Kolor.com
Kolor.com
by klausesser » Thu Jan 08, 2009 12:39 am
Hi!
I told a friend to go to Kolor.com for downloading a beta APG version for a try-out.
He didn´t find a way to navigate to it. Failed. I tried myself - failed completely.
Honestly: this is one of the most terrible navigations i ever came across!
My friend gave up and argued not to buy an application which is so badly to navigate to . .
I mean you should do something about that.
I was on a journey, had no adress book with me and remembered only Kolor.com - there MUST be a way to go over Kolor.com to the Betas and to the forum, Wiki and so on.
Using Firefox on PC every change of an URL skips the language back to French.
by mediavets » Thu Jan 08, 2009 12:45 am
klausesser wrote:Hi!
He could have Googled 'autopano'?
by klausesser » Thu Jan 08, 2009 2:19 am
mediavets wrote:He could have Googled 'autopano'?
of course - but he´s right, i think. There´s always a workaround - but the more straight and elegant the better . . :cool:
DrSlony
by DrSlony » Thu Jan 08, 2009 3:05 am
Kolor.com? If you mean autopano.net, then Buy > Beta in the menu at the top.
by AlexandreJ » Thu Jan 08, 2009 7:58 am
For the moment, on kolor.com, you'll find only the webshop, nothing else.
In a few months, there will be the coorporate site too.
Everything related to product is located on product domains : for example autopano.net or xnview.com
I totally agree that there should be some link from kolor.com to the product site. That's a bad you cannot do it yet.
DrSlony
by DrSlony » Thu Jan 08, 2009 11:47 am
But for me "kolor.com" is:
Not Found
The requested URL / was not found on this server.
----update:
Ah, "www.kolor.com" works
