Papywizard >>> What was wrong
rruiz
Liked in: 5 posts
by rruiz » Sun Apr 30, 2017 8:24 pm
I have a Sony a7rii with a full frame sensor (35.9 x 24 mm) .
Used a prime zeiss 24mm
3:2 RAW files of 5168x3448, then converted with Lightroom.
Below is the generated xml file
COLUMN PIC´S ARE OVERLAPED BUT BETWEEN ROWS AREN´T ? What I did wrong?
Also, why I can´t upload them "importing from "papywizard plugin" ? FINISH is grey !
Here is the generated xml file and the pics:
https://drive.google.com/drive/folders/ ... sp=sharing
<?xml version="1.0" encoding="utf-8"?>
<papywizard>
<preset name="24mm sphere">
<tooltip>
Camera:
Sensor size 35.9 x 24.0mm
Focal length 24mm
Lens vertical FOV 53.0deg
Lens horizontal FOV 74.0deg
Panorama:
Top at 90.0deg
Bottom at -90.0deg
vertical FOV 180.0deg
Vertical overlap 25 %
Horizontal overlap 25 %
</tooltip>
<shoot>
<pict pitch="90.00" yaw="0.0"/>
<pict pitch="-52.56" yaw="0.00"/>
<pict pitch="-52.56" yaw="72.00"/>
<pict pitch="-52.56" yaw="144.00"/>
<pict pitch="-52.56" yaw="216.00"/>
<pict pitch="-52.56" yaw="288.00"/>
<pict pitch="-17.52" yaw="0.00"/>
<pict pitch="-17.52" yaw="51.43"/>
<pict pitch="-17.52" yaw="102.86"/>
<pict pitch="-17.52" yaw="154.29"/>
<pict pitch="-17.52" yaw="205.71"/>
<pict pitch="-17.52" yaw="257.14"/>
<pict pitch="-17.52" yaw="308.57"/>
<pict pitch="17.52" yaw="0.00"/>
<pict pitch="17.52" yaw="51.43"/>
<pict pitch="17.52" yaw="102.86"/>
<pict pitch="17.52" yaw="154.29"/>
<pict pitch="17.52" yaw="205.71"/>
<pict pitch="17.52" yaw="257.14"/>
<pict pitch="17.52" yaw="308.57"/>
<pict pitch="52.56" yaw="0.00"/>
<pict pitch="52.56" yaw="72.00"/>
<pict pitch="52.56" yaw="144.00"/>
<pict pitch="52.56" yaw="216.00"/>
<pict pitch="52.56" yaw="288.00"/>
<pict pitch="-90.00" yaw="0.0"/>
</shoot>
</preset>
</papywizard>
mattspace
Likes: 4 posts
Re: Papywizard >>> What was wrong
by mattspace » Mon May 01, 2017 6:05 am
Someone feel free to correct me, but the xml file looks like it's showing:
Zenith
2 rows down
1 row down
1 row up
2 rows up
Nadir
I suspect those down and up rows being backwards may be a problem.
The structure of papywizard files might have changed, but here's the xml I use for 7 rows with a 60mm lens. You might see if you can reformat it to match the shoot you did, and try using it.
<papywizard version="a">
   <header>
      <general>
         <title>
            Papywizard file exported from Autopano Giga 3.7.0
         </title>
         <comment>
            Generated by Autopano Giga 3.7.0
         </comment>
      </general>
      <shooting>
      </shooting>
      <camera>
         <sensor coef="1"/>
      </camera>
      <lens type="standard">
         <focal>
            60
         </focal>
      </lens>
   </header>
   <shoot>
      <pict bracket="1" id="1">
         <position yaw="0" pitch="85" roll="0"/>
      </pict>
      <pict bracket="1" id="2">
         <position yaw="0" pitch="67.5" roll="0"/>
      </pict>
      <pict bracket="1" id="3">
         <position yaw="18" pitch="67.5" roll="0"/>
      </pict>
      <pict bracket="1" id="4">
         <position yaw="36" pitch="67.5" roll="0"/>
      </pict>
      <pict bracket="1" id="5">
         <position yaw="54" pitch="67.5" roll="0"/>
      </pict>
      <pict bracket="1" id="6">
         <position yaw="72" pitch="67.5" roll="0"/>
      </pict>
      <pict bracket="1" id="7">
         <position yaw="90" pitch="67.5" roll="0"/>
      </pict>
      <pict bracket="1" id="8">
         <position yaw="108" pitch="67.5" roll="0"/>
      </pict>
      <pict bracket="1" id="9">
         <position yaw="126" pitch="67.5" roll="0"/>
      </pict>
      <pict bracket="1" id="10">
         <position yaw="144" pitch="67.5" roll="0"/>
      </pict>
      <pict bracket="1" id="11">
         <position yaw="162" pitch="67.5" roll="0"/>
      </pict>
      <pict bracket="1" id="12">
         <position yaw="180" pitch="67.5" roll="0"/>
      </pict>
      <pict bracket="1" id="13">
         <position yaw="-162" pitch="67.5" roll="0"/>
      </pict>
      <pict bracket="1" id="14">
         <position yaw="-144" pitch="67.5" roll="0"/>
      </pict>
      <pict bracket="1" id="15">
         <position yaw="-126" pitch="67.5" roll="0"/>
      </pict>
      <pict bracket="1" id="16">
         <position yaw="-108" pitch="67.5" roll="0"/>
      </pict>
      <pict bracket="1" id="17">
         <position yaw="-90" pitch="67.5" roll="0"/>
      </pict>
      <pict bracket="1" id="18">
         <position yaw="-72" pitch="67.5" roll="0"/>
      </pict>
      <pict bracket="1" id="19">
         <position yaw="-54" pitch="67.5" roll="0"/>
      </pict>
      <pict bracket="1" id="20">
         <position yaw="-36" pitch="67.5" roll="0"/>
      </pict>
      <pict bracket="1" id="21">
         <position yaw="-18" pitch="67.5" roll="0"/>
      </pict>
      <pict bracket="1" id="22">
         <position yaw="0" pitch="45" roll="0"/>
      </pict>
      <pict bracket="1" id="23">
         <position yaw="18" pitch="45" roll="0"/>
      </pict>
      <pict bracket="1" id="24">
         <position yaw="36" pitch="45" roll="0"/>
      </pict>
      <pict bracket="1" id="25">
         <position yaw="54" pitch="45" roll="0"/>
      </pict>
      <pict bracket="1" id="26">
         <position yaw="72" pitch="45" roll="0"/>
      </pict>
      <pict bracket="1" id="27">
         <position yaw="90" pitch="45" roll="0"/>
      </pict>
      <pict bracket="1" id="28">
         <position yaw="108" pitch="45" roll="0"/>
      </pict>
      <pict bracket="1" id="29">
         <position yaw="126" pitch="45" roll="0"/>
      </pict>
      <pict bracket="1" id="30">
         <position yaw="144" pitch="45" roll="0"/>
      </pict>
      <pict bracket="1" id="31">
         <position yaw="162" pitch="45" roll="0"/>
      </pict>
      <pict bracket="1" id="32">
         <position yaw="180" pitch="45" roll="0"/>
      </pict>
      <pict bracket="1" id="33">
         <position yaw="-162" pitch="45" roll="0"/>
      </pict>
      <pict bracket="1" id="34">
         <position yaw="-144" pitch="45" roll="0"/>
      </pict>
      <pict bracket="1" id="35">
         <position yaw="-126" pitch="45" roll="0"/>
      </pict>
      <pict bracket="1" id="36">
         <position yaw="-108" pitch="45" roll="0"/>
      </pict>
      <pict bracket="1" id="37">
         <position yaw="-90" pitch="45" roll="0"/>
      </pict>
      <pict bracket="1" id="38">
         <position yaw="-72" pitch="45" roll="0"/>
      </pict>
      <pict bracket="1" id="39">
         <position yaw="-54" pitch="45" roll="0"/>
      </pict>
      <pict bracket="1" id="40">
         <position yaw="-36" pitch="45" roll="0"/>
      </pict>
      <pict bracket="1" id="41">
         <position yaw="-18" pitch="45" roll="0"/>
      </pict>
      <pict bracket="1" id="42">
         <position yaw="0" pitch="22.5" roll="0"/>
      </pict>
      <pict bracket="1" id="43">
         <position yaw="18" pitch="22.5" roll="0"/>
      </pict>
      <pict bracket="1" id="44">
         <position yaw="36" pitch="22.5" roll="0"/>
      </pict>
      <pict bracket="1" id="45">
         <position yaw="54" pitch="22.5" roll="0"/>
      </pict>
      <pict bracket="1" id="46">
         <position yaw="72" pitch="22.5" roll="0"/>
      </pict>
      <pict bracket="1" id="47">
         <position yaw="90" pitch="22.5" roll="0"/>
      </pict>
      <pict bracket="1" id="48">
         <position yaw="108" pitch="22.5" roll="0"/>
      </pict>
      <pict bracket="1" id="49">
         <position yaw="126" pitch="22.5" roll="0"/>
      </pict>
      <pict bracket="1" id="50">
         <position yaw="144" pitch="22.5" roll="0"/>
      </pict>
      <pict bracket="1" id="51">
         <position yaw="162" pitch="22.5" roll="0"/>
      </pict>
      <pict bracket="1" id="52">
         <position yaw="180" pitch="22.5" roll="0"/>
      </pict>
      <pict bracket="1" id="53">
         <position yaw="-162" pitch="22.5" roll="0"/>
      </pict>
      <pict bracket="1" id="54">
         <position yaw="-144" pitch="22.5" roll="0"/>
      </pict>
      <pict bracket="1" id="55">
         <position yaw="-126" pitch="22.5" roll="0"/>
      </pict>
      <pict bracket="1" id="56">
         <position yaw="-108" pitch="22.5" roll="0"/>
      </pict>
      <pict bracket="1" id="57">
         <position yaw="-90" pitch="22.5" roll="0"/>
      </pict>
      <pict bracket="1" id="58">
         <position yaw="-72" pitch="22.5" roll="0"/>
      </pict>
      <pict bracket="1" id="59">
         <position yaw="-54" pitch="22.5" roll="0"/>
      </pict>
      <pict bracket="1" id="60">
         <position yaw="-36" pitch="22.5" roll="0"/>
      </pict>
      <pict bracket="1" id="61">
         <position yaw="-18" pitch="22.5" roll="0"/>
      </pict>
      <pict bracket="1" id="62">
         <position yaw="0" pitch="0" roll="0"/>
      </pict>
      <pict bracket="1" id="63">
         <position yaw="18" pitch="0" roll="0"/>
      </pict>
      <pict bracket="1" id="64">
         <position yaw="36" pitch="0" roll="0"/>
      </pict>
      <pict bracket="1" id="65">
         <position yaw="54" pitch="0" roll="0"/>
      </pict>
      <pict bracket="1" id="66">
         <position yaw="72" pitch="0" roll="0"/>
      </pict>
      <pict bracket="1" id="67">
         <position yaw="90" pitch="0" roll="0"/>
      </pict>
      <pict bracket="1" id="68">
         <position yaw="108" pitch="0" roll="0"/>
      </pict>
      <pict bracket="1" id="69">
         <position yaw="126" pitch="0" roll="0"/>
      </pict>
      <pict bracket="1" id="70">
         <position yaw="144" pitch="0" roll="0"/>
      </pict>
      <pict bracket="1" id="71">
         <position yaw="162" pitch="0" roll="0"/>
      </pict>
      <pict bracket="1" id="72">
         <position yaw="180" pitch="0" roll="0"/>
      </pict>
      <pict bracket="1" id="73">
         <position yaw="-162" pitch="0" roll="0"/>
      </pict>
      <pict bracket="1" id="74">
         <position yaw="-144" pitch="0" roll="0"/>
      </pict>
      <pict bracket="1" id="75">
         <position yaw="-126" pitch="0" roll="0"/>
      </pict>
      <pict bracket="1" id="76">
         <position yaw="-108" pitch="0" roll="0"/>
      </pict>
      <pict bracket="1" id="77">
         <position yaw="-90" pitch="0" roll="0"/>
      </pict>
      <pict bracket="1" id="78">
         <position yaw="-72" pitch="0" roll="0"/>
      </pict>
      <pict bracket="1" id="79">
         <position yaw="-54" pitch="0" roll="0"/>
      </pict>
      <pict bracket="1" id="80">
         <position yaw="-36" pitch="0" roll="0"/>
      </pict>
      <pict bracket="1" id="81">
         <position yaw="-18" pitch="0" roll="0"/>
      </pict>
      <pict bracket="1" id="82">
         <position yaw="0" pitch="-22.5" roll="0"/>
      </pict>
      <pict bracket="1" id="83">
         <position yaw="18" pitch="-22.5" roll="0"/>
      </pict>
      <pict bracket="1" id="84">
         <position yaw="36" pitch="-22.5" roll="0"/>
      </pict>
      <pict bracket="1" id="85">
         <position yaw="54" pitch="-22.5" roll="0"/>
      </pict>
      <pict bracket="1" id="86">
         <position yaw="72" pitch="-22.5" roll="0"/>
      </pict>
      <pict bracket="1" id="87">
         <position yaw="90" pitch="-22.5" roll="0"/>
      </pict>
      <pict bracket="1" id="88">
         <position yaw="108" pitch="-22.5" roll="0"/>
      </pict>
      <pict bracket="1" id="89">
         <position yaw="126" pitch="-22.5" roll="0"/>
      </pict>
      <pict bracket="1" id="90">
         <position yaw="144" pitch="-22.5" roll="0"/>
      </pict>
      <pict bracket="1" id="91">
         <position yaw="162" pitch="-22.5" roll="0"/>
      </pict>
      <pict bracket="1" id="92">
         <position yaw="180" pitch="-22.5" roll="0"/>
      </pict>
      <pict bracket="1" id="93">
         <position yaw="-162" pitch="-22.5" roll="0"/>
      </pict>
      <pict bracket="1" id="94">
         <position yaw="-144" pitch="-22.5" roll="0"/>
      </pict>
      <pict bracket="1" id="95">
         <position yaw="-126" pitch="-22.5" roll="0"/>
      </pict>
      <pict bracket="1" id="96">
         <position yaw="-108" pitch="-22.5" roll="0"/>
      </pict>
      <pict bracket="1" id="97">
         <position yaw="-90" pitch="-22.5" roll="0"/>
      </pict>
      <pict bracket="1" id="98">
         <position yaw="-72" pitch="-22.5" roll="0"/>
      </pict>
      <pict bracket="1" id="99">
         <position yaw="-54" pitch="-22.5" roll="0"/>
      </pict>
      <pict bracket="1" id="100">
         <position yaw="-36" pitch="-22.5" roll="0"/>
      </pict>
      <pict bracket="1" id="101">
         <position yaw="-18" pitch="-22.5" roll="0"/>
      </pict>
      <pict bracket="1" id="102">
         <position yaw="0" pitch="-45" roll="0"/>
      </pict>
      <pict bracket="1" id="103">
         <position yaw="18" pitch="-45" roll="0"/>
      </pict>
      <pict bracket="1" id="104">
         <position yaw="36" pitch="-45" roll="0"/>
      </pict>
      <pict bracket="1" id="105">
         <position yaw="54" pitch="-45" roll="0"/>
      </pict>
      <pict bracket="1" id="106">
         <position yaw="72" pitch="-45" roll="0"/>
      </pict>
      <pict bracket="1" id="107">
         <position yaw="90" pitch="-45" roll="0"/>
      </pict>
      <pict bracket="1" id="108">
         <position yaw="108" pitch="-45" roll="0"/>
      </pict>
      <pict bracket="1" id="109">
         <position yaw="126" pitch="-45" roll="0"/>
      </pict>
      <pict bracket="1" id="110">
         <position yaw="144" pitch="-45" roll="0"/>
      </pict>
      <pict bracket="1" id="111">
         <position yaw="162" pitch="-45" roll="0"/>
      </pict>
      <pict bracket="1" id="112">
         <position yaw="180" pitch="-45" roll="0"/>
      </pict>
      <pict bracket="1" id="113">
         <position yaw="-162" pitch="-45" roll="0"/>
      </pict>
      <pict bracket="1" id="114">
         <position yaw="-144" pitch="-45" roll="0"/>
      </pict>
      <pict bracket="1" id="115">
         <position yaw="-126" pitch="-45" roll="0"/>
      </pict>
      <pict bracket="1" id="116">
         <position yaw="-108" pitch="-45" roll="0"/>
      </pict>
      <pict bracket="1" id="117">
         <position yaw="-90" pitch="-45" roll="0"/>
      </pict>
      <pict bracket="1" id="118">
         <position yaw="-72" pitch="-45" roll="0"/>
      </pict>
      <pict bracket="1" id="119">
         <position yaw="-54" pitch="-45" roll="0"/>
      </pict>
      <pict bracket="1" id="120">
         <position yaw="-36" pitch="-45" roll="0"/>
      </pict>
      <pict bracket="1" id="121">
         <position yaw="-18" pitch="-45" roll="0"/>
      </pict>
      <pict bracket="1" id="122">
         <position yaw="0" pitch="-67.5" roll="0"/>
      </pict>
      <pict bracket="1" id="123">
         <position yaw="18" pitch="-67.5" roll="0"/>
      </pict>
      <pict bracket="1" id="124">
         <position yaw="36" pitch="-67.5" roll="0"/>
      </pict>
      <pict bracket="1" id="125">
         <position yaw="54" pitch="-67.5" roll="0"/>
      </pict>
      <pict bracket="1" id="126">
         <position yaw="72" pitch="-67.5" roll="0"/>
      </pict>
      <pict bracket="1" id="127">
         <position yaw="90" pitch="-67.5" roll="0"/>
      </pict>
      <pict bracket="1" id="128">
         <position yaw="108" pitch="-67.5" roll="0"/>
      </pict>
      <pict bracket="1" id="129">
         <position yaw="126" pitch="-67.5" roll="0"/>
      </pict>
      <pict bracket="1" id="130">
         <position yaw="144" pitch="-67.5" roll="0"/>
      </pict>
      <pict bracket="1" id="131">
         <position yaw="162" pitch="-67.5" roll="0"/>
      </pict>
      <pict bracket="1" id="132">
         <position yaw="180" pitch="-67.5" roll="0"/>
      </pict>
      <pict bracket="1" id="133">
         <position yaw="-162" pitch="-67.5" roll="0"/>
      </pict>
      <pict bracket="1" id="134">
         <position yaw="-144" pitch="-67.5" roll="0"/>
      </pict>
      <pict bracket="1" id="135">
         <position yaw="-126" pitch="-67.5" roll="0"/>
      </pict>
      <pict bracket="1" id="136">
         <position yaw="-108" pitch="-67.5" roll="0"/>
      </pict>
      <pict bracket="1" id="137">
         <position yaw="-90" pitch="-67.5" roll="0"/>
      </pict>
      <pict bracket="1" id="138">
         <position yaw="-72" pitch="-67.5" roll="0"/>
      </pict>
      <pict bracket="1" id="139">
         <position yaw="-54" pitch="-67.5" roll="0"/>
      </pict>
      <pict bracket="1" id="140">
         <position yaw="-36" pitch="-67.5" roll="0"/>
      </pict>
      <pict bracket="1" id="141">
         <position yaw="-18" pitch="-67.5" roll="0"/>
      </pict>
      <pict bracket="1" id="142">
         <position yaw="0" pitch="-90" roll="0"/>
      </pict>
   </shoot>
</papywizard>
rruiz
Liked in: 5 posts
by rruiz » Mon May 01, 2017 2:36 pm
Matt
Thanks for your help. Maybe I have a stupid question, but how you generate the papywizard code within APG Pro? I can't find the option.
Thanks anticipated
mattspace
Likes: 4 posts
by mattspace » Mon May 01, 2017 4:00 pm
I think you export it from a completed pano. Personally, I think ive only ever done it once, just to get the sample code, and from then on, I've just written the xml by hand.
rruiz
Liked in: 5 posts
by rruiz » Mon May 01, 2017 5:00 pm
Can someone let me know why the xml file is not a valid one besides I used the generator link web page?
NOTE:
The links from http://www.papywizard.org/ to KOLOR WEB PAGE no longer work and would be great to have them back !!!
vincen
Kolor Certified Trainer
Likes: 23 posts
Liked in: 4 posts
by vincen » Tue May 09, 2017 7:59 am
Might sound stupid question but why don't you give directly your picture at APG and let it them stitch them automatically or it doesn't work at all ??
Blog: http://www.skivr.com
rruiz
Liked in: 5 posts
by rruiz » Wed May 10, 2017 4:18 am
Jajajaja
I plan to create a gigapanorama and would like to learn to use (head)+(BTmodule)+(papywizard generator)>>> (APG plugin) since my current pano is a little one. I don´t want to spend time in the giga and find that the setup was wrong.
Regards
vincen
Likes: 23 posts
Liked in: 4 posts
by vincen » Wed May 10, 2017 7:16 am
rruiz wrote:I plan to create a gigapanorama and would like to learn to use (head)+(BTmodule)+(papywizard generator)>>> (APG plugin) since my current pano is a little one. I don´t want to spend time in the giga and find that the setup was wrong
If you use the BT module you use Papywizard ou Pandroid no ? and if so they automatically generate the XML at end of each pano shot to give at APG !
