Render Presets for Panoramas - Cylindrical
Alpha81
by Alpha81 » Mon Jan 05, 2009 10:23 pm
Hi.
Trying to speed up my work flow. I had everything automated before had to stop that because i have to go into the edit screen and change the projection to cylindrical from spherical before i can do a final render to save the file as. Anywhere to preset it so that it will render the files as cylindricals without me having to go in and change the projection of each file before render/save?
by AlexandreJ » Tue Jan 06, 2009 9:28 am
With the current version, it's not possible. But with version 2, that's already possible. You have a menu to tell which projection by default you want.
You can try the alpha version here : http://www.autopano.net/wiki/Lastest_Beta
