Bad stitching
Óbila
Bad stitching
by Óbila » Thu Jan 11, 2018 10:45 pm
Hello:
I use autopano giga 4.4 in a MacBook Pro running High sierra. I have problems when pasting photos. It doesn’t work well. The stitching isn’t right. This problems doesn’t occur when working in other softwares for example Adobe Lightroom.
Thank you
olivierbo
Liked in: 133 posts
Re: Bad stitching
by olivierbo » Fri Jan 12, 2018 11:44 am
Autopano is not yet compatible with High Sierra. That said, there's no reason to not have a good stitching.
Can you add some screenshots of the issue and explain if you are able to stitch the same pictures properly using another OS and same Autopano version?
Kind regards,
Olivier
stadh
Liked in: 3 posts
Re: Bad stitching
by stadh » Wed Jan 17, 2018 11:17 pm
When will it be compatible with High Sierra (and also Panotour Pro)?
I may be forced to install a new system soon, and if possible I'd like to use the most recent macOS then.
olivierbo
Liked in: 133 posts
Re: Bad stitching
by olivierbo » Thu Jan 18, 2018 11:28 am
I do not have any ETA, I'm sorry.
Best,
Olivier
mggardner
Re: Bad stitching
by mggardner » Sat Aug 18, 2018 12:37 am
Well, I admit I've been away from stitching for a while. I'm running High Sierra and 4.4.1 won't load ANY images I try. No error - just never does anything. And I see no updates in a long while - so have we (pano) been abandoned for the more glitzy video?
mgg
olivierbo
Liked in: 133 posts
Re: Bad stitching
by olivierbo » Mon Aug 20, 2018 12:43 pm
That's not normal if you cannot add any image. What kind of picture file format exactly?
How did you add the files to Autopano?
Kind regards,
OLivier
mggardner
Re: Bad stitching
by mggardner » Mon Aug 20, 2018 1:07 pm
Reading further it seems APG is not compatible with high sierra.......which has been out for some time....
olivierbo
Liked in: 133 posts
Re: Bad stitching
by olivierbo » Mon Aug 20, 2018 3:19 pm
We said that APG is not compatible with High Sierra because we haven't done deep tests on that system, that's it! It does not mean that it does not work on high Sierra, that's different.
Kind regards,
Olivier
mggardner
Re: Bad stitching
by mggardner » Mon Aug 20, 2018 6:35 pm
I’ve tried to opt cr2, jpg, png nothing happens. No error. I reinstalled and no change. MacBook Pro 2017, fully up to date.
olivierbo
Liked in: 133 posts
Re: Bad stitching
by olivierbo » Tue Aug 21, 2018 7:17 am
Have you tried after you disable Fast editor and/or GPU processing?
Kind regards,
Olivier
mggardner
Re: Bad stitching
by mggardner » Tue Aug 21, 2018 7:00 pm
Nope. Since it won't even open the first screen I didn't figure disabling editing features had anything to do with it.
