"Fog" on Stacked panos
bastibasti
by bastibasti » Tue May 15, 2018 5:52 am
Hi ,
i've started to shoot only brackets even when the lighting is OK for single shooting. However I noticed that under bright light condition (outside) there are sometimes foggy fragments in the images.
Is there any way to overcome this?
bastibasti
Re: "Fog" on Stacked panos
by bastibasti » Tue May 15, 2018 5:54 am
Here is a comparison of the stitch and the original material.
Please check the white cars number plate
olivierbo
Liked in: 134 posts
by olivierbo » Wed May 16, 2018 8:15 am
Did you apply any blending? You can click the Preview icon in order to apply a standard blending and color correction.
Also, what is the recovery rate between pictures?
Kind regards,
Olivier
marzipano
Liked in: 14 posts
by marzipano » Thu May 17, 2018 6:48 am
You didn't say what product you used to fuse the bracketed images
I use Photomatix and I have also noted these foggy patches in bright areas
The way I minimise this is:
1. Use the lowest EV (-2EV for me) as the base
2. Use the lowest setting possible for deghosting whilst still removing ghosts properly
This usually gets rid of most but not always all the fog especially if there is movement within the brackets and you have to use a high deghosting %
Hope this helps
Martin
bastibasti
by bastibasti » Thu May 17, 2018 7:35 am
I normally use the exposure weights feature in autopano.
I have also tried LR but the result was completely different
blending: multiband
cutting: smart
weighting: fusion
should I apply any corrections?
bastibasti
by bastibasti » Thu May 17, 2018 7:54 am
reducing the antighose ammount seems to do the trick. I will try to finish this 15 images series and report back whether it worked.
olivierbo
Liked in: 134 posts
by olivierbo » Wed May 23, 2018 7:48 am
One more thing if you encounter that kind of issue. Check if you do not have more than one layer in the panorama editor.
Cheers,
Olivier
