violet overlay after Import DNG Files
flaviocavaleri
by flaviocavaleri » Tue Aug 07, 2018 6:03 pm
Hi there.
I have to stitch 202 Images to a Panorama. I tried an import with DNG-files and xml. the result is visible in the attached image. I created the DNGs with the Adobe DNG Converter.
I need some help or explanations.
thx very much!!!
olivierbo
Liked in: 133 posts
Re: violet overlay after Import DNG Files
by olivierbo » Wed Aug 08, 2018 3:16 pm
It seems that DNG Converter creates some issues with Autopano. Have you tried with an other software? Have you tried on an other computer as well?
Also, which version of Autopano are you using exactly.
Best regards,
Olivier
flaviocavaleri
by flaviocavaleri » Wed Aug 08, 2018 5:24 pm
Thanks for your answer.
I tried creating DNGs also with LR. APG 4.4 . My Laptop would collapse. The panorama has 202 images (50 megapixels)
