Future autopano hardware support?   [SOLVED] - View the solution
bastibasti
by bastibasti » Tue Apr 03, 2018 8:44 am
Hey guys,
sorry for asking too much...
I've read somewhere that autopano giga doesnt use any GPU for increasing the speed of rendering. I have a i7 and a xeon but both need about 3-4 minutes per pano which is quite looong. Are you planning to use opencl in future (in that case I will keep my 3x1070) or not (sell 2x 1070 and get a beefier CPU)
If so, which is the best cpu to go for? What is the key factor? CPU speed? Number of cores? CPU cache?
olivierbo
Liked in: 133 posts
Re: Future autopano hardware support?  [SOLVED]
by olivierbo » Tue Apr 03, 2018 1:18 pm
This is a feature we are thinking about but I cannot confirm (at this time) if we will add it in a later version.
Autopano will use all the cores available but does not support multi-CPU.
rendering time also depends on the images (JPG, TIFF, RAW), their resolution, their number, the corrections you added, numbers of CPUs and so on.
A Xeon is a perfect choice. CPU speed and number of cores are important!
Best regards,
Olivier
bastibasti likes this post.
