Problems with stitching
Vittoria
by Vittoria » Wed Jun 27, 2018 12:12 am
Hi guys.
I am having a bit of difficulties when stitching material shot with two kodak pixpro sp360 4k.
As you can see in the file attached my stitching is somewhat disturbing and I have watched about 10-15 tutorials on how to solve this issue but I'm not getting anywhere.
Does anybody know how to fix this?
Also not sure if this is necessary information but the cameras are on a moped so they move from time to time.
I am using Autopano Video Pro 2.5.3 and Autopano Giga 4.2.3.
All the best,
Vittoria
olivierbo
Liked in: 133 posts
Re: Problems with stitching
by olivierbo » Wed Jun 27, 2018 2:19 pm
Hello Vittoria,
Did you apply any blending to remove ghost images? Do you have some problem with transitions between the 2 cameras?
Kind regards,
Olivier
Vittoria
by Vittoria » Thu Jun 28, 2018 12:27 pm
Hi Olivier.
I've tried all the various blending presets available with your program and none of them works. This is as good as it gets with the smooth blend.
In the stitching area I saw that the only one available for my cameras was the Kodak-AlexPearce which I also used but it still doesn't work.
The cameras have always worked fine. When working with a previous project this was never an issue but here it is for some reason and I can't figure out what it is.
All the best,
Vittoria.
olivierbo
Liked in: 133 posts
by olivierbo » Thu Jun 28, 2018 12:46 pm
Hi Vittoria,
What about the stitching quality? Do you have ghost images, a bad stitching which may occur when you do not have enough brightness or area with a lack of details?
Kind regards,
Olivier
Vittoria
by Vittoria » Fri Jun 29, 2018 6:27 pm
Hi Olivier.
The quality in general is fine except for a bit of smudge I did not see in one of the cameras. The lighting is also very good. Much better than the previous project I worked with before.
I had a friend over yesterday and she tried a few different ways of fixing my issue. Another problem seems to be that the stitching line is right inbetween the guys hand so when we tried to get rid of the ghost image his hand looked very wierd.
All the best,
Vittoria
olivierbo
Liked in: 133 posts
by olivierbo » Mon Jul 02, 2018 1:36 pm
Hi Vittoria,
Sorry for the late reply.
Have you tried to use the mask tool into APG?
https://youtu.be/BVOzb4ZKJco?t=697
http://www.kolor.com/wiki-en/action/vie ... sking_tool
Let me know if it helps.
Cheers,
Olivier
Vittoria
by Vittoria » Fri Aug 10, 2018 10:31 pm
Hi Olivier.
I'm so terribly sorry for the late reply. I have been abroad for quite some time. The problem is that the stitching line falls on his hand. Everything else is perfect except for half of his right hand that dissapears and the mirror on that side as well. I've tried playing around with the footage in both video pro and giga but nothing helps at all.
All the best,
Vittoria
olivierbo
Liked in: 133 posts
by olivierbo » Tue Aug 21, 2018 2:34 pm
My turn to apologize for the late reply!
Those tools are not as magical ;as you can imagine! ;) Most of the time it can help improve the stitching but not remove all issues :(
If you're still having problem on the person's hand, you have to apply masks on all the sequence where the problem appears. Quite hard if you have a long sequence, unfortunately.
Cheers,
Olivier
