Stitch Photo in Giga
Matheus
Liked in: 4 posts
by Matheus » Thu Sep 21, 2017 3:31 pm
Hi
I'm using a pano template in panovideo to align my cameras
Is it possible to use the same process when you want to stitch a Photo via Giga ?
olivierbo
Liked in: 134 posts
Re: Stitch Photo in Giga
by olivierbo » Fri Sep 22, 2017 11:53 am
You have a "Save as Template" option in Autopano: http://www.kolor.com/wiki-en/action/vie ... or#Toolbar
Best regards,
Olivier
Matheus
Liked in: 4 posts
by Matheus » Fri Sep 22, 2017 11:59 am
Hi Olivier
I think I didn't explain correctly my issue.
In fact What I want to do :
Stitch photo from the Gear 360 2017
If I want to stitch Video from this camera I have a template which align the 2 lenses correctly and then I just have to work a little bit on the stitching
BUT if I want to stitch a photo, this is a nightmare. I have tested everything (like making a copy of the photo) then cropping to get the left and right lens
Tried different focal lengh, but still a lot of distortion and camera not aligned
So I was wondering as I have a template that I used in autopanovideo is there a way to use it to stitch Photo ...
Thanks again for your help
olivierbo
Liked in: 134 posts
by olivierbo » Fri Sep 22, 2017 12:37 pm
Have you tried to stitch your pictures using your video template?
We do not have any template unfortunately. Some videos are available on Youtube which could help you: https://www.youtube.com/watch?v=KiH5uy3jrIU
You can also use the different settings available in the Group settings menu.
Hope this can help.
Best regards,
Olivier
Matheus
Liked in: 4 posts
by Matheus » Fri Sep 22, 2017 12:51 pm
Hi
That's what I would like to do
How can use the template in giga for photo stitching
I don't see anywhere how I can do this action
Here the pano I'm using
4096x2048_Gear360_2017.pano
(635.87 KiB) Downloaded 80 times
olivierbo
Liked in: 134 posts
by olivierbo » Fri Sep 22, 2017 12:58 pm
Just have a look at the documentation link I gave you and you will find where to copy your .pano file on Windows or OSX ;-)
Then, after copying the .pano file, once again in Group settings menu, Layout field, select your template: http://www.kolor.com/wiki-en/action/vie ... ection_tab
Hope this helps.
Best,
Olivier
Matheus
Liked in: 4 posts
by Matheus » Sat Sep 23, 2017 10:26 am
Hi Olivier
I've followed everything you said
I've first created a new pano template
I've put it in
C:\Users\mathias\AppData\Local\Kolor\Autopano Giga 4.4\User\Templates
I've restarted Giga
I've been into detection parameters see (detection.png) and have selected the pano I did
I'm selected my images then click on detection.
But whether I'm using my pano or the standard one, the result is the same (see result)
So Don't really understand ;(
Any idea ?
olivierbo
Liked in: 134 posts
by olivierbo » Mon Sep 25, 2017 12:56 pm
I'm sorry I'm not familira with 360 Gear pictures stitching. You can try to create a preset using this tutorial: http://www.kolor.com/wiki-en/action/vie ... era_preset
Hope this can help.
Best,
Olivier
