Stitching an Art Reproduction
voggeneder
Likes: 3 posts
by voggeneder » Mon Jan 22, 2018 10:48 pm
Hey!
I recently was commissioned to create a gigapixel repro of a Schiele painting, and did so by manually moving the camera along a slider while shooting a macro lens. If I import the files into APG, it assumes i shot from a fixed position and corrects for the perspective distortion, creating a pincushion effect.
Is there any way to disable all geometric functions of APG4.4 and only use it to create a planar image?
canon 5dsr, 100mm L 2.8, generic video slider on tripods, APG4.4 OSX 10.11.6
screenshot
greatmasters likes this post.
Panoram1x
Liked in: 41 posts
Re: Stitching an Art Reproduction
by Panoram1x » Tue Jan 23, 2018 1:22 pm
You can take a look at this...
viewtopic.php?f=2&t=31164#p181055
2 people like this post.
Nanard
Liked in: 3 posts
by Nanard » Tue Jan 23, 2018 2:26 pm
And/or specify 'multiple viewpoints'. (giga only I think)
Bernard
greatmasters
Likes: 3 posts
by greatmasters » Fri Feb 16, 2018 10:55 pm
I'm having the same issue. I have the final size, the number of viewpoints, the serpentine travel, the overlap, the number of rows and columns, and the field of view. I have no place to put those data points. The software seems to just want to figure it all out by itself. But I want to help it :-)
Any ideas on how to set a serpentine viewpoint travel path and then constrain the final image to a rectangle made of exact number of rows and columns. Planar.
Microsoft ICE does have places for most of these inputs, but I still don't get a good clean rectangle.
voggeneder likes this post.
