mark_anderson_us wrote:Shoot brackets
Create HDR in Photomatix
Stitch in APP (Create HDR)
Tone map in Photomatix
The biggest pain in this workflow is the the EXIF is lost in HDR creation (not sure if it's a limitation in Photomatix or the EXR format). (I have e-mailed Photomatix abotu this)
mark_anderson_us wrote:Hmmm...
I was referring to APP. If you need to set the aperture for all images, you can only do them one by one as far as I can see.
You can by all means select the entire list, but to enter an aperture, you need to double click in the aperture field of ONE of the images. This de-selects all the others. You then need to repeat this for every image.
I don't see any other way to set the aperture
Regards
Mark
