Stereoscopic 3D images
signmaster
Likes: 52 posts
Liked in: 36 posts
by signmaster » Fri Mar 02, 2018 11:57 pm
Any tips for stitching stereoscopic 3D images using Autopano. I know it won't stitch both sets of images at the same time but I would be happy to stitch the left and right eye separately, perhaps after creating a template?
Steve
olivierbo
Liked in: 134 posts
Re: Stereoscopic 3D images
by olivierbo » Tue Mar 06, 2018 3:08 pm
In order to create a stereoscopic (anaglyph) panorama you can use Gimp, Photoshop or any other software that handles layers. There's no option in Autopano that can create such panorama.
Best regards,
Olivier
signmaster
Likes: 52 posts
Liked in: 36 posts
by signmaster » Tue Mar 06, 2018 11:24 pm
I have no problem using Photoshop after stitching. Tghe problem is stitching with Autopano or any other software I have tried. I currently shoot the images with about a 60mm (IPD) so each image is shot at an offset of 30mm from the center of rotation. This makes it hard for the software to stitch correctly. I am after some tips to overcome this problem. Would be good if Autopano would create hard links so you could stitch a series of images then save a template with hard links that could be applied to other images that were shot with the same positioning etc. Also to over come the stitching problem instead of shooting 4 images around with a fisheye lens I shoot 20 or more. So just after some tips.
olivierbo
Liked in: 134 posts
by olivierbo » Wed Mar 07, 2018 11:23 am
You can manually create links between pictures if you have enough overlap but you may encounter parallax issues.
Can you share or send your pictures?
Best,
Olivier
signmaster
Likes: 52 posts
Liked in: 36 posts
by signmaster » Thu Mar 08, 2018 11:36 am
Hi Olivier
I can share the images via my Google drive, just need an email?
Steve
olivierbo
Liked in: 134 posts
by olivierbo » Fri Mar 09, 2018 11:09 am
Hi Steve,
The stitch is really very good with Autopano (with all the pictures, slightly worse eye by eye but not horrible) but I do not have any solution for your special need, unfortunately.
Best,
Olivier
signmaster
Likes: 52 posts
Liked in: 36 posts
by signmaster » Fri Mar 09, 2018 11:23 am
Thanks Olivier
olivierbo
Liked in: 134 posts
by olivierbo » Fri Mar 09, 2018 11:25 am
You're welcome Steve.
Cheers,
Olivier
talkingdog
Liked in: 3 posts
by talkingdog » Mon Apr 16, 2018 11:54 pm
olivierbo wrote:Hello,
Best regards,
Olivier
Can giga do 360 stereoscopic like autopano video can?
I took some stills and I want to export the stitch with TOP/BOTTOM
martin.arnoux
Liked in: 27 posts
by martin.arnoux » Tue Apr 17, 2018 3:00 pm
Hi Talkingdog,
No APG cannot do 360 stereoscopic like AVP, sorry.
Cheers,
Martin
