Papywizard >>> Image number
rruiz
Liked in: 5 posts
by rruiz » Thu Apr 27, 2017 5:09 pm
What xml generator you use? The ones provided are really good (like the original papywizard) to control the mechanical head, but when I try to upload them, ... the NEXT button keeps gray... and I read that is required at APG to have the same number of images; the issue is that APG only shows N/A when the xml file is uploaded...
Or what I doing wrong?
I have tried the following:
http://www.photosbykev.com/panoramas/pr ... 0x180.html
http://exposedbykevin.com/PapySpheric/papyspheric.html
Re: Papywizard >>> Image number
by Destiny » Thu Apr 27, 2017 11:29 pm
Hi... If you have a really well stitched pano using APG, you can then go to Edit and generate the Papywizard code from there.. You can then tweek it... You can then use that code to stitch other panos using the same shooting pattern.. If you change your shooting pattern, the code will not work..
rruiz
Liked in: 5 posts
by rruiz » Tue Jul 10, 2018 3:10 am
Guys sorry if I ask the same question again, but one year after I want to resolve this issue. I can control without problems my mechanical head but APG papywizard plug-in doesn´t recognize the associated xml file.
WHAT I AM DOING WRONG ? What I need to add/remove from the code ?
Used= http://www.photosbykev.co.uk/panoramas/ ... 0x180.html
vvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvv
<?xml version="1.0" encoding="utf-8"?>
<papywizard>
<preset name="3510P_35_4_13">
<tooltip>
Source:
Format: 35mm (1 Crop, 3:2 Aspect Ratio, Portrait orientation)
Focal Length: 35mm lens, overlap: 25%, Horizontal FOV: 28.4, Vertical FOV: 45.4
Rows: 4, Columns: 13
Target:
For 360/180, Horizontal Size: 26280, Vertical Size: 13140
Mosaic Horizontal FOV: 382.8, Vertical FOV: 191.1
Mosaic Horizontal Size: 27944, Vertical Size: 13950
</tooltip>
<shoot>
<!-- arrange columns left to right in row 1 starting from column 1 -->
<pict yaw="0.0" pitch="-22.7"/> <!-- 1,1 -->
<pict yaw="28.4" pitch="-22.7"/> <!-- 1,2 -->
<pict yaw="56.8" pitch="-22.7"/> <!-- 1,3 -->
<pict yaw="85.2" pitch="-22.7"/> <!-- 1,4 -->
<pict yaw="113.6" pitch="-22.7"/> <!-- 1,5 -->
<pict yaw="142.0" pitch="-22.7"/> <!-- 1,6 -->
<pict yaw="170.4" pitch="-22.7"/> <!-- 1,7 -->
<pict yaw="198.8" pitch="-22.7"/> <!-- 1,8 -->
<pict yaw="227.2" pitch="-22.7"/> <!-- 1,9 -->
<pict yaw="255.6" pitch="-22.7"/> <!-- 1,10 -->
<pict yaw="284.0" pitch="-22.7"/> <!-- 1,11 -->
<pict yaw="312.4" pitch="-22.7"/> <!-- 1,12 -->
<pict yaw="340.8" pitch="-22.7"/> <!-- 1,13 -->
<!-- arrange columns right to left in row 2 starting from column 13 -->
<pict yaw="340.8" pitch="-68.1"/> <!-- 2,13 -->
<pict yaw="312.4" pitch="-68.1"/> <!-- 2,12 -->
<pict yaw="284.0" pitch="-68.1"/> <!-- 2,11 -->
<pict yaw="255.6" pitch="-68.1"/> <!-- 2,10 -->
<pict yaw="227.2" pitch="-68.1"/> <!-- 2,9 -->
<pict yaw="198.8" pitch="-68.1"/> <!-- 2,8 -->
<pict yaw="170.4" pitch="-68.1"/> <!-- 2,7 -->
<pict yaw="142.0" pitch="-68.1"/> <!-- 2,6 -->
<pict yaw="113.6" pitch="-68.1"/> <!-- 2,5 -->
<pict yaw="85.2" pitch="-68.1"/> <!-- 2,4 -->
<pict yaw="56.8" pitch="-68.1"/> <!-- 2,3 -->
<pict yaw="28.4" pitch="-68.1"/> <!-- 2,2 -->
<pict yaw="0.0" pitch="-68.1"/> <!-- 2,1 -->
<!-- arrange columns left to right in row 3 starting from column 1 -->
<pict yaw="0.0" pitch="-113.5"/> <!-- 3,1 -->
<pict yaw="28.4" pitch="-113.5"/> <!-- 3,2 -->
<pict yaw="56.8" pitch="-113.5"/> <!-- 3,3 -->
<pict yaw="85.2" pitch="-113.5"/> <!-- 3,4 -->
<pict yaw="113.6" pitch="-113.5"/> <!-- 3,5 -->
<pict yaw="142.0" pitch="-113.5"/> <!-- 3,6 -->
<pict yaw="170.4" pitch="-113.5"/> <!-- 3,7 -->
<pict yaw="198.8" pitch="-113.5"/> <!-- 3,8 -->
<pict yaw="227.2" pitch="-113.5"/> <!-- 3,9 -->
<pict yaw="255.6" pitch="-113.5"/> <!-- 3,10 -->
<pict yaw="284.0" pitch="-113.5"/> <!-- 3,11 -->
<pict yaw="312.4" pitch="-113.5"/> <!-- 3,12 -->
<pict yaw="340.8" pitch="-113.5"/> <!-- 3,13 -->
<!-- arrange columns right to left in row 4 starting from column 13 -->
<pict yaw="340.8" pitch="-158.9"/> <!-- 4,13 -->
<pict yaw="312.4" pitch="-158.9"/> <!-- 4,12 -->
<pict yaw="284.0" pitch="-158.9"/> <!-- 4,11 -->
<pict yaw="255.6" pitch="-158.9"/> <!-- 4,10 -->
<pict yaw="227.2" pitch="-158.9"/> <!-- 4,9 -->
<pict yaw="198.8" pitch="-158.9"/> <!-- 4,8 -->
<pict yaw="170.4" pitch="-158.9"/> <!-- 4,7 -->
<pict yaw="142.0" pitch="-158.9"/> <!-- 4,6 -->
<pict yaw="113.6" pitch="-158.9"/> <!-- 4,5 -->
<pict yaw="85.2" pitch="-158.9"/> <!-- 4,4 -->
<pict yaw="56.8" pitch="-158.9"/> <!-- 4,3 -->
<pict yaw="28.4" pitch="-158.9"/> <!-- 4,2 -->
<pict yaw="0.0" pitch="-158.9"/> <!-- 4,1 -->
</shoot>
</preset>
</papywizard>
mattspace
Likes: 4 posts
by mattspace » Thu Jul 12, 2018 9:00 am
I've never controlled a robot pano head with it, but this gets the correct arrangement etc in APG for a 60mm 7 rows of 20, plus nadir & zenith shoot. Edit it to suit your lens, number of images etc.
<papywizard version="a">
   <header>
      <general>
         <title>
            Papywizard file exported from Autopano Giga 3.7.0
         </title>
         <comment>
            Generated by Autopano Giga 3.7.0
         </comment>
      </general>
      <shooting>
      </shooting>
      <camera>
         <sensor coef="1"/>
      </camera>
      <lens type="standard">
         <focal>
            60
         </focal>
      </lens>
   </header>
   <shoot>
      <pict bracket="1" id="1">
         <position yaw="0" pitch="85" roll="0"/>
      </pict>
      <pict bracket="1" id="2">
         <position yaw="0" pitch="67.5" roll="0"/>
      </pict>
      <pict bracket="1" id="3">
         <position yaw="18" pitch="67.5" roll="0"/>
      </pict>
      <pict bracket="1" id="4">
         <position yaw="36" pitch="67.5" roll="0"/>
      </pict>
      <pict bracket="1" id="5">
         <position yaw="54" pitch="67.5" roll="0"/>
      </pict>
      <pict bracket="1" id="6">
         <position yaw="72" pitch="67.5" roll="0"/>
      </pict>
      <pict bracket="1" id="7">
         <position yaw="90" pitch="67.5" roll="0"/>
      </pict>
      <pict bracket="1" id="8">
         <position yaw="108" pitch="67.5" roll="0"/>
      </pict>
      <pict bracket="1" id="9">
         <position yaw="126" pitch="67.5" roll="0"/>
      </pict>
      <pict bracket="1" id="10">
         <position yaw="144" pitch="67.5" roll="0"/>
      </pict>
      <pict bracket="1" id="11">
         <position yaw="162" pitch="67.5" roll="0"/>
      </pict>
      <pict bracket="1" id="12">
         <position yaw="180" pitch="67.5" roll="0"/>
      </pict>
      <pict bracket="1" id="13">
         <position yaw="-162" pitch="67.5" roll="0"/>
      </pict>
      <pict bracket="1" id="14">
         <position yaw="-144" pitch="67.5" roll="0"/>
      </pict>
      <pict bracket="1" id="15">
         <position yaw="-126" pitch="67.5" roll="0"/>
      </pict>
      <pict bracket="1" id="16">
         <position yaw="-108" pitch="67.5" roll="0"/>
      </pict>
      <pict bracket="1" id="17">
         <position yaw="-90" pitch="67.5" roll="0"/>
      </pict>
      <pict bracket="1" id="18">
         <position yaw="-72" pitch="67.5" roll="0"/>
      </pict>
      <pict bracket="1" id="19">
         <position yaw="-54" pitch="67.5" roll="0"/>
      </pict>
      <pict bracket="1" id="20">
         <position yaw="-36" pitch="67.5" roll="0"/>
      </pict>
      <pict bracket="1" id="21">
         <position yaw="-18" pitch="67.5" roll="0"/>
      </pict>
      <pict bracket="1" id="22">
         <position yaw="0" pitch="45" roll="0"/>
      </pict>
      <pict bracket="1" id="23">
         <position yaw="18" pitch="45" roll="0"/>
      </pict>
      <pict bracket="1" id="24">
         <position yaw="36" pitch="45" roll="0"/>
      </pict>
      <pict bracket="1" id="25">
         <position yaw="54" pitch="45" roll="0"/>
      </pict>
      <pict bracket="1" id="26">
         <position yaw="72" pitch="45" roll="0"/>
      </pict>
      <pict bracket="1" id="27">
         <position yaw="90" pitch="45" roll="0"/>
      </pict>
      <pict bracket="1" id="28">
         <position yaw="108" pitch="45" roll="0"/>
      </pict>
      <pict bracket="1" id="29">
         <position yaw="126" pitch="45" roll="0"/>
      </pict>
      <pict bracket="1" id="30">
         <position yaw="144" pitch="45" roll="0"/>
      </pict>
      <pict bracket="1" id="31">
         <position yaw="162" pitch="45" roll="0"/>
      </pict>
      <pict bracket="1" id="32">
         <position yaw="180" pitch="45" roll="0"/>
      </pict>
      <pict bracket="1" id="33">
         <position yaw="-162" pitch="45" roll="0"/>
      </pict>
      <pict bracket="1" id="34">
         <position yaw="-144" pitch="45" roll="0"/>
      </pict>
      <pict bracket="1" id="35">
         <position yaw="-126" pitch="45" roll="0"/>
      </pict>
      <pict bracket="1" id="36">
         <position yaw="-108" pitch="45" roll="0"/>
      </pict>
      <pict bracket="1" id="37">
         <position yaw="-90" pitch="45" roll="0"/>
      </pict>
      <pict bracket="1" id="38">
         <position yaw="-72" pitch="45" roll="0"/>
      </pict>
      <pict bracket="1" id="39">
         <position yaw="-54" pitch="45" roll="0"/>
      </pict>
      <pict bracket="1" id="40">
         <position yaw="-36" pitch="45" roll="0"/>
      </pict>
      <pict bracket="1" id="41">
         <position yaw="-18" pitch="45" roll="0"/>
      </pict>
      <pict bracket="1" id="42">
         <position yaw="0" pitch="22.5" roll="0"/>
      </pict>
      <pict bracket="1" id="43">
         <position yaw="18" pitch="22.5" roll="0"/>
      </pict>
      <pict bracket="1" id="44">
         <position yaw="36" pitch="22.5" roll="0"/>
      </pict>
      <pict bracket="1" id="45">
         <position yaw="54" pitch="22.5" roll="0"/>
      </pict>
      <pict bracket="1" id="46">
         <position yaw="72" pitch="22.5" roll="0"/>
      </pict>
      <pict bracket="1" id="47">
         <position yaw="90" pitch="22.5" roll="0"/>
      </pict>
      <pict bracket="1" id="48">
         <position yaw="108" pitch="22.5" roll="0"/>
      </pict>
      <pict bracket="1" id="49">
         <position yaw="126" pitch="22.5" roll="0"/>
      </pict>
      <pict bracket="1" id="50">
         <position yaw="144" pitch="22.5" roll="0"/>
      </pict>
      <pict bracket="1" id="51">
         <position yaw="162" pitch="22.5" roll="0"/>
      </pict>
      <pict bracket="1" id="52">
         <position yaw="180" pitch="22.5" roll="0"/>
      </pict>
      <pict bracket="1" id="53">
         <position yaw="-162" pitch="22.5" roll="0"/>
      </pict>
      <pict bracket="1" id="54">
         <position yaw="-144" pitch="22.5" roll="0"/>
      </pict>
      <pict bracket="1" id="55">
         <position yaw="-126" pitch="22.5" roll="0"/>
      </pict>
      <pict bracket="1" id="56">
         <position yaw="-108" pitch="22.5" roll="0"/>
      </pict>
      <pict bracket="1" id="57">
         <position yaw="-90" pitch="22.5" roll="0"/>
      </pict>
      <pict bracket="1" id="58">
         <position yaw="-72" pitch="22.5" roll="0"/>
      </pict>
      <pict bracket="1" id="59">
         <position yaw="-54" pitch="22.5" roll="0"/>
      </pict>
      <pict bracket="1" id="60">
         <position yaw="-36" pitch="22.5" roll="0"/>
      </pict>
      <pict bracket="1" id="61">
         <position yaw="-18" pitch="22.5" roll="0"/>
      </pict>
      <pict bracket="1" id="62">
         <position yaw="0" pitch="0" roll="0"/>
      </pict>
      <pict bracket="1" id="63">
         <position yaw="18" pitch="0" roll="0"/>
      </pict>
      <pict bracket="1" id="64">
         <position yaw="36" pitch="0" roll="0"/>
      </pict>
      <pict bracket="1" id="65">
         <position yaw="54" pitch="0" roll="0"/>
      </pict>
      <pict bracket="1" id="66">
         <position yaw="72" pitch="0" roll="0"/>
      </pict>
      <pict bracket="1" id="67">
         <position yaw="90" pitch="0" roll="0"/>
      </pict>
      <pict bracket="1" id="68">
         <position yaw="108" pitch="0" roll="0"/>
      </pict>
      <pict bracket="1" id="69">
         <position yaw="126" pitch="0" roll="0"/>
      </pict>
      <pict bracket="1" id="70">
         <position yaw="144" pitch="0" roll="0"/>
      </pict>
      <pict bracket="1" id="71">
         <position yaw="162" pitch="0" roll="0"/>
      </pict>
      <pict bracket="1" id="72">
         <position yaw="180" pitch="0" roll="0"/>
      </pict>
      <pict bracket="1" id="73">
         <position yaw="-162" pitch="0" roll="0"/>
      </pict>
      <pict bracket="1" id="74">
         <position yaw="-144" pitch="0" roll="0"/>
      </pict>
      <pict bracket="1" id="75">
         <position yaw="-126" pitch="0" roll="0"/>
      </pict>
      <pict bracket="1" id="76">
         <position yaw="-108" pitch="0" roll="0"/>
      </pict>
      <pict bracket="1" id="77">
         <position yaw="-90" pitch="0" roll="0"/>
      </pict>
      <pict bracket="1" id="78">
         <position yaw="-72" pitch="0" roll="0"/>
      </pict>
      <pict bracket="1" id="79">
         <position yaw="-54" pitch="0" roll="0"/>
      </pict>
      <pict bracket="1" id="80">
         <position yaw="-36" pitch="0" roll="0"/>
      </pict>
      <pict bracket="1" id="81">
         <position yaw="-18" pitch="0" roll="0"/>
      </pict>
      <pict bracket="1" id="82">
         <position yaw="0" pitch="-22.5" roll="0"/>
      </pict>
      <pict bracket="1" id="83">
         <position yaw="18" pitch="-22.5" roll="0"/>
      </pict>
      <pict bracket="1" id="84">
         <position yaw="36" pitch="-22.5" roll="0"/>
      </pict>
      <pict bracket="1" id="85">
         <position yaw="54" pitch="-22.5" roll="0"/>
      </pict>
      <pict bracket="1" id="86">
         <position yaw="72" pitch="-22.5" roll="0"/>
      </pict>
      <pict bracket="1" id="87">
         <position yaw="90" pitch="-22.5" roll="0"/>
      </pict>
      <pict bracket="1" id="88">
         <position yaw="108" pitch="-22.5" roll="0"/>
      </pict>
      <pict bracket="1" id="89">
         <position yaw="126" pitch="-22.5" roll="0"/>
      </pict>
      <pict bracket="1" id="90">
         <position yaw="144" pitch="-22.5" roll="0"/>
      </pict>
      <pict bracket="1" id="91">
         <position yaw="162" pitch="-22.5" roll="0"/>
      </pict>
      <pict bracket="1" id="92">
         <position yaw="180" pitch="-22.5" roll="0"/>
      </pict>
      <pict bracket="1" id="93">
         <position yaw="-162" pitch="-22.5" roll="0"/>
      </pict>
      <pict bracket="1" id="94">
         <position yaw="-144" pitch="-22.5" roll="0"/>
      </pict>
      <pict bracket="1" id="95">
         <position yaw="-126" pitch="-22.5" roll="0"/>
      </pict>
      <pict bracket="1" id="96">
         <position yaw="-108" pitch="-22.5" roll="0"/>
      </pict>
      <pict bracket="1" id="97">
         <position yaw="-90" pitch="-22.5" roll="0"/>
      </pict>
      <pict bracket="1" id="98">
         <position yaw="-72" pitch="-22.5" roll="0"/>
      </pict>
      <pict bracket="1" id="99">
         <position yaw="-54" pitch="-22.5" roll="0"/>
      </pict>
      <pict bracket="1" id="100">
         <position yaw="-36" pitch="-22.5" roll="0"/>
      </pict>
      <pict bracket="1" id="101">
         <position yaw="-18" pitch="-22.5" roll="0"/>
      </pict>
      <pict bracket="1" id="102">
         <position yaw="0" pitch="-45" roll="0"/>
      </pict>
      <pict bracket="1" id="103">
         <position yaw="18" pitch="-45" roll="0"/>
      </pict>
      <pict bracket="1" id="104">
         <position yaw="36" pitch="-45" roll="0"/>
      </pict>
      <pict bracket="1" id="105">
         <position yaw="54" pitch="-45" roll="0"/>
      </pict>
      <pict bracket="1" id="106">
         <position yaw="72" pitch="-45" roll="0"/>
      </pict>
      <pict bracket="1" id="107">
         <position yaw="90" pitch="-45" roll="0"/>
      </pict>
      <pict bracket="1" id="108">
         <position yaw="108" pitch="-45" roll="0"/>
      </pict>
      <pict bracket="1" id="109">
         <position yaw="126" pitch="-45" roll="0"/>
      </pict>
      <pict bracket="1" id="110">
         <position yaw="144" pitch="-45" roll="0"/>
      </pict>
      <pict bracket="1" id="111">
         <position yaw="162" pitch="-45" roll="0"/>
      </pict>
      <pict bracket="1" id="112">
         <position yaw="180" pitch="-45" roll="0"/>
      </pict>
      <pict bracket="1" id="113">
         <position yaw="-162" pitch="-45" roll="0"/>
      </pict>
      <pict bracket="1" id="114">
         <position yaw="-144" pitch="-45" roll="0"/>
      </pict>
      <pict bracket="1" id="115">
         <position yaw="-126" pitch="-45" roll="0"/>
      </pict>
      <pict bracket="1" id="116">
         <position yaw="-108" pitch="-45" roll="0"/>
      </pict>
      <pict bracket="1" id="117">
         <position yaw="-90" pitch="-45" roll="0"/>
      </pict>
      <pict bracket="1" id="118">
         <position yaw="-72" pitch="-45" roll="0"/>
      </pict>
      <pict bracket="1" id="119">
         <position yaw="-54" pitch="-45" roll="0"/>
      </pict>
      <pict bracket="1" id="120">
         <position yaw="-36" pitch="-45" roll="0"/>
      </pict>
      <pict bracket="1" id="121">
         <position yaw="-18" pitch="-45" roll="0"/>
      </pict>
      <pict bracket="1" id="122">
         <position yaw="0" pitch="-67.5" roll="0"/>
      </pict>
      <pict bracket="1" id="123">
         <position yaw="18" pitch="-67.5" roll="0"/>
      </pict>
      <pict bracket="1" id="124">
         <position yaw="36" pitch="-67.5" roll="0"/>
      </pict>
      <pict bracket="1" id="125">
         <position yaw="54" pitch="-67.5" roll="0"/>
      </pict>
      <pict bracket="1" id="126">
         <position yaw="72" pitch="-67.5" roll="0"/>
      </pict>
      <pict bracket="1" id="127">
         <position yaw="90" pitch="-67.5" roll="0"/>
      </pict>
      <pict bracket="1" id="128">
         <position yaw="108" pitch="-67.5" roll="0"/>
      </pict>
      <pict bracket="1" id="129">
         <position yaw="126" pitch="-67.5" roll="0"/>
      </pict>
      <pict bracket="1" id="130">
         <position yaw="144" pitch="-67.5" roll="0"/>
      </pict>
      <pict bracket="1" id="131">
         <position yaw="162" pitch="-67.5" roll="0"/>
      </pict>
      <pict bracket="1" id="132">
         <position yaw="180" pitch="-67.5" roll="0"/>
      </pict>
      <pict bracket="1" id="133">
         <position yaw="-162" pitch="-67.5" roll="0"/>
      </pict>
      <pict bracket="1" id="134">
         <position yaw="-144" pitch="-67.5" roll="0"/>
      </pict>
      <pict bracket="1" id="135">
         <position yaw="-126" pitch="-67.5" roll="0"/>
      </pict>
      <pict bracket="1" id="136">
         <position yaw="-108" pitch="-67.5" roll="0"/>
      </pict>
      <pict bracket="1" id="137">
         <position yaw="-90" pitch="-67.5" roll="0"/>
      </pict>
      <pict bracket="1" id="138">
         <position yaw="-72" pitch="-67.5" roll="0"/>
      </pict>
      <pict bracket="1" id="139">
         <position yaw="-54" pitch="-67.5" roll="0"/>
      </pict>
      <pict bracket="1" id="140">
         <position yaw="-36" pitch="-67.5" roll="0"/>
      </pict>
      <pict bracket="1" id="141">
         <position yaw="-18" pitch="-67.5" roll="0"/>
      </pict>
      <pict bracket="1" id="142">
         <position yaw="0" pitch="-90" roll="0"/>
      </pict>
   </shoot>
</papywizard>
rruiz
Liked in: 5 posts
by rruiz » Fri Jul 13, 2018 12:50 pm
Matt thanks for your code. Will use it
Still with the doubth why APG Plug in doesn´t read the code
Regards
mattspace
Likes: 4 posts
by mattspace » Sat Jul 14, 2018 12:48 pm
your code looks very different from mine - a lot more condensed with attributes stacked instead of explicitly stated separately. Could be that the generator you used DOES work for controlling the head, but isn't actually a supported syntax for APG?
