[solved] Automatically resizing images for GSV?
bastibasti
by bastibasti » Sun Apr 29, 2018 4:40 pm
Hey all,
one question. Sometimes, when stitching the output image will be like 14987x7417 pixels.
now that is not a 2:1 ratio and the GSV app has issues uploading them. What I do currently is:
- cut horizontal resolution to 14986 (so it can be divided by 2)
- calculate y resolution
- add black pixels to the bottom of the flat pano
-> since I need to fix the nadir anyway, the additional 100 pixels black dont harm me
is there such an option in autopano??
Re: Automatically resizing images for GSV?
by Destiny » Sun Apr 29, 2018 10:52 pm
You can force to create a full 2:1 pano.. Then export the cube faces from PTP or krpano droplet. Then edit the nadir or zenith using Photoshop.. But be careful not to edit the outer edges, otherwise you will see lines when the pano is put back together.. After editing in Photoshop, import the cube faces into PTP...
dzeek
Likes: 3 posts
by dzeek » Mon May 07, 2018 2:34 pm
@bastibasti I've found that if you set Default projection to "Spherical" and Default crop to "Maximum Projection Range" then it will create a 2:1 pano. I then force the dimensions to 14142 x 7071 to yield the maximum GSV pano of 100 megapixels.
bastibasti
by bastibasti » Tue May 15, 2018 5:46 am
Excellent solution, thank you!
