Export Nadir Image From 360 Pano
maximilian ritter
by maximilian ritter » Thu Sep 28, 2017 5:33 pm
Hello! Is it possible,to export a part of a 360 sphere as a normal image (the nadir) ?
I would like to export the nadir, retouch it in photoshop and put it back inthe exact same place, where i took it from. I have already tried this, but APG seems tho "blend" the images in a wrong way together. Does somebody have exierence with this?
Best Regards,
Max
Re: Export Nadir Image From 360 Pano
by Destiny » Thu Sep 28, 2017 9:54 pm
Hi.. Yes, just export as Cube Faces from PTP or the Krpano tools... Then when you have done your editing, import cube faces.. Make sure you do not do anything to the edges or change the entire colours.. Otherwise you will see the difference between the images, thereby creating lines in your pano....
