Stereo 180 video with IZugar
ShimJim
by ShimJim » Fri Mar 02, 2018 4:17 pm
Hi all,
New user here and started learning Autopano a few weeks back. I need help reproducing the same result as this video shows:
https://www.youtube.com/watch?v=uVzNo9RZEdo
I don't have the .pano template like in the video so and I don't know how to create one. I've tried using Autopano Giga to make it but I've had no luck stitching and positioning the pictures correctly.
I tried using the correct lens presets and have tried using them with no luck either. I'm using IZugar MKX22 lenses and using the presets found here:
http://www.izugar.com/stitching/
Any advice or does anyone have a working template? What should I try and do or look into from here?
I'm running the trial versions for now until I'm confident I can make stereo videos with Autopano.
/Jim
