License Question: Multiple install   [SOLVED] - View the solution
bastibasti
by bastibasti » Wed Mar 28, 2018 9:35 pm
Hey guys,
one question: I want to install a second instance on a fat AWS machine so I can render larger projects quicker then on my all in one desktop pc. I'm not planning to use both instances at the same time, if the project is too big I will use "the other PC" ...
Is this covered by the pro license? I dont want to run into a situation where my license is blocked off or something
olivierbo
Liked in: 134 posts
Re: License Question: Multiple install  [SOLVED]
by olivierbo » Thu Mar 29, 2018 10:26 am
Our licenses are single-station licenses, i.e. you can only install the application on one computer. However, Kolor tolerates the installation of the applications on several computers for individuals and self-employed persons insofar as you are the only user of the application on these computers.
Let me know if you have any question.
Best regards,
Olivier
bastibasti likes this post.
