Autopano Video on a Multi-User System
jemski
by jemski » Thu Jul 26, 2018 8:27 pm
Hi There:
We're using Autopano video on a Mac and a second Autopano+Giga license on a Windows PC. We've found that Autopano has to be re-registered for every new user that has an account on the machine. This is a not a major problem on the PC's (annoying though) as it is primarily using only one account. But, the Mac is in a multiple user environment and it is deep frozen for security purposes; so settings are not saved when the machine is rebooted. Also, we are not permitted to have a single user account on that machine (for security reasons) and the Autopano software registration process requires a time consuming unfreeze-freeze cycle.
Is there any process on OSX (and Windows) to set Autopano to remain registered for all users of a particular machine. As it stands this is next to impossible to deploy.
Thanks!
olivierbo
Liked in: 133 posts
Re: Autopano Video on a Multi-User System
by olivierbo » Fri Jul 27, 2018 9:24 am
We do not have any specific license to avoid that issue but I will send you a trick.
Kind regards,
Olivier
