Panono template
joakimsteyls
Panono template
by joakimsteyls » Tue Aug 07, 2018 9:22 am
Followed these steps to try and stitch my panono photo files: http://www.kolor.com/wiki-en/action/vie ... 360_camera
However, I don't see the template showing up in Autopano Pro.
Can you please advise?
thanks
Joakim
no template available
file placement
olivierbo
Liked in: 133 posts
Re: Panono template
by olivierbo » Wed Aug 08, 2018 11:57 am
The template feature is only available with Autopano Giga, I'm sorry.
Have tou tried to just add you picture to Autopano Pro, then just check if the focal (equiv 35mm) is right and detect?
Detection tab:
Quality of detection: High
Number of control points: 150
Then, launch detection
Kind regards,
Olivier
joakimsteyls
Re: Panono template
by joakimsteyls » Wed Aug 08, 2018 1:57 pm
Hi Olivier,
Quite deceiving when the link mentions AutoPanoProXX as filepath to place the template:
OSX: Hold the "ALT" key, then open Go menu in the Finder. Go to Library/Application Support/Kolor/AutopanoProXX or AutopanoGigaXX/User/Templates/
Seems like i'm stuck with a Kolor product version that can't handle Panono photo's now :) .
I tried using Autopano following your recommendations and get results like the following in attachtment.
A lot of image corners look warped in a way that I can't even overlay them correctly on the pano and I can't find how to unwarp them.
Furthermore I can't seem to find where I can enter the focal length manually?
Thanks in advance.
Joakim
olivierbo
Liked in: 133 posts
Re: Panono template
by olivierbo » Wed Aug 08, 2018 2:08 pm
I apologize. This is my fault as I am in charge of the documentation!
I do not remember what's the exact Panono focal lenght but you can enter it in Image properties: http://www.kolor.com/wiki-en/action/vie ... properties
On my side, I entered 20mm and it seems to work well!
Let me know.
Cheers,
Olivier
