Resolution troubles
Hypilein
Resolution troubles
by Hypilein » Fri Aug 03, 2018 5:43 pm
I am still a trial user trying to figure out whether it's worth buying Autopano, as I have following problem.
I already use PTGUI and I am very happy with the results, if it gives me any. However, it seems to often have trouble finding control points. In a move of desperation I tried AutoPano and it immediately stitched everything to my liking. However, here comes the problem.
When I render a Pano (that works in PTGUI) I get much higher resolution output than in AutoPano. For Example one "little Planet" aerial (shot with the Mavic Air) gave me a ca. 20000x20000 Pixels output in PTGUI but the 100% output resolution of AutoPano is only about 5000x5000 Pixels. Considering I shoot Panos primarily to increase the shoddy resolution of my drone this is unacceptable. I can't really imagine that a 200€ software would give such a bad result, so what am I doing wrong?
I'm running on a MacBook Pro with 2,8 Ghz i5 and 8GB RAM. Hope you can help me out, because I've got some really nice Panos that won't stitch in PTGui, but I'm not forking that much money for the low resolution output I'm getting out of AutoPano right now.
Re: Resolution troubles
by mediavets » Fri Aug 03, 2018 6:49 pm
Without experimenting with your source images I wouldn't know what the issue might be.
Hypilein
by Hypilein » Tue Aug 07, 2018 8:38 am
Sorry for taking a while. Here is the link with my results and original files. It's not of great artistic merit, but should serve the purpose. https://www.dropbox.com/sh/uihkgymjv7cl ... WRWva?dl=0
