omni or Giga?
bergerdennis
omni or Giga?
by bergerdennis » Mon May 15, 2017 10:52 pm
What is leading to better results: open the Omni Importer project of your 360 photo or stitch it from the beginning in GIGA?
Any opinions, knowledge?
olivierbo
Liked in: 134 posts
Re: omni or Giga?
by olivierbo » Thu May 18, 2017 10:05 am
Using Omni Importer will have the advantage to automatically retrieve footages from all your SDCards and stitch them. Once you have processed the picture with Omni Importer, you can directly open APG via the menu or go to the destination folder you have selected and drag/drop the pictures to Autopano in order to stitch them.
Best regards,
Olivier
bergerdennis
Re: omni or Giga?
by bergerdennis » Sat May 20, 2017 1:10 pm
thank you. to ask more precise: does OMNI import leads to advantage in stitching or does it not lead to better stitchin results after using AVP and Giga?
Do you need the omni importer to get a optimal stitching result with GOPRo OMNI in AVP and Giga?
olivierbo
Liked in: 134 posts
Re: omni or Giga?
by olivierbo » Mon May 22, 2017 10:04 am
You do not need Omni to get a optimal stitching result, but...it also depends on the pictures (lot of details or not, close objects with parallax issues, ...). You can use the button "Open in APG" and get something perfect. Most of the time, I usually open Omni Importer to retrieve the pictures from the SDCards, then I drag/drop them to APG ;)
Make some test to make your own workflow and you will see what you prefer and the quality you expect ;)
Best,
Olivier
bergerdennis
Re: omni or Giga?
by bergerdennis » Wed May 24, 2017 1:08 am
Thank you!
