GoPro Stitching   [SOLVED] - View the solution
alexz5816
GoPro Stitching
by alexz5816 » Sun Sep 24, 2017 4:10 pm
I am working on a project in which I am using 4 gopros which all face forward but also outward so I only see 180 degrees. I am looking to buy Autopano but before I do I would like to know if Autopano will be able to stitch the videos of four gopros to get a high quality 180 video and not a usual full 360 degrees. I will be making a custom 3d printed mount to hold the four gopros.
Thanks in advance,
Alexz S
DJW
Liked in: 3 posts
Re: GoPro Stitching  [SOLVED]
by DJW » Mon Sep 25, 2017 9:08 am
Hi Alex
I'm not 100% sure about this as I've not tried it, but you can download the full version of AutoPano Video to test your rig output, the trial version will add a watermark to the rendered output. But if you get that far you'll at least know for sure that it works... ;-)
BTW, I'd suggest posting in the AutoPano Video forum rather than here.
Best regards
David.
