Black Holes in Panorama
coccoce
by coccoce » Sat Jul 01, 2017 3:25 pm
Dear Kolor,
I am using OSMO to create a 360 degree.
But I am getting the black holes above and bellow.
This tutorial shows how to eliminate it: https://www.youtube.com/watch?v=elDYGUV9cbw From 2.52min you can see the created the panorama and used KRPANO to split the pano in order to be able to photoshop the black hole.
I was wondering if with my Autopano or Panatour - i have the same option to split the panorama to retouch in photoshop? Or do i hve to buy separate krpano?
On their website they have a ''plug in'' for Autogiga
olivierbo
Liked in: 134 posts
Re: Black Holes in Panorama
by olivierbo » Mon Jul 03, 2017 12:25 pm
You can add a logo (png file format) or picture (png file format) to the nadir and zenith quite simply: http://www.kolor.com/wiki-en/action/vie ... r_patching
Hope this helps.
Best regards,
Olivier
coccoce
by coccoce » Mon Jul 03, 2017 10:31 pm
Hi Olivier,
This is not what I am after. I will have to buy the KRPANO in order to unstich the panorama and make the modifications in PhotoShop.
Cesar
by Destiny » Tue Jul 04, 2017 12:26 am
Hi.. Do you have Panotour Pro...??
