will remove the EXIF data.
3. No, APP can stitch images that have been pre-processed as HDR or expsoure blenede or whatever.
4. Did you really need tone-mapped HDR images for input to APP?
5. Many people prefer exposure blending to HDR and tonemapping.
6. Very tongue in cheek and diving for cover as I write - I'm afraid I can't help you with your Mac handicap/addiction. ;)
gcarr
by gcarr » Sat Jan 17, 2009 8:26 pm
Thanks Andrew - I've always had an admiration for the British dry humor.
beeloba
by beeloba » Sat Jan 17, 2009 10:26 pm
This picture from Raynox contains Exif data… HERE The proper download link is THERE, save it as
Just open it in most of image editor and you'll see the data… in the info field or in APP :)
gcarr
by gcarr » Sun Jan 18, 2009 4:13 pm
mediavets wrote:
gcarr wrote:
GURL wrote:"No EXIF" is displayed in the bottom left corner of the screen capture.
This is too bizarre! Now I'm not getting any folders to open. I went step by step and nothing opens. I go to browsw folder and select choose folder with the 3 little dots. The folders on my desktop appear and I select the folder and click choose. NOTHING HAPPENS -see attachments. I have tried different folders with the same results.
gcarr
by gcarr » Mon Jan 19, 2009 2:12 am
Ok I went step by step. I rebooted my computer, I reset default settings and the same thing happens. I went to browse folder (3rd pic) and clicked and got a pop up (see pic 1) and clicked the 3 dots. I got another pop up showing folders on my desk top (see pic 2 - in this case I had already found the right folder so it automatically popped up). I click choose and it disappears and nothing.
What could the problem be?
by fma38 » Mon Jan 19, 2009 7:40 am
Did you try to activate the APP panels, with the buttons between the 'load pictures' and 'gear' ones?
gcarr
by gcarr » Mon Jan 19, 2009 2:51 pm
Thanks for replying Frederic - I don't know what/ where you mean. Which image above are you referring to? The first, second or third?
The third image has a blue 'gear' but I don't see 'load pictures or buttons. Perhaps you can help me here.
Thanks,
Gary
by fma38 » Mon Jan 19, 2009 2:59 pm
Try this icon...
gcarr
by gcarr » Mon Jan 19, 2009 2:59 pm
fma38 wrote:Did you try to activate the APP panels, with the buttons between the 'load pictures' and 'gear' ones?
It worked when I clicked 'load pictures' as oppose to browse folders. Why would that be? The tutorial says to click 'browse folders' first.
Gary
gcarr
by gcarr » Mon Jan 19, 2009 4:48 pm
Andrew - here is an image with no pre-processing and it has some information but nothing compared to yours that seems to be a Windows program that I can't work with on my Mac.
by mediavets » Mon Jan 19, 2009 4:54 pm
No, that's a stitched pano.
I mean images as they come from the camera - just as I said - please read my post again:
http://www.autopano.net/forum/p37161-2009-01-17-15-56-13#p37161
I expect you'll find an EXIF viewer for the Mac if you do a Google search.
