iMac Pro Video Card Performance
jemski
by jemski » Thu Jul 26, 2018 8:31 pm
Hi There:
We're looking at obtaining an iMac pro for Autopano Video (likely Giga as well). Could you let me know if Autopano utilizes the GPU's of the Radeon Pro Vega cards in the iMacs to accelerate rendering speeds. If so, are these a good option?
Alternatively, do you recommend NVIDIA cards in a PC etc. How is the GTX1080 in this regard. We will be stiching 4, 6 and 8K video.
Thanks in advance!
olivierbo
Liked in: 133 posts
Re: iMac Pro Video Card Performance
by olivierbo » Fri Jul 27, 2018 8:59 am
Only CUDA from NVIDIA is supported by Autopano Video 3. Autopano Giga uses OpenCL which is compatible with NVDIA and AMD video cards.
A GTX 1080 will be a great choice.
Also, a SSD and enough memory (16 or 32GB) is a good choice ;)
Have you tried those softwares?
Let me know if you have any question.
Best regards,
Olivier
