How do I link an image to add control points?
tony75672
Liked in: 9 posts
by tony75672 » Wed Feb 07, 2018 9:33 pm
Hi there,
I am struggling to detect 8 images. It only detects 7. I got it to force to use all images and I have tried placing the image manually but with no luck. How can I link image 6 to image 7 so I can manually add the connection points?
Tony
signmaster
Likes: 52 posts
Liked in: 36 posts
Re: How do I link an image to add control points?
by signmaster » Thu Feb 08, 2018 5:58 am
Hi Tony
Just going from memory as I don't have the program in front of me. Ctrl-click the images so you have both open in the window then make sure you have the add points marque selected and draw a box around the common sections on each image. That should generate the points then optimize the pano. Mor detailed instructions here http://www.kolor.com/wiki-en/action/view/Autopano_Giga_-_Panorama_Editor_-_Control_Points_Editor
Steve
olivierbo
Liked in: 134 posts
by olivierbo » Mon Feb 12, 2018 4:02 pm
You can try after you increase quality of detection. You can also try to use Local geometry analysis, Guess position tool in Move image mode...
Let me know.
Best,
Olivier
