script Merlin/N800 import into APP
by klausesser » Wed Jan 07, 2009 9:20 pm
can i take the xml file from N800/Papy to import it in APP/APG Alpha?
by fma38 » Wed Jan 07, 2009 9:27 pm
Yes, sure.
by klausesser » Wed Jan 07, 2009 9:55 pm
fma38 wrote:Yes, sure.
Thanks! :cool:
by klausesser » Thu Jan 08, 2009 12:28 am
tried to do with APG on PC. Vista46. Imported the xml file - importing 44 images crashes APG.
No way to import the images otherwise. 44 JPGs, small.
Is there a special procedere?
by mediavets » Thu Jan 08, 2009 12:32 am
This may be because the APG alpha 2 Papywizard import filter cannot handle non-mosaic (regular matrix) panos?
I don't know if this is the case.
I have previously asked whether it can and have never received an answer.
by AlexandreJ » Thu Jan 08, 2009 8:12 am
mediavets wrote:This may be because the APG alpha 2 Papywizard import filter cannot handle non-mosaic (regular matrix) panos?
Not at all. I don't suppose that.
My guess is that the xml parser crashed. 2 Tests to do :
- 1. try inputs images without using the plugins system. If you can detect them without crashing, it's not a image decoding crash.
- 2. then provide me the xml. I have to check it, perhaps there is something I cannot parse into that one ( I followed the specification carefully but may have forgotten a case )
by fma38 » Thu Jan 08, 2009 8:39 am
I may also have generated a wrong file... Can you send it to me too? I'll check it with the RelaxNG description file (Alexandre, you may want to check the xml file with this RelaxNG spec. before importing, so you will be sure to have a correct file).
by klausesser » Thu Jan 08, 2009 11:53 am
fma38 wrote:I may also have generated a wrong file... Can you send it to me too? I'll check it with the RelaxNG description file (Alexandre, you may want to check the xml file with this RelaxNG spec. before importing, so you will be sure to have a correct file).
Hi Alexandre, hi Frédéric!
Here´s the script: (don´t know how to make it a smaller and scrollable window)
<?xml version="1.0" encoding="utf-8"?>
<papywizard version="a">
    <header>
        <general>
            <title>
                Here goes the title
            </title>
            <gps>
                Here goes the location
            </gps>
            <comment>
                Generated by Papywizard 1.5.4
            </comment>
        </general>
        <shooting mode="preset">
            <headOrientation>
                up
            </headOrientation>
            <cameraOrientation>
                portrait
            </cameraOrientation>
            <stabilizationDelay>
                0.5
            </stabilizationDelay>
            <startTime>
                2009-01-07_22h52m43s
            </startTime>
            <endTime>
                2009-01-07_23h00m33s
            </endTime>
        </shooting>
        <camera>
            <timeValue>
                0.5
            </timeValue>
            <bracketing intent="exposure" nbPicts="1"/>
            <sensor coef="1.6" ratio="3:2"/>
        </camera>
        <lens type="rectilinear">
            <focal>
                20.0
            </focal>
        </lens>
        <preset name="20mm 1.6crop"/>
    </header>
    <shoot>
        <pict bracket="1" id="1">
            <time>
                2009-01-07_22h53m05s
            </time>
            <position pitch="80.0" roll="90.0" yaw="30.0"/>
        </pict>
        <pict bracket="1" id="2">
            <time>
                2009-01-07_22h53m22s
            </time>
            <position pitch="80.0" roll="90.0" yaw="120.0"/>
        </pict>
        <pict bracket="1" id="3">
            <time>
                2009-01-07_22h53m39s
            </time>
            <position pitch="80.0" roll="90.0" yaw="210.0"/>
        </pict>
        <pict bracket="1" id="4">
            <time>
                2009-01-07_22h53m56s
            </time>
            <position pitch="80.0" roll="90.0" yaw="300.0"/>
        </pict>
        <pict bracket="1" id="5">
            <time>
                2009-01-07_22h54m07s
            </time>
            <position pitch="40.0" roll="90.0" yaw="345.0"/>
        </pict>
        <pict bracket="1" id="6">
            <time>
                2009-01-07_22h54m16s
            </time>
            <position pitch="40.0" roll="90.0" yaw="315.0"/>
        </pict>
        <pict bracket="1" id="7">
            <time>
                2009-01-07_22h54m25s
            </time>
            <position pitch="40.0" roll="90.0" yaw="285.0"/>
        </pict>
        <pict bracket="1" id="8">
            <time>
                2009-01-07_22h54m33s
            </time>
            <position pitch="40.0" roll="90.0" yaw="255.0"/>
        </pict>
        <pict bracket="1" id="9">
            <time>
                2009-01-07_22h54m42s
            </time>
            <position pitch="40.0" roll="90.0" yaw="225.0"/>
        </pict>
        <pict bracket="1" id="10">
            <time>
                2009-01-07_22h54m51s
            </time>
            <position pitch="40.0" roll="90.0" yaw="195.0"/>
        </pict>
        <pict bracket="1" id="11">
            <time>
                2009-01-07_22h55m00s
            </time>
            <position pitch="40.0" roll="90.0" yaw="165.0"/>
        </pict>
        <pict bracket="1" id="12">
            <time>
                2009-01-07_22h55m09s
            </time>
            <position pitch="40.0" roll="90.0" yaw="135.0"/>
        </pict>
        <pict bracket="1" id="13">
            <time>
                2009-01-07_22h55m19s
            </time>
            <position pitch="40.0" roll="90.0" yaw="105.0"/>
        </pict>
        <pict bracket="1" id="14">
            <time>
                2009-01-07_22h55m28s
            </time>
            <position pitch="40.0" roll="90.0" yaw="75.0"/>
        </pict>
        <pict bracket="1" id="15">
            <time>
                2009-01-07_22h55m36s
            </time>
            <position pitch="40.0" roll="90.0" yaw="45.0"/>
        </pict>
        <pict bracket="1" id="16">
            <time>
                2009-01-07_22h55m45s
            </time>
            <position pitch="40.0" roll="90.0" yaw="15.0"/>
        </pict>
        <pict bracket="1" id="17">
            <time>
                2009-01-07_22h55m56s
            </time>
            <position pitch="0.0" roll="90.0" yaw="0.0"/>
        </pict>
        <pict bracket="1" id="18">
            <time>
                2009-01-07_22h56m05s
            </time>
            <position pitch="0.0" roll="90.0" yaw="30.0"/>
        </pict>
        <pict bracket="1" id="19">
            <time>
                2009-01-07_22h56m14s
            </time>
            <position pitch="0.0" roll="90.0" yaw="60.0"/>
        </pict>
        <pict bracket="1" id="20">
            <time>
                2009-01-07_22h56m23s
            </time>
            <position pitch="0.0" roll="90.0" yaw="90.0"/>
        </pict>
        <pict bracket="1" id="21">
            <time>
                2009-01-07_22h56m34s
            </time>
            <position pitch="0.0" roll="90.0" yaw="120.0"/>
        </pict>
        <pict bracket="1" id="22">
            <time>
                2009-01-07_22h56m43s
            </time>
            <position pitch="0.0" roll="90.0" yaw="150.0"/>
        </pict>
        <pict bracket="1" id="23">
            <time>
                2009-01-07_22h56m52s
            </time>
            <position pitch="0.0" roll="90.0" yaw="180.0"/>
        </pict>
        <pict bracket="1" id="24">
            <time>
                2009-01-07_22h57m02s
            </time>
            <position pitch="0.0" roll="90.0" yaw="210.0"/>
        </pict>
        <pict bracket="1" id="25">
            <time>
                2009-01-07_22h57m11s
            </time>
            <position pitch="0.0" roll="90.0" yaw="240.0"/>
        </pict>
        <pict bracket="1" id="26">
            <time>
                2009-01-07_22h57m19s
            </time>
            <position pitch="0.0" roll="90.0" yaw="270.0"/>
        </pict>
        <pict bracket="1" id="27">
            <time>
                2009-01-07_22h57m31s
            </time>
            <position pitch="0.0" roll="90.0" yaw="300.0"/>
        </pict>
        <pict bracket="1" id="28">
            <time>
                2009-01-07_22h57m40s
            </time>
            <position pitch="0.0" roll="90.0" yaw="330.0"/>
        </pict>
        <pict bracket="1" id="29">
            <time>
                2009-01-07_22h57m50s
            </time>
            <position pitch="-40.0" roll="90.0" yaw="345.0"/>
        </pict>
        <pict bracket="1" id="30">
            <time>
                2009-01-07_22h57m59s
            </time>
            <position pitch="-40.0" roll="90.0" yaw="315.0"/>
        </pict>
        <pict bracket="1" id="31">
            <time>
                2009-01-07_22h58m08s
            </time>
            <position pitch="-40.0" roll="90.0" yaw="285.0"/>
        </pict>
        <pict bracket="1" id="32">
            <time>
                2009-01-07_22h58m17s
            </time>
            <position pitch="-40.0" roll="90.0" yaw="255.0"/>
        </pict>
        <pict bracket="1" id="33">
            <time>
                2009-01-07_22h58m25s
            </time>
            <position pitch="-40.0" roll="90.0" yaw="225.0"/>
        </pict>
        <pict bracket="1" id="34">
            <time>
                2009-01-07_22h58m35s
            </time>
            <position pitch="-40.0" roll="90.0" yaw="195.0"/>
        </pict>
        <pict bracket="1" id="35">
            <time>
                2009-01-07_22h58m44s
            </time>
            <position pitch="-40.0" roll="90.0" yaw="165.0"/>
        </pict>
        <pict bracket="1" id="36">
            <time>
                2009-01-07_22h58m55s
            </time>
            <position pitch="-40.0" roll="90.0" yaw="135.0"/>
        </pict>
        <pict bracket="1" id="37">
            <time>
                2009-01-07_22h59m04s
            </time>
            <position pitch="-40.0" roll="90.0" yaw="105.0"/>
        </pict>
        <pict bracket="1" id="38">
            <time>
                2009-01-07_22h59m12s
            </time>
            <position pitch="-40.0" roll="90.0" yaw="75.0"/>
        </pict>
        <pict bracket="1" id="39">
            <time>
                2009-01-07_22h59m21s
            </time>
            <position pitch="-40.0" roll="90.0" yaw="45.0"/>
        </pict>
        <pict bracket="1" id="40">
            <time>
                2009-01-07_22h59m30s
            </time>
            <position pitch="-40.0" roll="90.0" yaw="15.0"/>
        </pict>
        <pict bracket="1" id="41">
            <time>
                2009-01-07_22h59m40s
            </time>
            <position pitch="-80.0" roll="90.0" yaw="30.0"/>
        </pict>
        <pict bracket="1" id="42">
            <time>
                2009-01-07_22h59m59s
            </time>
            <position pitch="-80.0" roll="90.0" yaw="120.0"/>
        </pict>
        <pict bracket="1" id="43">
            <time>
                2009-01-07_23h00m16s
            </time>
            <position pitch="-80.0" roll="90.0" yaw="210.0"/>
        </pict>
        <pict bracket="1" id="44">
            <time>
            </time>
            <position pitch="-80.0" roll="90.0" yaw="300.0"/>
        </pict>
    </shoot>
</papywizard>
by fma38 » Thu Jan 08, 2009 12:34 pm
Thanks. I checked, and it is correctly validated by the RelaxNG spec (the file is syntactically correct). But there are maybe values that the APG parser doesn't like...
by AlexandreJ » Thu Jan 08, 2009 12:38 pm
This xml is parsed without issue on apg alpha2. The bug is not in that part.
by klausesser » Thu Jan 08, 2009 1:31 pm
fma38 wrote:Thanks. I checked, and it is correctly validated by the RelaxNG spec (the file is syntactically correct). But there are maybe values that the APG parser doesn't like...
strange: the file shows FOUR shots at -80 . . . But in the presets it´s EIGHT - and so are the images!
Presets.xml
<!-- End of fourth row -->
<!-- Fifth row 8-around Yaw separation 45h, Pitch -80 -->
<pict yaw="30." pitch="-80."/>
<pict yaw="75." pitch="-80."/>
<pict yaw="120." pitch="-80."/>
<pict yaw="165." pitch="-80."/>
<pict yaw="210." pitch="-80."/>
<pict yaw="255." pitch="-80."/>
<pict yaw="300." pitch="-80."/>
<pict yaw="345." pitch="-80."/>
<!-- End of fifth row -->
<!-- End of shoot -->
</shoot>
</preset>
</papywizard>
Script . . xml:
</time>
</pict>
<time>
</time>
</pict>
<time>
</time>
</pict>
<time>
</time>
</pict>
<time>
</time>
</pict>
</shoot>
</papywizard>
by klausesser » Thu Jan 08, 2009 1:57 pm
An actual script from today - 8 shots @-80°
    <header>
        <general>
            <title>
                8.1.a
            </title>
            <gps>
                Hardbg.
            </gps>
            <comment>
            </comment>
        </general>
            <headOrientation>
                up
            </headOrientation>
            <cameraOrientation>
                portrait
                0.5
            <startTime>
                2009-01-08_13h27m15s
            </startTime>
            <endTime>
                2009-01-08_13h35m32s
            </endTime>
        </shooting>
        <camera>
            <timeValue>
                0.5
            </timeValue>
        </camera>
            <focal>
                20.0
            </focal>
        </lens>
    </header>
    <shoot>
            <time>
                2009-01-08_13h27m31s
            </time>
        </pict>
            <time>
                2009-01-08_13h27m50s
            </time>
        </pict>
            <time>
                2009-01-08_13h28m07s
            </time>
        </pict>
            <time>
                2009-01-08_13h28m24s
            </time>
        </pict>
            <time>
                2009-01-08_13h28m35s
            </time>
        </pict>
            <time>
                2009-01-08_13h28m44s
            </time>
        </pict>
            <time>
                2009-01-08_13h28m53s
            </time>
        </pict>
            <time>
                2009-01-08_13h29m02s
            </time>
        </pict>
            <time>
                2009-01-08_13h29m12s
            </time>
        </pict>
            <time>
                2009-01-08_13h29m21s
            </time>
        </pict>
            <time>
                2009-01-08_13h29m31s
            </time>
        </pict>
            <time>
                2009-01-08_13h29m43s
            </time>
        </pict>
            <time>
                2009-01-08_13h29m51s
            </time>
        </pict>
            <time>
                2009-01-08_13h30m00s
            </time>
        </pict>
            <time>
                2009-01-08_13h30m10s
            </time>
        </pict>
            <time>
                2009-01-08_13h30m18s
            </time>
        </pict>
            <time>
                2009-01-08_13h30m29s
            </time>
        </pict>
            <time>
                2009-01-08_13h30m38s
            </time>
        </pict>
            <time>
                2009-01-08_13h30m47s
            </time>
        </pict>
            <time>
                2009-01-08_13h30m56s
            </time>
        </pict>
            <time>
                2009-01-08_13h31m04s
            </time>
        </pict>
            <time>
                2009-01-08_13h31m15s
            </time>
        </pict>
            <time>
                2009-01-08_13h31m24s
            </time>
        </pict>
            <time>
                2009-01-08_13h31m32s
            </time>
        </pict>
            <time>
                2009-01-08_13h31m42s
            </time>
        </pict>
            <time>
                2009-01-08_13h31m51s
            </time>
        </pict>
            <time>
                2009-01-08_13h32m00s
            </time>
        </pict>
            <time>
                2009-01-08_13h32m09s
            </time>
        </pict>
            <time>
                2009-01-08_13h32m20s
            </time>
        </pict>
            <time>
                2009-01-08_13h32m29s
            </time>
        </pict>
            <time>
                2009-01-08_13h32m38s
            </time>
        </pict>
            <time>
                2009-01-08_13h32m48s
            </time>
        </pict>
            <time>
                2009-01-08_13h32m56s
            </time>
        </pict>
            <time>
                2009-01-08_13h33m06s
            </time>
        </pict>
            <time>
                2009-01-08_13h33m16s
            </time>
        </pict>
            <time>
                2009-01-08_13h33m25s
            </time>
        </pict>
            <time>
                2009-01-08_13h33m34s
            </time>
        </pict>
            <time>
                2009-01-08_13h33m43s
            </time>
        </pict>
            <time>
                2009-01-08_13h33m52s
            </time>
        </pict>
            <time>
                2009-01-08_13h34m01s
            </time>
        </pict>
            <time>
                2009-01-08_13h34m12s
            </time>
        </pict>
            <time>
                2009-01-08_13h34m23s
            </time>
            <position pitch="-80.0" roll="90.0" yaw="75.0"/>
        </pict>
            <time>
                2009-01-08_13h34m34s
            </time>
        </pict>
            <time>
                2009-01-08_13h34m45s
            </time>
            <position pitch="-80.0" roll="90.0" yaw="165.0"/>
        </pict>
        <pict bracket="1" id="45">
            <time>
                2009-01-08_13h34m58s
            </time>
        </pict>
        <pict bracket="1" id="46">
            <time>
                2009-01-08_13h35m09s
            </time>
            <position pitch="-80.0" roll="90.0" yaw="255.0"/>
        </pict>
        <pict bracket="1" id="47">
            <time>
                2009-01-08_13h35m21s
            </time>
        </pict>
        <pict bracket="1" id="48">
            <time>
            </time>
            <position pitch="-80.0" roll="90.0" yaw="345.0"/>
        </pict>
    </shoot>
</papywizard>
by klausesser » Thu Jan 08, 2009 2:18 pm
Could import the script. Importing the corresponding images causes a crash and s splash screen.
Importing the images in the usual way works.
after that i imported the script again, imported the images to the script worked - but says it´s 101 images. But in fact it´s 48 images!
tried again:
importing script works. importing related images works also. editor shows a complete mess.
loading images the usual way, setting lens/camera data manually (no exif), detecting works fast and editor shows a perfect stitch.
Maybe the scripting process NEEDS exifs? Doesn´t the script tell APP about lens and camera anyway? I don´t have exifs because of using a manual Nikon-lens on a Canon 20D.
I often tried to add the lens to the database - didn´t work, i think.
by AlexandreJ » Thu Jan 08, 2009 2:51 pm
note : to prevent have a nice display on the forum use this syntax before and after your script :
before : "[ code ]" without spaces
after : "[ /code ]" without spaces
by klausesser » Thu Jan 08, 2009 3:58 pm
AlexandreJ wrote:note : to prevent have a nice display on the forum use this syntax before and after your script :
thanks! :)
